Question about Whirlpool Dryers
Whirlpool dryer tub not moving, motor sounds like it is running. Have top and back off. The narrow blt around the middle of the outside tub has slack in it. Do not know how to access motor. Need help
  • Whirlpool Master
  • 7,482 Answers
Sounds like you have a broken belt, or the belt may have slipped off the motor pulley, or idler arm pulley.
If your machine is a front loader, then if you remove the front of the machine this will expose the drum and belt. You can then remove the drum and this will expose the drum rollers, motor, and idler arm with pulley.
While you got the machine apart, go ahead and check you drum rollers to make sure they are in good condition. Also lubricate the shaft of the drum rollers with a good grade of machine oil such as 3 in one Oil, this will save you some problems later.
I hope this helps
Posted on Oct 03, 2009
Testimonial: "I followed this and fixed the problem-belt slipped off the motor and idler pulley. Thanks for the help!!"
My dryer heat but tub want turn i open the back and the belt was laying on the floor on the rt. side i would like to know if i would be able to replace it or not.
Hi again, Your parts can be found here:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11086880800/0582/0151200?searchedModel=86880800&blt=11
The belt is item 30 of this page:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11086880800/0582/0151200/00041279/00002?blt=06&prst=&shdMod=
The manual that will help you is here:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4829abde74a34d7f85256ab000620794/$FILE/4322260.pdf
Removal of the top is on page 19 / 14 printed of the pdf file
Removal of the toe panel is on page 20 / 15 printed if the pdf file
Removal of the front panel in on page 24 / 19 printed of the pdf file
The belt is installed with the ribs against the drom and the udler pulley / motor routing for the belt can be found here:
http://www.repairclinic.com/Dryer-Belt-Diagrams#DiagramH
Once you have the drum loose inspect the rear bottom drum rollers and idle pulley for any signs of wear. Flat spots or hard to turn = replace.
Thanks for choosing FixYa,
Kelly
Mar 16, 2011 | Dryers
It sounds like the spring in my washer has broken. It made a loud sound during a cycle and now the basket is completely off balance and barely moves. I was wondering if the spring is worth fixing or if...
This could be an easy fix if the counter weight came loose from the top of the tub shell which is a common problem. Pull the unit out from the wall and removed the back panel to inspect the counter weight, spider pulley and belt. If the counter weight is not broke you can reattach it to tub shell and retighten the bolts. If it is broke it is about $30.00 plus shipping. Inspect the spider pulley which is attached to the tub with the belt around it. If it is not broken, you can turn the pulley by hand to check the tub bearings for free movement. Make sure the belt is in good shape and attached to the motor spindle and spider pulley. If the spider pulley is broken you may have to order a new pulley. If you have to remove the spider pulley you may want to use a gear puller from an auto parts store to remove the pulley. The belt is easily replaced once you know the below procedure:
1. Place the belt around the center of the motor pulley stretching the belt to the spider pulley leaving no slack in the belt.
2. Keeping the slack out of the belt, place the belt on the outside rim of the spider pulley as much as the belt tension will allow you to do so.
3. Keep the tension on the belt and slowly rotate the spider pulley counter clockwise until the belt is completely on the spider pulley.
Rotate the spider pulley several times to make sure the belt stays in the center of the spider pulley. If the belt is not centered after several revolutions you need to remove the belt and reinstall it after moving the ribs of the belt on the motor pulley in the direction which centers the belt. If it was my unit I would fix it unless you have to replace the outer tub shell (approximately $300.00 for parts only).
Feb 18, 2011 | Stainless WSXH208AWW GE Extra-Large...
Whirlpool dryer model #GEW9250PT1 not drying properly
when was the last time you cleaned your dryer?all a dryer does is move air around and if it can't cycle through the dryer the clothes won't dry. unplug the dryer and then you need to clean the duct that the lint filter slides into,vac out the inside of dryer where the motor is and clean out the vent line,if the vent line is a long run from the back of dryer to the outside vent i use a leaf blower to clean it out,make sure the outside vent is clear first then blow it out,if it's a short run vac it out,most problems start just from lint buildup,the clothes don't dry the dryer runs hot and parts start messin up,also vac out under your fridge,take the bottom kick plate off and vac it out,you can kill the compreesor if you don't,good luck
Apr 05, 2010 | Whirlpool Dryers
How to install a multi rib dryer belt on my
remove the back!! top lid take 2 bolts out of the inside top of the front panel and two screws on the lower outside front panel remove the belt if its still on the drum ! slide drum outwards about 6 inches then from the back of unit slide the belt around the motor shaft and then the drum and hook around the idler tensioner slide drum back and reassemble
Jan 17, 2010 | Whirlpool LER4634J Electric Dryer
Scraping sound when tub is rotating.
The motor turning the drum may be bad OR the spindle or axle the drum turns on may be bad as well. The belt turning the drum may have been to tight thus putting too much pressure on the drum which eventually would wear it out then causing the noise which will only get louder as time goes on.
You will need to take off the back of the dryer and possibly the top to gain proper access to the drum and motor.
Jan 14, 2009 | Dryers
Broken belt on a Whirlpool dryer
Fix it yourself, and you do not need to remove the tub. Put the belt around the pulley and pull the tub towards the belt. You may have bought a belt that is too short. But upon a belt breaking they will stretch pretty bad also
Jan 13, 2009 | Amana ALW480DA Top Load Washer
Stopped running in middle of cycle
hi thanks for the question when your dryer stopped and you tried to restart if no noise the over load thermostat embedded in motor is suppose to open and not allow it to start then the motor cools down now it works till the motor over heats again and shuts off again. i would vacuum out the inside clean motor and check the venting right to the outside and try it again but remember do this with power off thanks the appliance doc
Aug 31, 2008 | Whirlpool LER5636P Electric Dryer
Dryer tub won't turn
hear the motor running, just not spinnig drum? if so you problably eiteh threw the belt off pully it broke all together. theres 2 screws holding the front panel on apprx 10 in. up and 2in. in, slightly pointed upwards. rmeove them and the front panl comes off, i believ the top might just tip back at that pint in which case youll see the belt wrapped around the drum. ro where it should be wrapped around anyway. new belt num Y312959.if needed, youll need to reach beltto motor pulley from behind unit through a small acsess hole. be carefull not rip bag bael is in because it shows placemnet of tension pulley and correct direction to wrap belt in.anything past that, im thinkin 18 yrs has been a good run, go for new
Mar 01, 2008 | Dryers
Whirlpool Dryer Motor Removal
stand that baby up!!! acess is from front, try removeig 2 screws from under lint filter and then pop top with screw driver lean top back.. youll see the tub and belt(if not broken right there),no belt??? order a 341241 whirlpool dryer belt. 2 5/16screws on either side of iside facade remoivefront caver, disconnect door switch and remove front panel. belt slips over drum , you need to reset tension pulley and wrap around motor shaft. .
Feb 26, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
94 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
