Question about Maytag Dryers
Dryersqeeks and squacks when it starts up/turning
Dryersqeeks and squacks when it starts up/turning the drum.
  • Maytag Master
  • 7,482 Answers
I believe your problem is the drum rollers in need of lubrication or replacement. The will cause the squeak and squeal as you described
If you have a front loading machine, Disconnect the power first, then remove the front of the machine, this will expose the drum and belt, then you remove the drum and belt and that will expose the drum rollers.
Try to lubricate the rollers at the shaft area with a good grade of machine oil such as 3 in One Oil.
If the drum rollers are worn very much and are sloppy at the shaft area then you may need to replace them with new ones.
While your at it check the drum roller surface to make sure they have no flat spots on them. If they do replace them.
I hope this helps
Posted on Oct 03, 2009
Why won't it start?
check for the operation of a small micro switch at the door hinge
if that is out of adjustment then the unit will not start
Jan 05, 2016 | Bosch Dryers
Westinghouse Electric Dryer, Drum doesn't turn on start up, if your spin drum and close door it will start,
Either something is binding the blower wheel up or the motor is bad. The best thing is to take the front of the machine off to access the blower wheel to verify ifanything is indeed binding it.IF not read the next section.
If you can turn the drum and then the dryer starts you have a bad motor. The way the dryer works is when you initially push the start button, electricity is sent to the start winding, or stator, of the motor. This will in turn start the motor turning. From there the stator will drop out of the electrical process and at the same time the run winding, or rotor, will take over and the motor will continie to run. Your stator is damaged, has a burn spot, etc so by you turning the drum, the belt around the drum is moved which is attached to the motor pulley. You basically take the place of the stator. Long story short, you have a bad motor.
Jun 22, 2012 | Westinghouse Laundry Dryer Motor...
My ED56 won't start unless you turn the drum by hand why?
Apr 28, 2012 | Fisher and Paykel Dryers
Dryer makes loud humming noise but drum doesn't turn when I push start.
Check to see if the drum will turn by hand. If so, leave the door open but push the light switch button down and start the unit. Once you hear the humming sound, manually turn the drum with your hand to start. If the drum turns normally, you have a bad motor and needs to be replaced. If the drum does not turn, something is jamming the motor and needs to be disassembled and inspected.
Good luck
Oct 03, 2010 | LG DLE2514 Electric Dryer
When turning the knob to start dryer, buzzing sounds but drum doesn't start to turn unless you gently push atart the inside drum
The problem is either a faulty start winding in the motor, or the circuit which energizes the start winding is failing.
A dryer motor has two windings: start & run. The start winding gets it going and a centrifugal switch disconnects the start winding when the motor gets up to speed.
Check the dryer start switch -- then the motor connections and the centrifugal switch inside the motor.
May 05, 2009 | Dryers
Dryer wont start, drum hard to turn-revised
get a new drumm it might be bent if your putting stuff that weight alot in your dryer if its making a skeeking rusing soung get a new drum about 400 dollers
Dec 21, 2008 | Dryers
Dryer Motor won't always start Model FSE747GES
Too much drag on the Drum. Try lubricating the rollers that the drum turns on. Check the belt tensioner pully...lubricate that as necessary. If Drum still turns very hard after this then take belt off of motor and try turning drum. If drum turns easily then replace motor.
Nov 24, 2008 | Frigidaire FDE336RE Dryer
Power inverter on ic-r8500
wow thats a great radio, pack it up and send it to me.(just kidding)you might want to contact icom www.icomamerica.com and talk to their techs about this one. congratulations on having one fine radio, it is worth a quality repair,ive wanted to take one of those apart for years lol
Jul 16, 2008 | Icom IC-R8500 Base Scanner
Dryer drum will not turn
Try pushing start button while turing drum clock wise and see if drum will start spinning, sounds like bad start winding or relay
Sep 17, 2007 | Estate EED4300SQ Dryer
Audio problelms
Bad Solder Connections on The Main Board(Look for Ring Breaks)
Jun 10, 2007 | Icom IC-R8500 Base Scanner
Dryers Logo
67 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
