Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
I am trying to install a programmable thermostat. The old stat had 6 wires connected to it, I will list the terminals, followed by the wire color: C-Light Blue, E-White, R-Red, G-Green, O/B-Orange, Y-Yellow. There was also a toggle switch, set to O (not set to B). I hooked up a new stat, which has Rh and Rc jumped - Red wire, W-White, Y-Yellow, G-Green. I did not connect Blue or Orange wires, taped them off. When the stat calls for heat, the gas intake fan starts running, but I get a 3 blink error message on the furnace - Pressure Switch Stuck Closed. I have taken the new stat off, put the old one back on, and the furnace runs fine. I'm trying the new one again, and I get the same error. I have a gas furnace, only one temperature sensor at the thermostat. The wiring on the circuit board of the furnace is as follows: R-Red, C-Dark Blue, W-White, Y-Yellow, G-Green. (Also, there is an orange wire connected to the green but not connected to the board). I called Honeywell, they had me change the new thermostat programming, and said my wiring was correct, but it still doesn't work. There is a jumper switch on the thermostat and it is set for a gas furnace vs a heat pump. Any help would be appreciated! I'm certain there is nothing wrong with the furnace or the pressure switch because it works fine with the old thermostat. But I have two wires that are unconnected to the new stat, and I think one of them might need to be connected to something.
  • kavaea Oct 04, 2009
    Actually there is A/C as well. I'm reluctant to disconnect anything from the furnace, because it works correctly when the t-stat is wired correctly.
    Is it possible that I should remove the t-stat jumper, connect the Red wire to Rh and connect the Blue wire, (which is connected to C on the furnace circuit board) to the Rc port on the stat? That will leave the orange wire unconnected.
  • 70 Answers
Disconect the dark blue on the circuit board of the furnace. if there is no central air the c terminal was powering the old t-stat
Posted on Oct 04, 2009
My old thermostat has 8 wires and I'm trying to figure out how to install a Honeywell Rth2310b thermostat.
The terminals on the old stat should be basically the same as on the new stat...with a couple exceptions anyway. Note the color of wire on each terminal before removing them and reconnect to the new stat on the same terminals. 8 wires typically indicate a heat pump, so in the configuration menu you'll have to tell it whether to energize the O terminal in cool or not. If you have individual wires on Rc and Rh terminals, you must remove the factory jumper between those two terminals on the new stat. If not, you'll burn out one of the two control transformers or possibly damage your new stat.
In the configuration menu, you'll have to tell it whether its a gas furnace or electric furnace, select the way the fan operates and possibly limit the cycles per hour on both heat and cool modes. There's a lot of subtle entries that need to be done to 'tailor' the new stat to your likings also.
I think it would be best to rely on someone thats a bit familiar with HVAC to change out your stat for you..... as once it is changed, all possible functions of the stat need to be verified as correct in operation.
Feb 07, 2015 | Honeywell CT3200 5-2 Day Electronic...
Hi, I have a baxi solo boiler WM60/4RS and a Landis & Gyr RWB252 timer but my Honeywell T6160 thermostat has nether been connected, can anybody shed light on the wiring connections please.
The color code for thermostat wiring is as follows.
The "R" terminal is power into the stat from the boiler control transformer. Normally 24 volts. The "Y" terminal is for cooling. Normally left blank for a boiler. The "W" terminal is for heat. This one used to start the heating cycle.The "G" terminal is for fan operation. Probably not used for a boiler. Check the boiler terminal board for these functions and write down the wire color on each one. Match the boiler colors to the right function on the stat. If you need more than this, let me know.
Jan 06, 2014 | Honeywell Programmable Thermostat Heater
Wiring with only 2 wires; which terminals to connect?
See RC and RH, RC is for cool, RH is for heat, you wire the red wire to the RH or red terminal ,either one will work actually but we generally switch the hot leg of power, W is the heat circuit
Dec 12, 2013 | Honeywell Electronic Programmable...
I am installing honywell thermostat rth111/rth221 old thermostat has two wires that are yellow and need to know where to hook up
First things first. What type of system? Heat only, boiler or furnace? Central cooling.
Do NOT take wires off the old thermostat yet, or mark the color wire, to the terminal letter. Most times W,Y,G,R, terminals and maybe even a C terminal.
Your new thermostat should have the same letters. Sometimes they mix up color wire with terminal letters...... example (yellow wire to w terminal)
Also turn off power to equipment it is controlling. It is not high volts but you can short out the transformer. Hook uo wire color to same letter terminal on old stat, to new stat. Thats it.
Nov 12, 2011 | Honeywell Programmable Thermostat Heater
Replacing an ST699 with a ST9400C following repl wiring diagram, but programmer does not come on. Is the diagram incorrect? Wiring colours do not follow any of the plans. Syst has room stat, cyl stat,...
Disregard wire colors. Instead wire by terminal designation. In other words :
Wire on "R" Terminal on old thermostat to "R" Terminal on new thermostat no matter the color.
Jun 14, 2011 | Honeywell Heating & Cooling
Carrier 6 wire, installed programmable hunter ther...
Is this a heat pump? Look in the thermostat. You should have something like the following.
Red wire to R terminal
Green wire to G terminal
Yellow wire to Y terminal
White wire to W or W1
Blue or Orange wire to the O or B terminal
Brown wire to C terminal.
Let me know what you have in the thermostat. The wire colors are not always the same.
May 21, 2010 | Carrier 38BRC048 Air Conditioner
Programmable thermostat
I am unsure of your question, but if you are just replacing your old thermostat with a new one, then connect the red wire to the Rh or R terminal and the white wire to the W terminal on the thermostat. Hope this helps
Jan 09, 2010 | Honeywell Electronic Programmable...
I tried to insatll my new honeywell programmable. the old t-stat had a white and red wire connected allread. there were 3 other wires unused, G,W,R. I hook up the original R,W wires to the new t-stat and...
The red and white wires go to the R and W terminals on the thermostat. Disconnect what you have now and hook the red wire to the R terminal and the white wire to the W terminal on the new thermostat and see what happens.
Jan 09, 2010 | Honeywell Programmable Thermostat Heater
My problem is....On my new Honeywell RTH230B thermostat the color code is Rh, Rc, W,Y and G. My wire colors are red, orange, blue, white and black. I can obviously match up 4 of them but where the heck...
First you are using abnormal wire colors for a furnace. Second.... if you have an air conditioner hooked up to this furnace, you will need to install a jumper wire between rh & rc. I am assuming this is a natural gas furnace. Usually the red wire to R terminals. Usaully the white wire to the W terminal. Take the door off of the furnace. Find the thermostat wire connection in the furnace. What ever color wire is on the R terminal in the furnace should hook to the R terminal on the t/stat. Whatever color is on the W in the furnace goes on the W on the t/stat. Whatever color is on the G terminal in the furnace goes to G on the t/stat. And the Y in the furnace to the Y on the stat. and the G in the furnace to the G on the stat. Most applications use only the R, W, G, & Y ( always put the jumper wire between Rh & Rc)
Good Luck
Hvac Teacher
Mar 26, 2009 | Honeywell Programmable Thermostat Heater
Upgrading Thermostat
Looks like your system is a heatpump system and that t-stat will not run a heatpump , you need a t-stat for 2heat and 1 cool systems
Jan 30, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
232 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
