Question about GPX HM3817DT Shelf System
I cannot remove the bottom of my cd player. I want to hang it on the wall
  • 4 Answers
Turn the system upside-down and look at the bottom of the stand. It should have arrows saying "Release." Pull the stand in the direction of the arrows, and it should come off.
Posted on Oct 10, 2009
How to hang a mirror without nails
Instructions
    • 1
      Select a location to hang your mirror by holding it up on different areas of the wall. If possible, ask another person to hold the mirror while you stand on the other side of the room to judge the best spot for displaying it. Once you've decided on a spot, mark the wall lightly with a pencil along the top and bottom edges and/or corners of the mirror.
    • 2
      Place a level against the wall horizontally at the top pencil marks and tilt it up and down slightly until the bubble centers inside the glass tube in the level.
    • 3
      Draw a line lightly with your pencil along the edge of the level.
    • 4
      Lay a thick towel or blanket on a flat work surface and place the mirror on top of it, reflective side down.
    • 5
      Wipe the back of the mirror with a damp cloth to remove any dirt or debris sticking to the surface and wait 15 to 20 minutes for it to dry. In addition, wipe the wall down and wipe or air-dry it. If either surface has greasy or oily stains or other marks, wash the surfaces with mild detergent, rinse thoroughly with a damp cloth to remove any residue, then wipe or air-dry.
    • 6
      Affix strips of heavy-duty, double-sided, mirror-mounting tape to the back of the mirror along the sides, top and bottom.
    • 7
      Remove the paper backing from the double-sided tape strips, align the top of your mirror with the pencil line on the wall and press the mirror firmly against the wall.
    • 8
      Erase any visible pencil marks.
Tips & Warnings
  • If you need to mount a heavy mirror without putting a hole in a wall, hire a professional mirror installer.
  • Never touch the adhesive surface with your fingers because you can transfer oil to the adhesive that can reduce its ability to bond to surfaces.
Related SearchesReferences
Mar 29, 2013 | YouTube Videos
How do you remove the icemaker from model mzd2768geb after you remove he screw on the bottom?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The ice maker hangs on the wall with three screws. two at the top and one at the bottom. Just loosen these screws and the ice maker will lift off the bracket and you can then reach the wiring harness to unplug it.
Dec 26, 2009 | Maytag MSD2756G Side by Side Refrigerator
Need to replace cd player in Compaq persrio 700 how do I do it? no screws in hinge covers?
Laptop off, remove the AC adapter, (Charger), if installed.
Remove the battery. Turn the laptop over so the bottom side is up.
Face the optical drive towards you. (CD drive)
See how there is a rectangular looking panel, on the bottom of the laptop? (Looking at the CD drive, the panel is over the CD drive. Bottom side of laptop)
See the single Philips head screw in the panel, towards the left corner?
Remove it.
Now take a paper clip, and bend it out straight. Make a small U-shape on the end of the straightened out paper clip, so you have something to hang onto.
On the drive tray that comes out of the CD drive, is a small hole. Insert the paper clip straight in.
This is a manual release to open the CD drive tray.
Gives you something to hang onto, to pull the CD drive out.
To install the new cd drive, (Player), just reverse these steps.
[Open drive tray. Slide CD drive in. Replace screw]
Nov 24, 2009 | Compaq Presario 700 470024-192 Notebook
My cd player refuses to eject the cd that is in.
If anyone knows how to fix this without taking it apart, I'd sure like to know!
Sometime something mechanical hangs up and once you take off the cover, careful examination and the gentle nudge or two can reveal it. Once the trapped CD is removed, the player works ok.
Other times it is a symptom of a more serious mechanical or electrical failure necessitating expert repairs.
Nov 01, 2009 | JVC KD-G200 CD Player
GPX hm3817dt - How do I get the ''removable'' stand off?
Ok, nevermind, I fixed it. You just stick a flat head screwdriver in the little slot at the bottom and pop the stand off. Thanks anyway!
Aug 29, 2009 | GPX Audio Players & Recorders
I want to take off the base of my flat screen tv.
lay tv down on a flat soft surface remove 4 philips screws on back on either side of signal brd inputs base will pull out of bottom
Oct 15, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
I just bought a second hand westinghouse dryer 6kg LD605E, the sticker on the machine is upside down and the seller told me that the machine can be used either way. it this true? thanks
The LD605 series of driers is wall mountable and stackable
When wall mounting, the drier is hung 'upside down' with the knobs at the bottom to allow access, by people less than 8 feet tall.
The original package came with wall mounting bracke, and replacement sticker for the control panel with the text upside down so that it would be right way up when the dryer was hung.
If you arent going to hang the dryer, examine one small corner of the label area, the original label may be underneath and exposed by removing the wall hanging label.
The current model in the LD605 series still comes with wall mounting kit
http://www.westinghouse.com.au/product/display/model/LD605EB
Oct 11, 2008 | Dryers
How to change a starter
a should be two bolts holding the starter, gen, chevy are vetical, frome bottom,before that is attemped, please remove positive cable from battery, then remove wires/cable from solenoid on starter,if this not accessable, you can drop starter, then remove leads, pls do not let starter hang by the leads if possible, thnku, good luck.
Oct 05, 2008 | 1993 Chevrolet S-10 Blazer
PDM-0822BD
This is called "audio transfer saturation. Rarely happens but will when there is constant use of player. Drain saturation by removing battery (if attached), With the power adapter still attached, turn off player and unplug adapter from wall for several hours. Saturation should discharge back through you adapter. Disconnect adapter from player before plugging back into wall.You may have to do this periodically when constant music is played.
Feb 29, 2008 | Polaroid PDM-0824 Portable DVD Player
Yamaha s2500 dvd player
Hello, frustrated Yamaha owners.
I have destroyed two of these machines to remove my precious CD's. I did discover this today:
1. There is a fuse but it is soldered onto its circuit board.
2. There is no easy way, like using a paperclip on the old computer cd-rom drives, to release the cd/dvd tray. However, when I destroyed my second player, I noted there is a rather large piece of metallic tape on the bottom of the player to the right side of the front of the drive on the metal bottom cover plate of the machine. It is covering a slot about an inch long. If you carefully remove the tape and use, say a phillips head screwdriver, starting at the right side of the slot as you face the front of the player, you can slide a plastic bar that will free-up the tray slightly allowing one to pull the tray out and save the cd or dvd. I would do this with the player upright but hanging over the edge of a table so that the freed cd doesn't bang around against something in the process.
For what it is worth, I hope this helps.
Yamaha should be ashamed of producing a product at this price point with an issue like this. At the very least there should be a fail-safe way of removing a cd/dvd from the drive regardless of the issue with the electronics or drive mechanism.
Apr 08, 2007 | Yamaha DVD-S2500 DVD Player
GPX HM3817DT Shelf System Logo
264 people viewed this question
Top GPX Audio Players & Recorders Experts
Tequella Chapman
Level 1 Expert
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
