Question about Cycling
Won't start after a long time in storage - Cycling
    Novelist:
  • 168 Answers
You may have to replace the spark plug, change the oil and have the carb cleaned if left in storage for an extended period of time. New gasoline today have many additives and some of them will deteriate new gasoline in as little as 30 days. Never put the unit away in the fall unless you drain both the carburetor and the tank.
Posted on Oct 03, 2009
Have you ever won a self storage auction?
yes, pretty cool huh?
Lots of work though, depending on how big the locker.
Good going, get more.
Did you have a question??
return and ask it in the Comment link if you did.
Nov 03, 2014 | Computers & Internet
Ac fan not running, but compressor runs on and off
switch/ fuse possible if it has one, if not one of the wire going to the motor was severed, or the start up capacitor of the motor if it also has one.
Jun 04, 2013 | Frigidaire FAX054P7A Wall/Window Air...
Cirago nus1000 storage server won't recognize large drive
Many older systems lack support for drives larger than 2TB. Unfortunately most prebuilt storage solutions can't be upgraded, so you're a bit out of luck. Sorry.
Jan 14, 2018 | Cirago NUS1000 Network Storage Server
Went to start my XL500 homelite chainsaw and the rope won't pull out.It worked fine when I ran it dry for storage, now it seems like th sprocket won't turn. looks like chain oil is comming out
If it is bar oil then the gasket is leaking between the oil tank and the crankcase, this would mean a full strip down and replace the gasket.
Feb 10, 2013 | Garden
Frigidaire Side by side refrigerator won't get cold.
After having been in storage for some time, your refrigerator could be low on Freon
Jan 06, 2013 | Frigidaire Refrigerators
My camera won't save to mass storage
Are you sure it's an SD card? If it's larger than 2GB then it's actually an SDHC card and won't work in the A300.
May 06, 2012 | Polaroid a300 Digital Camera
I HAVE A POWERMATE 5000 12 hp GENERATOR THAT IS ABOUT 4 YEARS OLD. IT HAS BEEN IN STORAGE AND WON'T START NOW. I THINK IT MAY BE A CLOGGED CARBURATOR. WHERE DO I FIND THE SCHEMATICS OF HOW TO TAKE...
I have the same problem on my 10 hp if it set for a long time , I remove the spark plug and put a drop or 2 of gasoline in the cylinder and reinstall the plug and wite and it starts o the first pull
Sep 07, 2011 | Coleman Powermate Powermate 5000W...
Ferrari 328GTS 1986. Has been in storage. Fully charged battery but when turn on ignition it just clicks then nothing. Any advice appreciated. Thanks Alan
Since it has be sitting in storage suggest you start out by cleaning the barttery cable ends. Then try to start it. If you are still just getting clicks then try a jump start. If it still won't start, then take the fan belt off and make sure that the engine will turn by hand - with a large socket wrench that is! If it will turn by hand, it is in your starting circuit, either a weak solenoid or bad starter. If it doesn't turn then it is internal to the engine.
Jun 29, 2011 | 1986 Ferrari 328
I just pulled my 2006 screaming eagle ultra classic out of winter storage and it won't start. The battery had a full charge and it makes a long clicking sound when I try to start it. It's the...
Harleys pull a lot of amps starting,, Just because the battery says 12v doesn't mean the charge is handling the draw when trying to start them ,, get the battery LOAD checked,, remember also,, Harley's are known for drawing Juice when starting , thats why any dealer or shop will tell you that if you start one be sure and drive it a while,, start and stop trips eat up the battery since the alt won't keep up with the charging. when I leave mine for any time, I use one of the trickle charge units just to keep it at full
May 13, 2011 | 2006 Harley Davidson FLHTCUSE Screamin...
Cycling Logo
41 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
