Upgradevidio card in a s3120n Hp slimeline to 9600 GT low profile, do i need anew pwer supple(160 w Presently).and what kind is recomendited (must be Quite)
  • 1 more comment
  • tcsakgalibec Oct 03, 2009
    What i wanted to do wasput a 9600 GT LOw profile GeFoce vidio card into a S3120n. I guess by doing this i need a new power supple, i was thinking of using either ATX pwer supple or the SHutlePc450w, which would be better, also is ther something extra (PART 0 ineed to hook the motherboard (ASus M2NC51-AR)to the new power source.
  • tcsakgalibec Oct 04, 2009
    What type of Nvidia geforce low profile vidio card ( must have dvi, hdmi,s-vid out, maily for Hd veiwing)be compatibe to put in s3120n Slimeline HP(mother board: asus , M2NC51-Ar.with 2 g ram) , with a ATX 270 wts power supple. or is there any other vidio cards that are good
  • Lavell Turner
    Lavell Turner May 11, 2010
    You should not need a new powersupply for this unit the 160watts installed should be more then enough to power your unit with out any problems. Is recommened that if you do decide to purchase another power supply make sure its a HP type . Step 3b: Ordering an upgraded power supplyIf you want to upgrade the power supply, there are additional things to consider. When adding or upgrading system components, such as memory, optical drives, or video cards, make sure that the power supply you purchase has a wattage rating equal or higher than the total combined wattage of all internal PC components. Since finding the wattage needed for each component can be extremely difficult, you can use the following general method to find a power supply that will properly provide power to an upgraded system: Find the power consumption rating of each new component that will be added to the computer. Total the power consumption ratings from all the new components. Add the power supply rating of the original power supply to the total. The formula for these three steps is: Original max power supply rating + Power consumption rating of new components <= New power supply max ratingNOTE: You can subtract the power consumption rating for devices that will be removed when upgrading. However, it is better to have a higher wattage number in the event future upgrades are needed. Purchase and install a power supply that has the same or better wattage rating than the total. For example, when installing a new video card that has a power consumption rating of 230W, and the original power supply was 250W, you can install a power supply that is 480W or greater.
    President:
  • 2,351 Answers
You are not the only one having this problem with the HP slimline systems. The facts are HP doesn't make a 300watt power supply for your slimline. To make things worse HP uses a special small 24-pin main power connector. Power supply, Slimline dimensions are:
3.25" Wide X 1 5/8" Tall X 6" Deep. The highest PS I could find that will fit in your case is 270watts. Also made by HP;
http://www.atxpowersupplies.com/270-watt-HP-slimline-power-supply-FSP270-60LE-SL.php
This should work for you. The only other option would be to replace your slimline case with a standard ATA size case. Than your options for power supplies is endless.
Cheers!
Mike
Posted on Oct 04, 2009
What video cards fit into a gateway profile 6
You won't ba able to fit a video card in this computer. Because it is a all-in-one PC.
May 26, 2012 | Gateway Computers & Internet
HP slimline 7320 needs larger video card
I checked out the specs on your computer, and it does have a single upgrade slot, of the PCI variety. Don't confuse this with PCIE, which is totally different.
To make it fit in your PC, some video cards come "low profile ready", which means the circuit board is narrow enough, and they include a narrow bracket for mounting in the slim computers. They leave it to you to switch out the bracket, which is usually a couple of screws. Pretty easy to switch out.
There is two major drawback to this suggestion:
  1. PCI is not the preferred connection for graphics cards (it has a slower interface, and thus lacks pretty much all more powerful cards).
  2. You may have to remove an existing card (a modem, or network card, perhaps) to make it available.
If you are a gamer (you want to play 3D games on it), I would hold off and save your pennies for a more capable machine. This is not it.
Otherwise, there are several acceptable (not great, but OK) low profile cards out there. Look for low-profile and PCI in the description. I know newegg has a bunch of different models available in the $35-175 range. Just make sure whatever you get is low profile & PCI.
That should get you going. Let me know if you have other questions.
Dec 21, 2011 | Computers & Internet
WHAT GRAPHICS CARD IF ANY WILL FIT IN A HP SLIMLINE S5120Y COMPUTER?
Hi catchabass1...
You will need a low profile PCIe graphics card.
Go to the following website and check out the low profile graphics cards
Please take time to rate me
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=low+profile+graphics+card
Sep 14, 2011 | HP Computers & Internet
Looking for a new video card for this model, having trouble finding one that will fit, any ideas?
any low profile video card with do. Try the following:
A) XFX NVIDIA GeForce 7300 GS Low Profile (Part # PV-T72G-WAN7, PV-T72G-****) $55
B) Visiontek Radeon X1650 Pro HD Low Profile (Part # V261-4038) $70
C) MSI NX8500GT-MTD256EH GeForce 8500GT 256MB 128-bit GDDR2 PCI Express x16 HDCP Ready SLI Supported HDMI HDCP Silent Heatsink Video Card - Retail $76.99
D) Leadtek WinFast PX8500 GT TDH Low Profile $131 (Available in Passive or with Fan versions)
E) Sapphire ATI 256MB X1600PRO HDMI PCI-E (TVO, DVI), Low profile (brackets included) $139
Mar 09, 2011 | HP Pavilion Slimline s3600z Desktop PC
Hi. i have a compaq presario sr5025an. I have 2 gig of ram. I have the intel core 2 duo e4300 processor. I am after a grapics card. cheers.
To get the full specs of your mainboard go to: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00893006&lc=en&cc=au&lang=en&product=3401230&dlc=en#N198
This motherboard has 1 PCI Express x16 slot for a graphics card.
You could use:
Geforce 6 series (6800GT)
Geforce 7 series (GeForce 7950, GeForce 7900, GeForce 7800, GeForce 7600 ,
GeForce 7300, GeForce 7200 and GeForce 7100)
Geforce 8 series (GeForce 8800 Ultra, GeForce 8800 GTX, GeForce 8800 GTS, GeForce 8800 GTS 512, GeForce 8800 GT, GeForce 8800 GS, GeForce 8600 GTS, GeForce 8600 GT and GeForce 8500 GT)
Geforce 9 series (GeForce 9800 GX2, GeForce 9800 GTX+, GeForce 9800 GTX, GeForce 9600 GT, GeForce 9600 GSO 512, GeForce 9600 GSO and GeForce 9400 GT
Geforce 200 series (GeForce GTX 295, GeForce GTX 285, GeForce GTX 280, GeForce GTX 275, GeForce GTX 260, GeForce GTS 250 GeForce GTS 240 and GeForce GT 220
Geforce 400 series (GeForce GTX 480, GeForce GTX 470, GeForce GTX 465, GeForce GTX 460, Geforce GTX 450)
With your system however I would recommend nothing greater than a Geforce GTS 250.
Please rate me high.
Thanks.
Nov 01, 2010 | HP Computers & Internet
Infinate loop on 9600 gt
look like you have a lag in your game that maibe related to a bad driver go here (http://www.nvidia.com/object/product_geforce_9600gt_us.html ) for the lastest drivers thanks
Nov 09, 2009 | BFG Technologies NVIDIA GeForce 9600 GT OC...
Tuner hardware not found,worked a while back , just now trying to record something and now this error comes up(ViZS pure tv-U48A3) I have surfed all over looking for an answer but no one including HP seems...
home premium comes with a set of default drivers romve the default audio driver and install you original audio drivers which are made for vista by your lp company
Oct 14, 2009 | Microsoft Windows Vista Ultimate Edition
Hp s3120n slim line freezing up
Sounds like a video issue. What OS is on the machine? Try updating the video card drivers. If the OS is Windows 2000 or older, update your version of DirectX as well.
If that doesnt work, check system resources. Low memory, and low hard drive space can be a cause.
If all else fails, replace the mouse. Mice are very inexpensive now. Keep us posted.
Feb 28, 2009 | HP S3120N Pavilion Slimline Desktop...
Computers & Internet Logo
229 people viewed this question
David Payne
David Payne
