Question about Hitachi HTS542525K9SA00 250 GB SATA Hard Drive
Defect hard drive
Hi, my name is Remco, I've got a problem with my Hitachi travelstar HTS542525k9SA00 hard drive. The BIOS doesn't recognize it anymore. The platters still spin though when I connect it (so no crashed read/write heads). How much chance do i have to repair it by replacing the pcb with a replacement?
thanks in advance
    Scholar:
  • 82 Answers
If you can get an exact replacement controller even down to the firmware level, there's about a 50% chance it will work. No one can guarantee anything at this point but if the data is valuable enough to you, that's probably your cheapest option. Otherwise, you'll be looking at about $1000 or more for a data recovery specialist to recover data from the drive.
Posted on Oct 04, 2009
Won' recognized my external hitachi z5k320
check data cable.
change use port and check the driver on any other PC.
if problem is same after doing so. check hard drive Cage. change driver Cage
Jul 14, 2014 | Hitachi 160GB Travelstar Z5K320 SATA 3Gbs...
Cant access HITACHI TRAVELSTAR 5K250 HTS542516K9SA00 160GB drive
If the drive cannot be accessed then the logic board on the hard drive is toast. U can remove the sata drive and install it into a working desktop with sata connections and see if the desktop recognizes it.
When installing on another computer, make sure that you are still booting up from the working sata drive originally there. If you change the bootup sequence to the allegedly non working drive and it does work you may corrupt the operating system in the bootup process. Just put it in there and see if the other computer boots up and recognizes it. Often if a hard drive is really bad the defective unit will prevent a good working computer from booting up at all.
Nov 22, 2013 | Fujitsu "HITACHI TRAVELSTAR 5K250...
I bought a Hitachi z5k320 hard drive trying to install it, and windows, but my computer won't recognize hard drive. how can i get it to recognize the new drive. can't do anything until that happens.
As long as you are sure the hard drive is connected properly with SATA cables to the motherboard and has power from the power supply unit, and that the drive is working, you can enter the BIOS on computer startup and modify the "boot device" look in "primary boot device" for a name matching that of your hard drive (probably "HITACHI .....) If it is there select it as the primary device and hopefully it will boot and ask you to install windows. If it is not there the drive may not be connected or it may need to be replaced. Hope this helps!
Mar 15, 2011 | Hitachi 160GB Travelstar Z5K320 SATA 3Gbs...
When installed the HDD spins but the PC does not recognize the HDD. Not in BIOS, not thru the DOS-prompt or in sys configure/hardware or HDD configuration. It also interfers with the startup of the PC and...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help
Mar 15, 2011 | Hitachi Travelstar 5K500.B...
Which of Hitachi Hard discs could be a better replacement for model HTS541080G9SA00???
Just choose Hitachi Travelstar 320 GB, 5400 RPM, SATA , 2.5'' for convenience files storage.
Dec 19, 2010 | Hitachi Travelstar 5K100 HTS541080G9SA00...
How to download the driver of Hitachi Travelstar 5K100 HTS541060G9SA00 ? plz plz help me
I am not familiar with Linux but have you checked your Bios to see if Sata Hard Drive is recognized in there??? Most of the time you have to set the bios to recognize a Sata drive because 90% of Hard Drives are still IDE and most bios software is still recognizing the IDE drives. I know I had to reset everything on my Motherboard and Bios when I changed over from an IDE to SATA Hard Drive.
Nov 01, 2010 | Hitachi Travelstar 5K100 HTS541060G9SA00...
Hi where is the jumper to put the hard drive into slave position on a hitachi TRAVELSTAR HTS541080G9SA00 ? I cannot find it Many thanks best regards
Hi
There are no jumpers to set on a SATA drive since they all use individual interfaces with the motherboard.
All you can do is connect the drive you want as master to the first SATA header,slave to the second,and then set the boot priority in BIOS.
They don't have jumper pins like the old days.
Post again if you have questions,and if this helps would you rate my post?
Bob
Aug 22, 2010 | Hitachi Travelstar 5K100 HTS541080G9SA00...
My hard drive which is model dk23eb-40 is not being recognized by my computer at all. not in the bios or nothing. is there something else i can do or is it gone completely
If you can try it in another computer, as the _only_ device connected to the "data" ribbon-cable, and it still fails to be detected, then it's gone, gone, gone.
Jan 16, 2010 | Hitachi TravelStar DK23EB Series DK23EB-40...
Hitachi travelstar dk23ea 30 will not load windows
Try memtest86 and be sure the memory in the system is working. Also, some systems are tied to APCI... make sure your bios has it enabled.
Jan 09, 2009 | Hitachi TravelStar DK23EA Series DK23EA-30...
Hitachi HTS542525K9SA00 250 GB SATA Hard Drive Logo
298 people viewed this question
Top Hitachi Computers & Internet Experts
Fotis Papastamatiou
steve morris
steve morris
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
