Cant locate jumpers on motherboard of dc7700 motherboard
  • 86 Answers
Where are the jumper (pins) on a KONA-SVT motherboard?
Sorry don't now where jumper is for this model. However, most jumpers are located not too far from the bios battery. If you still can't find the jumper try disconnecting the power source from the motherboard, remove the bios battery, then press the power switch to dissipate the capacitors. Wait 5 minutes then re-insert the bios battery and reconnect power to the motherboard. You should now be prompted by the bios to set the time when you start the computer. Good luck
Nov 27, 2015 | Lenovo Computers & Internet
Cant open computer with original password so had to open second user with no password and would like to completely remove the password so I can get easy access to my Hotmail ect
There are jumpers on most all modern motherboards that are password overrides. Find out you motherboard manufacturer (should be stamped on the motherboard) and look up the diagram to show you the location of the jumper. Then simply place the jumper on the correct pins and the password will be wiped out.
Hope this helps.
Oct 19, 2013 | Computers & Internet
Hi, I messed up my BIOS by trying to update it... I got an asus p4b533 and cant find how to do a CMOS reset. I read about shortening two bumps because this board obviously has no jumpers to reset CMOS....
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard.
If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine.
Hope this helps
Jan 16, 2011 | ASUS P4B533-VM Motherboard
I have the e210882 motherboard and i have a prob with "bios" cant get in.. Need password..how can i fix this?
Hi!
It so simple, you don't need to blow your mind looking and thinking of the password. Just reset the BIOS jumper configuration straight from your motherboard and the password will be gone.
Open your computer system case and then look for this thing:
Next, move the jumpers from the their default location (Example: from across pins #1 and #2 as above) and then place the jumper across pins #2 and #3.
Leave the jumper in place for 20 to 30 seconds and then return it to its default location.
Its done! The password is gone!
Or you can try also this procedure.
- Just remove the BIOS battery and place it back.
Refer to your motherboard manual to do this as reference.
Have a nice day!
Thank you for reaching us.
May 20, 2010 | Dell (E210882) Motherboard
I would like to move it in to a bigger case
When looking at the specifications of the HP Compaq DC7700 SFF Desktop PC, all they state is the motherboard form factor is, 'Custom'.
Same thing for the DC7700 USDT Desktop PC.
Both of these desktop computers are of the 'Pizza Box' design.
(Flat rectangular box)
The DC7700 CMT model is a tower model, and the motherboard form factor for it is uATX.
uATX can also mean Micro-ATX.
The form factor of a Micro-ATX motherboard is 244mm by 244mm, or also said as 9.6 inches by 9.6 inches.
(9.6 inches is approximately 9 and 9/16ths inches)
To regress for a moment, and explain the term Form Factor.
This term is supposed to apply only to motherboards, but has gone on to apply to computer cases, and power supply's.
Form factor means the dimensions of the motherboard, and also where the I/O area is located.
[I/O = Input/Output
Area for the Input/Output devices that are attached to the computer.
Examples: Mouse, Keyboard and Monitor]
Whether the motherboard is installed onto the Left side of the computer case, and the I/O area is on the Left side also (ATX , Micro-ATX, and uATX form factor),
or
whether the motherboard is installed on the Right side of the computer case, and the I/O area is on the Right side also. (BTX)
Dimension sizes:
ATX is 305mm x 244mm. (12 inches by 9.6 inches)
Micro-ATX is 244mm x 244mm (9.6 inches by 9.6 inches)
http://en.wikipedia.org/wiki/Computer_form_factor
Above the link is the Maximum size for the Micro-ATX form factor.
It can also be the Minimum size of 171.45mm x 171.45mm
(Or 6.75 inches by 6.75 inches.
6.75 inches = 6 and 3/4 inches)
http://en.wikipedia.org/wiki/MicroATX
Point of all this?
The motherboard form factor inside a DC7700 SFF is probably a uATX form factor, and is 6.75 inches by 6.75 inches.
Or some variation thereof.
It's a custom size.
This means good luck in finding a computer case you can buy off of the shelf, and is large enough to install an ATX power supply.
You can get a custom one made, and you're probably looking at $150 to $200.
Or, you can modify one of these computer cases VERY easily,
1) http://www.directron.com/cs888uvbl.html
The above is an Acyrlic plastic computer case. It's approximately 1/4 inch thick for the case walls, bottom, and top.
VERY sturdy.
It has metal Standoff's that are set up for an ATX motherboard.
It should have holes in the case where a Micro-ATX motherboard can be mounted, by unscrewing the Standoffs, and screwing them into the Micro-ATX holes.
[A Standoff is a piece of metal that is hex shaped, and has a threaded hole in one end, and a threaded end on the other side ]
If there isn't the proper holes for mounting your motherboard, you make the holes.
The case is plastic.
Uses an ATX power supply.
The cost of the case is $50
Mar 08, 2010 | HP RT810UTABA - HP dc7700 small form...
Can anyone help me on how to reset the Bios password to default on an HP Compaq 6710b Laptop? I have an HP Compaq 6710b Laptop. It is booting but it cant go beyond bios boot and i cant enter setup as it is...
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Oct 16, 2009 | HP Smart Buy Notebook
How do I reset cmos?
You need to located the jumper on your motherboard. Usually located near the battery. Just remove the jumper from the current location and place onto the other pins. You should see 3 pins after you remove the jumper. Pins 1 & 2 might of had the jumper on it. You then need to place the jumper on pins 2 & 3. Do this with the power off. Wait a few seconds and them place the jumper back on pins 1 & 2 and restart your computer.
Mar 28, 2009 | Computers & Internet
Hp dc7700
verify you device manager if there is modem or network card installed, if you see a device with yellow question mark..it means you need to install the right driver
network card are built in to motherboard...maybe the right driver is not installed.
you can verify the original configuration by going to hp web site support and type the product number..
Mar 15, 2009 | HP RT810UTABA - HP dc7700 small form...
Computers & Internet Logo
631 people viewed this question
David Payne
David Payne
