Question about Kenmore Dryers
When I turn the dryer on the green light flashes; when I press start the machines "beeps" but doesnt start Any suggestions
  • 6 Answers
Sounds like it might be stuck in a cycle, Turn off at braker box wait a few seconds an turn back on, This should lit the dryer reset and try again. Also check you owner manual for trouble shooting problems.
Posted on Oct 03, 2009
Frigidaire electric dryer (FEQ1442CES) keep flashing and beeping even after cleaning lint filter.
Good Afternoon Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, keeps beeping and flashing lights. I also see that you have cleaned all the lint out and your appliance will not run more than about 10 seconds. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance, determine what is causing the lights to flash and the beeping, and repair your dryer. Hope this is helpful.
-Best Regards-
WP
Jul 04, 2014 | Frigidaire FEQ1442ES Electric Dryer
Frigidaire Gallery model GLEQ2170KSO dryer turns off within a minute.
Hello allisonarena - Try reprogramming the dryer by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and then turn on the unit. If issue persists, then the dryer may possibly be experiencing more serious issues such as; wiring failure, faulty control board, thermal limiter, or defective door switch. I would recommend connecting with an experienced appliance repair tech to assist further and to reduce the risk of unnecessary parts.
Jun 12, 2013 | Frigidaire Dryers
Start button will not initiate on cycle. Get 3 beeps.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jun 20, 2010 | Whirlpool GEW9250 Electric Dryer
Dryer says locked
The Operating Instructions say this:
Control Lock
To avoid having someone accidentally start or stop
the washer, press OPTIONS and Select at the same
time and hold for about 10 seconds until the
(Control Lock) lights up. “LOC” will be displayed
alternately with the estimated cycle time. Turning
the Cycle Selector knob or pressing any button
will produce flashing indicator lights and/or beeping.
To unlock the controls, press and hold OPTIONS
and Select for about 10 seconds.
Oct 14, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Whirlpool Duet Gas Dryer won't start
Did you take the shipping blocks out? They are inside the machine. You will need to remove the access cover on the back and look in, you cant miss them. Good luck
Jul 26, 2009 | Dryers
Malber Dryer won't start (sine-wave light flashing)
The dryer is easy: turn it on and turn the control to 0. It will beep. Then turn it to the desired program (20, 40, 60 minutes or a pre-programmed cycle), it will beep again and start. If there's a red light you have to empty the water tank at the front on the left. The washer is a normal washer. Just pick your program and press start (be patient as it takes a while to get cranking). Sometimes you have to really push the door closed very hard. Try and turn the control to 12 o'clock before setting it again.
May 30, 2009 | Malber TD800 Electric Dryer
How do i disconnect my HBH PV703 Headset from a damaged phone and connect it to another Phone
Step 1 - To reset your Bluetooth headset:
  1. Press and hold down the volume keys "+" and "-" on your headset at the same time, until your hear a beep and the light flashes red and green alternately.
  2. Press and hold down the volume keys on your headset until it is turned off. The headset is now reset as it was when purchased.
Step 2 - To pair the headset with your phone:
  1. Make sure the headset is turned off.
  2. Turn on the Bluetooth function and Bluetooth visibility in your phone (This makes the phone visible to other Bluetooth devices).
  3. Place the phone within 20 cm (8 inches) from the headset.
  4. Press and hold down the call handling key on the headset until it beeps, shows a steady green light and then flashes red and green alternately. If the indicator light only flashes red or green, simultaneously press and hold down both volume keys until the headset beeps and flashes red and green alternately.
  5. If your phone supports auto pairing, press "Yes" when you are asked to add the headset to the phone. If not, check your phone User Guide on how to pair the Bluetooth device. If required, the headset passcode is 0000.
  6. The headset beeps and flashes green when successfully paired.
Jan 21, 2009 | Audio Players & Recorders
Gw11 fisher & Paykel
Peace
ngfam1 at you service,
It sounds like it may be a faulty lid or door sensor!
A&E Factory service is nation wide and only charges $75 service call in my area!. (NJ)
They are available 24/7 to set appointments!
Bless You,
Please give me a good rating befor e you sign off of fixya.com
Sep 01, 2008 | Fisher and Paykel GWL11 Top Load Washer
Focusing Still Photos with SD870 IS
If you check page 45 in the manual, you'll see that the orange light during the half press indicates that the flash is turned on. A single beep means that the camera is having difficulty getting a "focus lock" (usually when shooting in low light conditions). See page 100 of the manual for suggestions on how to improve the chances for getting a well-focused picture.
May 01, 2008 | Canon PowerShot SD870 IS Digital Camera
Dryers Logo
56 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
