Question about Philips DVDR3576H DVD Recorder
Some Philips DVDR3576H recordings get stuck during playback.
I have used a Philips DVDR3576H for less than a year to regularly record programs off the air. About one out of ten recordings cannot be played back without sticking at some point and these programs also cannot be dubbed to a DVD. Some recordings play OK the first time but then develop a sticking point. I have found that I can remove the sticking point by using the editing feature to divide the title ten seconds before and after the sticking point but that is an awkward workaround and loses twenty seconds of the recording. This problem has occurred more frequently over time so it seems that maybe the hard drive has become fragmented and needs to be cleaned but I am not aware of a process for doing that unless erasing all program recordings will allow the hard drive to start on a clean slate so to speak. I plan to do that after I have watched or transferred to DVD all of the current recordings. Philips' only suggestion was that a proprietary signal in the program may be causing the problem but I don't buy it since I have downloaded digital video from my camcorder and have experienced the same problem. I have seen many complaints about similar problems with other hard drive recorders as well so I assume it must be an inherent problem with the current level of technology. This technology is great when it works but extremely frustrating when there is a glitch like this. Hopefully, some day, the manufacturers will acknowledge this problem and implement appropriate corrective action. Until then, I will continue to deal with this shortfall and be thankful for the ~90% successful recordings.
3 Suggested Answers
  • 223 Answers
SOURCE: I have 10 year old
Check if your disc player is a twin tuner model which will allow you to do what you want. It might just need configuring properly. Otherwise there are devices on sale that will allow you to achieve your goal. Good luck.
Posted on Sep 26, 2008
SOURCE: I Have been trying to
First, I think that you must use DVD + R blank discs in order for them to play on another unit. Secondly, when dubbing is completed and you *stop* the process, usually the recorder automatically finalizes the disc.
Posted on Jan 05, 2009
I taped 8 hours of programming in LP mode and want to burn it onto disc. Can I use the divide title mode to split the title into 3 segments so I can fit on 3 discs?
Yes, go into hdd list of recorded shows and select show
edit, chapter mark, find about 1/3 of show, select mark,
yes, back 1 menu under chapter mark is split or cut,
just select and you now have 2 files, 1/3 of show and 1 2/3 of show, just repeat, for 3 parts. and burn to dvd.
Jan 07, 2010 | Philips DVDR3576H DVD Recorder
Cooling fan on Philips DVDR3576 runs on when the unit off?
I noticed the same thing on mine. I determined that the unit turns on the fan AND Hard Drive during the period of 11:59 to 12:00 BOTH AM and PM and continues to run until the unit is cycled on and off either with remote or by a program. I used a stethoscope to listen to the Hard Drive humming inside; when the unit is cycled off I could hear the Hard Drive shut down, and a second or 2 later, the fan shuts off. I had purchased several other new units thinking I would return the "defective" one. Testing them, (by setting the clock to 11:57 and wait) both other 2 units did the exact same thing. So I assume that's a software "oops" on probably all units.
My "solution" is to set up "dummy programs" to record for 1 minute after those time periods: like 12:03 to 12:04 AM and PM on a daily schedule, and I pick a channel I usually don't record. The 00:01:00 recording time and "special" channel number make it easy to quickly identify the unwanted "dummy programs" and I use the "multiple title delete" feature to periodically delete them.
So I accumulate 2 titles per day, but I prefer that to having the hard drive run all the time.
Incidentally, I talked to a sevice rep at Philips, and the only thing they could offer is to set up a return for refund. The Philips 3576H is, in my opinion, a fantastic unit and I think the little glitch is well worth the benefits of the features it provides. How did I ever live without it???
Mar 25, 2009 | Philips DVDR3576H DVD Recorder
Picture playback
Your hard drive needs to be reformatted.. its a long process
Mar 15, 2009 | Philips DIRECTV R15
No playback pics. Blue screen.Can't record.Used x2 since service.
I just made contact with a service tech who seems very competent and who won me over. Have problem with video and audio dropout similiar to dirty heads on a 10 year old DCR-VX2000 but which is a larger problem attributed to worn parts which will need replacement. Do not know how old your unit is, but will share name of person/company if you wish. Only thing that worries me is if you by chance had had yours repaired by them!!! They are a Southern California company.
Jan 27, 2009 | Sony DCR-VX2000 Mini DV Digital Camcorder
Dvdr3576h will record on dvd+r but will not play on other devices
You will need to finalize the discs on the Philips. I know the manual says that +r may auto-finalize, but I found that finalization sometimes fails on the first attempt. Go into the menu for the Philips, and select the Edit Disc -> Finalize option. Once finalized, your disc should play in other players.
-Tha Mp3 Doctor
Nov 14, 2008 | Philips DVDR3576H DVD Recorder
Philips DVDR3576H  DVD Recorder Logo
62 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
