Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
I've replaced the ink cartridges in my brother 240C printer but it keeps telling me to re-install & won't print.Help!
  • llussier4 Oct 03, 2009
    I tried doing what you told me to do but I still have the same problem
    Genius:
  • 1,112 Answers
Make sure you removed the protection strip from the cartridges print head, if so take an pencil and use the eraser end of it and gently use it on the copper contact pad, also inside the cartridge housing use gentle force to erase until shiny.
Posted on Oct 03, 2009
  • Lavell Turner
    Lavell Turner Oct 04, 2009
    It is possible the print heads are faulty, try replacing them again, I know this cost money but if the printer was working before this happened, then the printer might be ook. Also try updating the firmware and drivers. If these are ink refill catridges they may not work make sure you are using orginal Brother ink and cartridges.
Won't print black
TRY CLEANING THE INK CARTRIDGE. If it doesnt work, go to service center with the printer.
Jun 30, 2012 | BROTHER INTERNATIONAL CORPORAT BROTHER...
My Brother LC61, bought in Nov.2010, won't print black. Recently replaced black ink along with all color inks...replaced black ink again when it quit printing...still won't work. Machine whirs...
This is common problem with Brother Printers. I am going to assume you are using Non-Brother branded ink cartridges. Brother cartridges have a cleanser in the ink that most generic cartridges don't have. This in turn causes the jets to clog and not allow ink to pass through them. The fix is to go buy a couple of Brother cartridges and do a cleaning with those cartridges. You may spend some money doing this as a cleaning wastes a lot of ink, but it will clean the injection lines and fix the printer. You could also consider buying a new printer. I know this is not the answer you were looking for, but it is the true answer. I just bought a new printer due to this fact.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 11, 2011 | Brother Multi-Function Center MFC-240C...
Brother 240C= Replacing 1 cartridge only,leaving others empty. Will not print!!! Must I replace all cartridges or can I bypass in system memory Much Thanks
You must replace all cartridges.
Make sure it is Genuine Brother Cartridges.
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Feb 05, 2010 | Brother MFC 240C All-In-One InkJet Printer
Have a MFC-240C used INNOJET compatible cartridges. display said magenta empty, opened it up, cartridge had leaked. replaced with new INNOJET. No magenta ink is printing. CLOGGED????? what to do? THNX
Brother Genuine Cartirdges????
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
Hi I have bought new in black cartridge and nothing .what should i do ??? Have MFC -790 cw all rest collor printing good only have problem with black one .
Did you use Brother Genuine Cartridges?????
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
If you are using Generic, replace them with Genuine Brother Ink Cartridges.
Good Luck
Jan 29, 2010 | Brother Multi-Function Center MFC-240C...
MFC-240C. replaced black ink cartridge. I've done so before ok. This time we had the original refilled. The computer shows it full, but when you hit print nothing happens. thanks
Did you use Epson Genuine Cartridges? Brother Genuine Cartirdges????
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE
BE BETTER IF YOU DISABLE THE INK MONITOR.
The next step would be to disassemble and clean the Pads/Heads.
A good Forum below Click on link below.:
http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
Jan 28, 2010 | Brother Multi-Function Center MFC-240C...
INK CARTRIDGES ALL NEW. SAYING THEY ARE EMPTY
Hi, i think during the process of changing the cartridges, the top lid on the ink cartridge that clips or keys the cartridge down inside the printer has been broken and needs to be replaced.
I suggest you get a technician to help get a replacement for this. With this your printer should be in other.
Jan 04, 2010 | Brother MFC 240C All-In-One InkJet Printer
I installed a new black ink cartridge and the printer says the ink cartridge in empty. The printer is a Brother MFC-240C All in one Ink jet priner.
Please look here:
http://www.hstt.net/forum/
It is an refill forum (in german and english).
And here is described how the detecting of inc on this printers happens:
http://www.hstt.net/refill-faq/brother.html#LC-900%20Tips
Dec 30, 2008 | Brother MFC 240C All-In-One InkJet Printer
HELP ON MFC-240C
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Sep 01, 2008 | Brother MFC 240C All-In-One InkJet Printer
Print faded after replacing black cartridge Brother 240C
The print heads don't appreciate being out of ink so the Brother printer has sensors to prevent that but the tape defeated that prevention. Maybe more cleanings or maybe a cartridge with printhead cleaning solution will help. Otherwise, I fear a new printer.
Dec 13, 2007 | Brother Multi-Function Center MFC-240C...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
139 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
