Question about Pentair Minimax NT Heater
Winterize minimax heater
How to winterize minimax heater
Lost the manual to my heater. Would like to know how to
winterize the heater. mini max ch 250 M
bl.wilson @ hotmail.com .. thank you, hope you can help me.
Posted on Sep 05, 2011
How do i install an igniter in minimax
Pentair 472604 Igniter Replacement MiniMax NT STD Pool and Spa Heater
The ignitor is simple to replace, It is either a spark ignitor or a Hot surface ignitor. The above link will take you to a picture of the Hot surface ignitor, it is normal held onto the bottom of the burner tray, at right about the middle, by 1 or 2 sheet metal screws.
If a Spark style ignitor/electrode, then the bottom link is the one want to look at. Again, held in place the same way as above description.
Pentair 471090 Ignitor Electrode Replacement MiniMax 75 100 Pool and Spa...
Good Luck
Jun 04, 2014 | Pentair Minimax NT Heater
Pentair Pool Heating Rapidly Increases Temp on Panel then shuts off.
Check the Thermal Reg in the header and also make sure you have adequate water flow thru the heater, make sure your filters are clean and there are no external by-pass valves open.
If you remove the Thermal Reg in the header and the heaters seems to run fine the replace with a new one.
May 03, 2017 | Pentair Minimax NT Heater
There's water leaking from side of heater
this is 100% broken heat exchanger its the coils inside of heater that heats the water this usually happines from really old age or because your climate temperature is below freezing and broke the coils, i see it all the time in winter season, best way to prevent this is to run your heater for fifteen minutes every month and make sure pool equipment runs all day everyday when its really cold out you can start running system normaly after your outside temp is warmer. its better to get a new heater when this happines heat exchanger is hard to install for most tech's pretty much have to take whole top part of heater off and is also expensive part
Jan 27, 2011 | Pentair Minimax NT Heater
Drain Plug broke in half and is stuck
If you can not get the pice still in the header out, loosen the flanges that hold the inlet and outlet pipes enough for water to drain and then tilt the unit so the water inlet/outlet side is lower than the other side. You may want to place a block of wood under the edge to kep it this way for the winter. Be sure to also remove the pressure switch to allow that tube to drain as well.
Oct 03, 2009 | Pool & Spa
Need to reignite the heater and the instructions on the panel are paritially destroyed. it is a minimax plus 250 and have tried finding the instructions on line
For an Owner's Manual for the MiniMax Plus heaters, which does contain start up proceedures for the electric and millivolt models, you can follow the link below.
http://www.inyopools.com/owners_manual/pentair_heater_minimax_plus.pdf
Make sure that you follow the directions for your particular model of heater.
Jul 05, 2009 | Pentair MINIMAX NT TSI IGNITER
Pentair Minimax NT Heater Logo
337 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
