Question about Troy-Bilt Pony Garden Tiller
Troy-Bilt Pony Tiller runs terrible with blue smoke
I added some motor oil to my tiller and changed the spark plug. there is an oil fill on both sides of the tiller, Is one of these for the trans fluid? I bought this at a yard sale and can't find a engine manual on the net. But it will till for just a little and blow out blue or white smoke and just a few minutes fouled out the new spark plug.
    Scholar:
  • 135 Answers
When you say there is an oil fill on both sides of the tiller. If you are referring to the engine, then yes it does have two oil holes one on each side that requires the use of Briggs & Stratton SAE 30 oil. If you have filled this up until it's ready to overflow, then you have put too much oil in there. It should only be filled to the mark on the dip stick and no higher. If you did put more in to bring it up above the mark, then that would explain the reason for the blue and white smoke. It's trying to run and give you the power and you have given it too much oil to handle and therefore, causes the sump to dump the rest of the oil up the vent tube to the carburetor and in turn it will **** it back in and try to burn it. Hence, the fouling on the plugs. If this is not the case then you have an issue with piston rings or maybe even the cylinder walls. This motor has 3 rings. The top ring and the second ring are compression rings which aid in easier starts. The last ring is the oil ring which keeps oil from getting pass the other two rings. If that ring is worn you'll have to have a complete new set replaced. Also, if you find this to be true, have a dealer check your cylinder for possible out of round. Hope this doesn't scare you. But with all my years fixing these things, most of the problem is related to the customer and their lack of knowledge about the units.
Now if your referring to the gear box which you may be referring to as a transmission. This unit does not take trans fluid. This unit requires a special lube, more like a gear lube. Contact your nearest Briggs dealer and he will be able to inform you exactly as to what you need. Or contact Troy Bilt dealer, that'll even be better.
Good luck. Hope this clearify things for you.
Wayne
Posted on Oct 03, 2009
Testimonial: "Thank you very much"
  • 31 Answers
Need to change the oil and filters there is two place for oil one of cap has dip stick
Troy bilt pony 5hp rear tine tiller is leaking behind muffler on side of motor
Head bolts are probably loose, check the 3 nearest the mouffler and of course check all of them.
May 09, 2011 | Troy-Bilt Pony Garden Tiller
I have an older Troy-Bilt tiller (model & serial # unknown) that when I start it (manual pull) it runs for a second and then shuts off. I checked the spark plug, fuel line and inline filter, fuel, oil...
could be bad coil. does it stay running with choke on? or half on, if so its a gas problem. could be the main jet is plugged in the carb. Or water in the carb bowl. Remove the bowl nut and let some gas run out the put it back in and try it. just guessing as not much info to go on.
Apr 26, 2011 | Troy-Bilt Pony Garden Tiller
The tiller was working fine for about an hour. I let it rest for 15 min, then briefly turned it on its right side work on left wheel. It started right up, but then stalled about a minute later and won't...
Laying your tiller of its right side can fill engine breather with oil and possibly entering your carburator causing engine to smoke and then quite. If this is so change or clean your spark plug. It this is not the case your crankshaft seal may be bad allowing oil to enter your ignition point and condenser cavity causing points to get wet.
Mar 19, 2011 | Troy-Bilt Pony Garden Tiller
What oil used in transmission
Troy-Bilt says that if adding a few ounces only, use GL-4 or GL-5 gear oil. If refilling an empty transmission, use GL-4, with a viscosity of SAE 85W-140 or SAE 140.
Best regards, --W/D--
Mar 08, 2011 | Troy-Bilt Pony Garden Tiller
Troy Bilt Rear tine tiller model 643 Bronco, won't start,it ran out of gas, put in new gas and it started but wouldn't stay running. Put in new spark plugs, cleaned filters, changed out gas,still won't...
did it run out of gas when you added gas it could be that the fuel line has plugged up with something from the bottom of the tank take the fuel line off and try blowing threw it and take a air hose and blow out the carb and carb cleaner
Jun 05, 2010 | Troy-Bilt Pony Garden Tiller
Pony Garden Tiller: does a tiller with a briggs and straton engine nee...
The pony tiller with a Briggs and Stratton engine only uses gas do NOT mix oil with the gas.
Frank
May 18, 2010 | Troy-Bilt Pony Garden Tiller
Old (1981)Troy Prof. 8hp tiller runs 30 sec. and stops.
Clean the carb and if this machine was kept outside all winter make sure no water in tank. I realize you stated that you removed old gas but how it was removed is the key. Try the carb thing first though.
Apr 28, 2010 | Troy-Bilt Pony Garden Tiller
I have 1980's model troy built pony tiller that won't fire
Great machine, I had one. The points need replacement. Look for a gadget that replaces the points. I found mine in PepBoys. Search the Internet, the cost was about $5.00.
May 17, 2009 | Troy-Bilt Pony Garden Tiller
What type oil goes in the tranmission?
Trans oil! 90 or 140 wt.
I use 140 in my older tiller.
G
Feb 10, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Troy-Bilt Pony Garden Tiller Logo
703 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
