Question about Dell Precision M60 Notebook
Screen resolution is locked at lowest setting!
My M60 screen display seems to be locked at the lowest resolution (640 x 480). When I go into Properties>Settings>Screen Resolution to try to change it back, I hit apply but nothing happens. No strange messages appear in the start up, the computer is NOT in safe mode, and nothing I do seems to help.
I don't know if this is the cause of the problem but I had left the computer in the car in some pretty cold cold weather. The screen problem started happening directly after this incident. The warranty for this computer has already passed so any help would be greatly appreciated!
  • 1 more comment
  • conyang Jan 16, 2008
    Hi Karlox,
    I checked the video card driver (NVIDIA Quadro FX Go700) in device manager and it is installed properly.  To double check, I tried to reinstall the driver and windows informed me that it was already the latest version.  So then i went to support.dell.com and downloaded the latest BIOS updgrade.  After installing it, i went back to the desktop to change the resolution.  No go.
    Same thing happens where the screen goes black for a second and looks like it'll change, and the lowest resolution pops back up. Is it possible the cold weather could have killed the video card??
    Please let me know if you have any more suggestions!
    Connie
  • conyang Jan 18, 2008
    Hi Karlox,
    I have two entries under Display:
    1. (Multiple Monitors) on NVIDIA Quadro FX Go700
    2. Default Monitor on NVIDIA Quadro FX Go700
    I actually don't know which Display its suppose to be on, but under #1, the screen resolution is locked at the lowest setting (640 by 480 pixels). I can drag the slider bar to the highest setting, but when i 'Apply' the setting, it reverts back to the lowest. Under Display #2, it is set at the highest resolution (2048 x 1536), but the screen display is still at the lowest resolution.
    Let me know if you need any more info!
    Thanks
    Connie
  • conyang Jan 23, 2008
    Karlox,
    I followed all your instructions, uninstalled the driver, restarted the system, changed the resolution ... and it worked! The screen resolution is back to normal but didn't doing this uninstall the driver for my video card? Should i be reinstalling it? The computer is basically saying right now that it has no video adapter and it can't automatically find a driver to download from the internet.
    Also, the screen (although it's at the right resolution) is stretched out now (everything is a little bit fatter...).  It is liveable, but it'd be great to get it exactly as it was.
    let me know your thoughts!
    Connie
  • 58 Answers
Hi!
you cant change the resolution? did you check the video card driver in device manager? check if the driver is installed properly. if not, then download the latest video driver at support.dell.com > go to drivers and downloads and select your system. If the video driver is okay, then download the latest BIOS upgrade in the same site. post back here if the issue persists.
Hope this helps!
Karlox
Posted on Dec 21, 2007
  • 1 more comment
  • Kristoffer Karl Subang
    Kristoffer Karl Subang Jan 17, 2008
    hi!
    try to go to the desktop right click then go to >properties>settings then check under display, just above the screen resolution part, if you have 1 or more displays listed there. post back anything you see so I can tell what to do next.
    will wait for your reply.
    Thanks,
    Karlox
    Kristoffer Karl Subang Jan 18, 2008
    Hi!
    okay, just let it stay on multiple monitor, click advanced button, click monitor tab, then properties, then driver tab, then uninstall it. Once you're done, restart the system. And that will give you a chance to change the resolution. Revert back here if still won't fix the issue.
    Thanks,
    Karlox
    Kristoffer Karl Subang Jan 24, 2008
    Hi there!
    Im glad you got it fixed. anyway, with he question you have, please check the device manager and check if you have any question mark on video controller. if not, then that's good to go. :) this could be the last step for this issue. Hopefully this is a Fixya.. :)
    Regards,
    Karlox
Laptop screen resolution
when u connect to projector.after connecting change your laptop screen resolution and by setting lowest resolution you will see full screen.
Feb 19, 2012 | InFocus LP530V Video Projector 2000 ANSI...
Frequency out of range
First of all press F8 key several times before window boots and then select last known good configuration otherwise go in safemode and then set the screen resolution to minimum.
Jul 28, 2010 | Gateway 838GM (RB838GM) PC Desktop
When i turn it on it says out of range and i have a black screen
Hi, The reason behind the out of range (frequency of monitor) because the video display adapter is trying to set resolution more than what the monitor (screen) is capable of. In this case, try to boot your computer in Safe Mode using F8 function key while starting your computer. Once you are in safe mode, try to decrease the resolution of monitor to the lowest resolution level and apply the settings. Now try to boot computer in normal mode once again, you will get the settings which you have applied in safe mode. Adjust the screen resolution accordingly till the settings work with the monitor (screen).
Cheers!
Mar 01, 2010 | Microsoft Windows XP Home Edition
My problem is the displayed windows on my monitor/screen
Press the F8 key when windows is booting up from a power off situation, select "safe Mode" you should get a Display then,(NO Video driver(except windows generic) driver is load in safe mode). Set your display to the LOWEST resolution.. Reboot. See if you have a display with the driver set Low. If so, increase the resolution on level at a time until you encounter a problem. If you do not select Yes when windows asks if you want to keep this display setting, Windows will revert back to the last setting you selected yes for.
Apr 12, 2009 | Microsoft Windows 2000 Professional for PC
Computer windows too small.
Possibly your resolution?
Try right clicking on your desktop, selecting properties > settings tab
Click on the screen resolution slider and drag to the left to reduce the resolution. You will be prompted to accept changes within 10 seconds or the settings will revert.
Jan 22, 2009 | Dell Precision M60 Notebook
Windows starts and then the screen goes black
If you have your windows program on cd-rom try putting it in before starting your computer. Then run a virus scan.
Dec 18, 2008 | Computers & Internet
RM computer-
be sure you downloaded the graphic driver for your computer. you can find it from the manufacturer website or if you know the model of your mainboard you can also find it from the mainboard manufacturer website. also, try changing your display settings by right click your desktop and choose properties then choose display adjust the screen resolution on higher pixel. but my best guess is you need the graphic driver of your computer.
Feb 21, 2008 | Ahead Software Nero 6.0 (60045) for PC
How do i connect my laptop
Assuming that the laptop is hooked up to the projection TV using the correct cables or connectors and still no video display on the TV, perhaps you need to lower down the laptops screen resolution first using your laptop's screen display before pressing the Fn + F? key.
To lower the screen resolution, right click on any clear area of your desktop, select Properties. click on the Settings tab, move cursor of Screen resolution to farthest left, Apply, Color Quality to lowest, Apply. Additionally, click on the Advanced button, Monitor tab, select lowest Screen refresh rate.
Hope that this be of some help. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 13, 2007 | Samsung HL-P5063W 50" Rear Projection HDTV
Connecting to PC
Hi Sarah, You may want to try lowering the resolution of your computer down first before connecting the 42PX5D. Since everything seems to be working except when you get to the desktop then your PC might be set to a resultion that's too high for the LG (am not 100% sure, but I think that LG's max res is 1024 X 768). Try to adjust your PC's resolution while still connected to a regular monitor, right click on any free/clear part of your desktop and click properties. Display Properties window will pop-up, click on Settings tab, adjust Screen resolution towards the left,trym lowest posiible, color quality, again lowest possible. Then hook it up to the LG. If desktop now displays in LG, do the same again but this time going up. Do it by increment and stop when LG screen goes blank. Press escape to go to setting prior to blank. Adjust color quality best setting acceptable to the LG. Good luck and hopes this work out for you. Regards.
Apr 14, 2007 | LG 42PX5D 42 in. Plasma HDTV
Resolution
Use the resolution button on the top of the camera by the LCD display. One button is for selecting Flash. One button is for the self-timer. The middle button is for resolution. Press the button repeatedly to cycle through the options. One Star for Basic. Two Stars for Normal. Three Stars for Fine (High Quality). HALF means half the amount of data, perfect for e-mails and screen savers. FULL means full data, perfect for prints.
Sep 15, 2005 | Toshiba PDR-M60 Digital Camera
Dell Precision M60 Notebook Logo
1,077 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
