My Kenwood 5050 volume knob turns but no volume change.
  • samo55 Oct 04, 2009
    What an obvious over site on my part. What is the availbality of parts?
  • 10,865 Answers
Hello. pull the knob off and turn the stem to see if your actual problem is that the knob is worn on the inside.
If the stem makes the volume work properly either order a new knob or do what I usually do...........just get some crazy glue and put a drop or two inside the hole and then slide it onto the stem and let it dry.
Posted on Oct 03, 2009
Kenwood KA 995 amp. volume control, as you increase or decrease the sound, a loud clicking sound is heard.
Katrina, this sounds like a dirty potentiometer (volume control knob). Try turning the unit off, and exercising the knob. That means turn it full turns, many times, like 70 times. Then try it again with power. Sometimes this helps.
Sep 21, 2016 | Kenwood Audio Players & Recorders
Kenwood kr 5050 volume stuck on high cant change
These days the circuit of the volume control is controlled by an IC in modern amps. These can go faulty preventing adjustment of the sound by the volume control. The only cure is to find the IC and replace it. You can start in the area where the volume control is located. If it's not mounted direct on the PC board, follow the connections to the board. Hopefully the board might have writing on it to indicate the area where the faulty IC is.
Aug 04, 2015 | Kenwood Audio Players & Recorders
I have a Kenwood KC 105 preamp and the volume is stuck on high. I turn the volume knob but it does nothing. Any suggestions?
Looks like you are going to have to replace the potentiometer, AKA volume control. It must be shorted out inside (probably) or knob came off the shaft. (doubtful)
Feb 02, 2015 | Kenwood Sc-75 Av Surround Processor...
How do I set clock on dpx308u
See pic below for reference. Press SRC button 4x to get to standby mode. Press "Boost," for 2 secs. Use volume knob to change hour. Press volume knob when hour is reached. Turn volume knob to set minutes. Press volume to set time. All done. Press SRC button again to go back to your tuner, or CD, or whatever.
Mar 08, 2012 | Kenwood Car Audio & Video
Kenwood kr-v6030 master volume wont go down
To zyclon3, I've got a KR-V6030 that the volume knob some how got broke and had to take the receiver apart and get the knob out and play with it with the remote untill I got control. but I have to becareful cause it will go full blast if I'm not carefull going down in volume have to be especialy carefull since theres no stop.
Mar 08, 2010 | Kenwood Audio Players & Recorders
How do you switch speakers to rear of vehicle from front of car. I have a Kenwood kdc mp 4029
Hello my friend, Ok you can do one of two things, you can try this link, http://manual.kenwood.com/files/B64-2928-00_En.pdf
or you can email me and i can send you the pdf user manual. butcher960@btinternet.com
By what i have found is if you turn on the unit and press the volume button until you come to Fader, you then turn the volume knob left or right to change the sound from front to back, Colin.
Jan 26, 2010 | Car Audio & Video
Master volume on Kenwood not working - knob turns but no effect on volume
is the outer of the knob actually turning the post inside the pot. if it is then maybe replace the potentiometer if it isnt, find a way of securing it on
Oct 15, 2009 | Audio Players & Recorders
How do i set the clock on my kenwood kdc-x492
you need to put the headunit in to STANDBY MODE then press he little DISP button to the bottom left of the volume knob. press it for a few seconds. then it will bring up a menu. hit the volume knob down a few times til you see clock set. then PRESS AND HOLD THE VOLUME KNOB IN THE CENTER then it will blink. press the volume knob up or down for hour i believe and left and right for minutes. Once thats done hit the src button again and its done!
Aug 21, 2008 | Kenwood Car Audio & Video
How do i turn off the "loud" option
hold down the volume knob then hpf will come up then press control knob till you get to loud setting and spin knob it will change to off
Apr 07, 2008 | Kenwood KDC-X589 CD Player
Volume
If the volume control does nothing them spraying it will do nothing. If it is noisy when you turn it but the volume does change them you can try to spray it with cleaner. You cannot do this from the front; only from the inside and only if the volume control is not sealed.
Aug 28, 2007 | Kenwood VR-407 Receiver
 Grubhead
Grubhead
