Question about Minolta magicolor 2400W Laser Printer
Service call 18H - Minolta magicolor 2400W Laser Printer
    Problem Solver:
  • 5 Answers
It´s a problem with the fixunit.
I read it on another site.
I have sometimes the same problem, but I just open the blue top of the printer, close it and after an restart, the 2400W is working fine again.
Posted on Dec 13, 2009
What is18h code on gltf2940es0?
Thank you for your post, Jeff Duvall!
I see that your Frigidaire washer is displaying an error code of "18h". However, it appears "18h" is an invalid error code. In order to clear any false error codes, let's attempt resetting your range. You can do this by unplugging it or flipping the household circuit breaker to the off position for approximately ten minutes.
If resetting the power does not correct the issue, could you please inform me of the new error code or if your washer continues to display "18h". I look forward to assisting you. -Matt
Nov 09, 2014 | Frigidaire Washing Machines
What does error code 18h mean
Hey friend, thank you for the post!
I see you are getting an 18h code on your front load washer. Normally any error code would have the letter E or F in it. I would suggest that stands for 18 hour delay start cycle, you could do a reset on your washer by disconnecting power to it or turning off the household circuit breaker for ten minutes and turning it back on. Hope this information is helpful. -Matt
Jul 21, 2014 | Frigidaire GLTF2940ES Front Load Washer
My machine gives me error code 18h wont do anything
Are you sure it is an 18h? There is no such error code for this manufacturer anywhere. What cycle was it in and what was it doing/not doing when this happened?
Sep 04, 2012 | Frigidaire Affinity ATF7000E Front Load...
My didgital frame will not turn on. ADS-18H-4 0918G
My didgital fram will not turn on. ADS-18H-4 0918G switching adapter does have a slowly pulsing green light. But will not turn on the picture frame. Where can I get a replacement or how do i get it to work
Mar 22, 2010 | SmartParts SP15MW (092566981886) Digital...
Where to buy a ads-18h-12-4 1218g power supply
Ebay seems as good as any ....
http://cgi.ebay.com/ADS-18H-12-AC-Adapter-9v-2A_W0QQitemZ250532141467QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3a54e1199b
Satisfy yourself its the right thing before purchasing (The SKU matches, but that doesn't necessarily mean.....)
Hope this helps
Mar 06, 2010 | SmartParts SP15MW (092566981886) Digital...
My Ford YT-18H model tractor will not accelerate when either in forward or reverse gears. It moves slowly but not with enough power to climb even a snall incline. Could it be a transmission problem, or a...
I need a belt diagram for a Ford Riding mower, Model YT 18H. A diagram for the tractor belts would be greatly appreciated.
bilp07@yahoo.com
Oct 20, 2009 | Ford Garden
Konica minolta 2490mf
18H: Heating roller warm-up failure
1 Check the fusing unit for correct installation (whether it is secured in position).
2 Check the fusing unit, DCPU1, and PRCB for proper connection and correct as necessary.
3 Check the lever of the safety switch and correct as necessary.
4 Change the fusing unit.
5 Change PRCB.
6 Change DCPU1.
Jun 22, 2009 | Konica Minolta magicolor 2490MF Laser...
1996 Ford Crown Victoria Shifting
when was the last time you had the fluid and filter changed? This trans should be done every 30,000. Is it shuddering as the torque converter locks up?
TSB 97-10-6 has a repair procedure for this ysmptom:
Vehicles equipped with an AODE or 4R70W transmission may experience a torque converter clutch shudder or vibration. This occurs under light to moderate acceleration above 56 km/h (35 mph) while in 3rd or 4th gear. This may be due to either transmission fluid breakdown and/or the Powertrain Control Module (PCM) calibration.
Verify that bulk fluid does not have moisture contamination. If suspected, use quart containers of MERCON®. Refill transmission with the proper amount of Motorcraft MERCON® Multi-Purpose Automatic Transmission Fluid (ATF) (XT-2-QDX).
NOTE: DO NOT USE MERCON® V.
Check emissions decal to verify vehicle has the latest calibration. If it does not, reprogram the PCM to new calibration level using Service Bay Diagnostic System (SBDS) or New Generation Star (NGS) Tester with May 1997 CD-ROM or later. Refer to the PCM Calibration Chart found at the end of this article for proper application.
NOTE: VEHICLES SHOULD BE DRIVEN A MINIMUM OF 480 km (300 MILES) TO WORK THE NEW FLUID INTO FRICTION MATERIAL.
PCM CALIBRATION CHART Application Old Calibration Old Part Number (-12A650-) New Calibration New Part Number (-12A650-) 1996 Crown Victoria/Grand Marquis 49S/Canada/High Altitude 6-18F-R05/R11 F6AF-AE 6-18F-R11 F6PZ-DJA 49S/Canada/High Altitude 6-18H-R05/R11 F6AF-BE 6-18H-R11 F6PZ-DKA Mexico 6-18H-R05/R11 F6AF-KE 6-18H-R11 F6PZ-DMA Police 6-18I-R05/R12 F6AF-CF 6-18I-R12 F6PZ-DLA California 6-18M-R05/R11 F6AF-DE 6-18M-R11 F6PZ-DNA California 6-18N-R05/R11 F6AF-EE 6-18N-R11 F6PZ-DPA
Mar 02, 2009 | 1996 Ford Crown Victoria
ERROR CODE 18H
18h is not an error code error codes will be displayed be an E followed by numbers this sounds like delayed start try hitting cancel then if that don't clear it try unplugging the unit for 5-8 seconds let me know if that don't clear it and we will run diagnostics on it
May 22, 2008 | Frigidaire ATF6000ES Front Load Washer
Minolta magicolor 2400W Laser Printer Logo
252 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
