Question about Musso Stainless Steel Pola Ice Cream Maker
I have the DAK Gellatissimo machine with Broken Belt as well
I have the broken belt as well.
If anyone knows where to get one, I would appreciate it. Everything still works great... but I need the belt to fix it so that the blades turn to mix the icecream as it freezes.
I live in the Orlando, FL area. USA.
I live in Orlando also and now need a new reservoir where the ice cream freezes. A neighbor put a knife through the side of it trying to get the ice cream out. DUH Are these available locally ??
Posted on Oct 07, 2011
  • 3 Answers
The following Gates belt will work. Its called Poly power chain belt which is metric and just under 12 inches with 60 teeth. Just Google the number and you will find several suppliers online. Costs around $24 which is cheap to fix such a great machine.
Product # 5MGT-300-09
Posted on Mar 06, 2010
Simac il Gelataio Magnum repair: what kind of grease to use?
The grease is most likely a lithium based grease. If there is absolutely no chance of it coming in contact with the product. If there is a chance it contacts the food then it has to be a food based grease. Never lube a belt! The reason that you are not supposed to lay the unit flat is because the cooling systems have oil in the coils along with the refrigerant. When laying it down, the oil can move into the expansion tube and cause it to plug up and make the compressor fail. You can lay it down, just don't start it for 24 hours after you stand it back up. This allows the oil to drain back down.
Jan 02, 2017 | Ice Cream Makers
My musso ice cream maker is making a knocking sound when on. Once ice cream starts to freeze it can't turn it any more. Loose belt? How do I fix or take apart? Thank you!
I would look at the motor itself. You will have to remove the cover and see what is happening. What I would be looking for is a loose motor mount or a missing/broken off mounting bolt.
Feb 20, 2015 | Musso Ice Cream Makers
Simac Sorbetiere Gelataio 1600. with broken plastic part.
Hi Kendy,
my Simac 1600 just broke yesterday. So if you like I can send you this plastic piece. But my mashine has a plastic blade and so I don´t know exactly what you need. Can you send me a picture. olaf.drauschke@gmx.de
Jul 07, 2009 | Ice Cream Makers
Taylor Icecream Machine Model# y754-27
Try slowing down the rate at which you are drawing the product from the machine,and giving it a minute or two between draws. If you take to much out to fast it starves the barrel and will cause it to freeze up,and that will make the belts squeal.
Dec 11, 2008 | Taylor 632-27 Ice Cream Maker
Blade stops turning but motor still running
Hi Lew 2!
Sounds like the belt might be slipping prematurely. I'd try cleaning the belt and all the pulleys with an alcohol based solvent or rubbing alcohol (clear) to remove any excess oils that might cause slippage and see if that helps Is there any type of belt tension adjustment? If so, also try tightening the belt.. If the problem persists, you probably need to replace the belt.
If this helps, after the churning stops, remove the paddles and cover the top with plastic wrap or wax paper and allow the mixture to "firm up" in the ice bucket nother 10-15 mnutes, and then enjoy a great old-fashioned treat!
Hope this is a help, let us know how it goes, and good luck!
-WB
Jun 14, 2008 | Simac Ice Cream Makers
Dak gelatisimo machine broken gears
I just helped a problem similar. It is possible to get a repair man and fix it. Get a hold of a repairman at www.repairman.org. I do not know the number but i'm shore it is on that website.
Nov 25, 2007 | Musso Stainless Steel Pola Ice Cream Maker
Repair
Nov 05, 2007 | Musso Stainless Steel Pola Ice Cream Maker
Musso gelato maker where can i buy parts
go to Http://www.catering-machines.com they have full list of spares or parts for Musso stella.
All parts for the musso ice cream machine including lid, motors, gear wheels, gearbox, musso paddle Musso serial numbers start L1 = Musso piccolo L2 = Musso stella L3 = Musso Club L4 = MUSSO CONSUL.
Oct 31, 2007 | Musso Stainless Steel Pola Ice Cream Maker
Musso Stainless Steel Pola Ice Cream Maker Logo
190 people viewed this question
Top Musso Ice Cream Makers Experts
ray gallant
Are you a Musso Ice Cream Maker Expert? Answer questions, earn points and help others
