Question about Delta X5 3Hp Left Titl Unisaw with Unifence
I recently (8 days ago) changed the starter on my Unisaw. A couple of the wires from the plug on the origional starter were loose, and the saw would kick off as soon as I turned it on. Now my saw has done the same thing. I went to turn it on, it started, kicked off, and it won't start again. The replacement starter was installed per included instructions. There is nothing obviously wrong with the starter, and I checked the motor with a multitester, and could find nothing wrong. Any ideas?
    Problem Solver:
  • 9 Answers
What is the rating of the starter overloads. A more basic question, are they adjustable or the heater type? It sounds like the starter overloads are taking you out. Check the full load amps of the motor you are using against the overload rating. Add 10% to this and set overloads at ths setpoint if adjustable. If heater equipped buy new heaters rated for motor load. Make sure to use the 1 phase rating and not the 3 phase. That is if you are using a 3 phase starter.
Posted on Apr 04, 2010
Delta 3 hp x5 unisaw. The on button when pressed will start up the saw but will stop once you stop pressing it. Sometimes I can slap the side of the switch box and it will allow the saw to run
Now here is a saw worth repairing! The switch should be replaced. IIRC it is a magnetic switch. Replacement is the safest way to resolve your problem. It will be a 'wire for wire' type of job. I mean it is simple, but do one wire at a time. These days, you can take good photos of the old switch in order to have reference to the wiring. Highly recommended.
Jan 18, 2018 | Delta Saws
Unisaw single phase 3hp magnetic starter keeps blowing actuator coil
Should check the voltage on the coil if its a 220 volt saw could have a 120 volt coil
Nov 07, 2013 | Delta NHD STARTER SWITCH ASSY. FOR UNISAW...
My 1999 Ford Contour SE wont start
It's possible that the defective plugs blew out the Ignition Control Module. Are you getting any spark from the plugs? Try removing one of the plug leads, hold it about 1/4" from a metal surface, and have someone crank the engine. You should see a strong spark. If not, then I'd replace the ICM and see what happens.
Sep 25, 2012 | 1999 Ford Contour
Delta x5 unisaw 3 hp. couple days ago it was running strong never had a problem before. push start motor tries hard to spin but nothing besides a hot motor barely touch it hot. 10 min later saw starts...
The motor has a component called a clixon (there are other names for it, too). The clixon has a step up coil and a capacitor that gives the motor an extra bit of juice to get started turning. When it fails, you get the kind of thing you're talking about. If you keep trying to use it without this component working, it overheats the windings and shorts the motor out, killing it. You're most likely going to end up replacing the motor now.
Sorry I didn't have better news for you.
Jul 09, 2011 | Delta X5 3Hp Left Titl Unisaw with...
Delta unisaw W/LVC
I think this is what you're looking for:
http://media.ptg-online.com/media/dm/OwnersManuals/20040331153155_En438-01-655-0002-04-01-04.pdf
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Mar 29, 2009 | Delta Machinery 3 HP Left Tilt Unisaw with...
Need owner's manual for used Unisaw 36-812
You can download one from the Dewalt service center. Click on this link and choose the saw that most closely matches your own:
http://www.dewaltservicenet.com/Products/ProductManual.aspx?q=36-812
If you found this link to be helpful, please rate this response so I can become a trusted advisor. Enjoy your new saw!
Mar 21, 2009 | Delta Saws
Car overheat frequently and at time the engine sound is very loud
Several things can cause this overheating. Have you recently done a:
1. Check Hoses for Leaks
2. Check Radiator for Leaks --- Also, Change Radiator Cap ( can loose pressure there if
cap is bad)
3. Check Water Pump for Leaks. If Water Pump is bad, you will hear a loud noise from it
4 Complete Tune Up? Should be done at least 1x a Yr. Depending on how much you drive the Vehicle. Includes: Plugs, Plug Wires, Gas Filter, Air Breather Filter, PCV Valve, Adjust Timing,
Check Belts -- see if worn
5. Changed your Thermostat & Gasket and have the correct degree Thermostat in the Vehicle?
6.. Had your Radiator Rod and Cleaned out?
7. Temperture Sending Unit (located near Thermostat) could be bad
8. 02-Sensor (Generally located in the Exhaust Manifold - needs a socket with a space in it
to allow the Socket to fit over this top wire of the 0-2 Sensor )
9. Change oil and oil Filter.
10. Change Gas Tank Cap ---
Do all this yearly ( except the Radiator Rod & Clean ( do every 2-3 yrs), and you should not have
any over-heating nor stalling out, etc. and should pass emissions as well.
Nov 25, 2008 | Hyundai Elantra Cars & Trucks
Delta X5 3Hp Left Titl Unisaw with Unifence Logo
181 people viewed this question
Top Delta Saws Experts
Jim London
Jim London
Craig Butler
Craig Butler
Are you a Delta Saw Expert? Answer questions, earn points and help others
