Question about Car Audio & Video
Cd changer says magazine empty when its loaded. why and how can it be fixed?
    Genius:
  • 1,112 Answers
Hello there is a cartridge sense swith, in this unit that senses when the magazine is inserted to ejected. This swith may need to be replaced or cleaned on the cartridge housing.. Also do you hear the cartridge engauge the system and the disc select motor operation if not then you may have a timing problem in the loading mechanism..
Posted on Oct 03, 2009
4 Suggested Answers
ohms
  • 1879 Answers
SOURCE: Remove CD Magazine - No power to unit!
u need to re-connect it in order to remove the magazine
Posted on Jun 15, 2008
Eagleeyes
  • 199 Answers
there is a small fuse on the uni-link socked pcb inside the unit, it looks like a transistor but only has two legs.
mark
www.blueice-electronics.co.uk
Posted on Nov 04, 2008
dj_relly999
  • 4070 Answers
SOURCE: cd changer magazine does not eject
good day, you may want to do it manually if its jammed, you may find a pinhole on it and u can use a paperclip, insert it in the hole and it will open. hopefully it wont jam again. hope this helps, have a nice day
Posted on Feb 10, 2010
I have a MB GL 450, 2008. It has a problem with CD Changer, it loaded 6 CDs before and worked great. But display start to show that "CD is being loaded" from yesterday. No lights that indicates...
If you have a magazine-type CD changer there may be a CD jammed in transit between the magazine and the player mechanism. Disassembly may be required to find and fix the problem.
Feb 20, 2014 | Mercedes-Benz Cars & Trucks
Mercedes cd changer stuck
There may be a CD that did not completely return to its slot in the magazine, for example if power was turned off before the return was completed. Don't know how to fix it. You might power up and try a load-unload cycle to get back to normal.
Sep 12, 2012 | Blaupunkt IDC-A09 5-Disc CD Changer
My cd changer in my 2000 ford expedition will not load cds' and reads empty magazine when it is loaded.
Take it in for service, the sensor is either dirty or faulty. Your sensor that sees if the magazine is in has gone bad
Jul 14, 2011 | 2000 Ford Expedition
I have a Bose 6 cd changer, when i load my cds its telling me the magazine is empty
are you sure you are putting the cds in the trays correctly? you may also have a dirty lens or possibly a bad laser assembly. there are also a few other problems that could cause this symptom.
Dec 08, 2010 | Car Audio & Video
My original problem WAS that the magazine wouldn't eject which i'm told is due to a weak or dirty belt or gearing. I have a temporary solutuion for this (which is to undo the top of the frame INSIDE the...
there are small drive belts that provide the power to operate the different parts to eject the CD magazine, i suggest you remove the covers and check these belts for slack/strech, it is a common reason for this problem
Jan 28, 2010 | Alpine CHA-1214 12-Disc CD Changer
The magazine wouldn't eject which i'm told is due to a weak or dirty belt or gearing. I have a temporary solutuion for this (which is to undo the top of the frame inside the caring which releases the...
Hi
Open top cover, if the empty magazine was left inside the cd trays it can slide out into the playing area and jam the unit, check it like that anyhow. Sometimes you can see a small metal tab to release the magazine.
However Error1 means Battery inside CD Changer needs to be replaced.
And NO CD.CD error message means No CD in magazine or no magazine in CD Changer.
To fix the problem, disconnect the CD changer.
take off the top plastic slide cover,
with a small screwdriver slowly move the gearing so that the CD disc holder will move back to the load - unload position.
Pop out the CD holder.
Replace unit, reconnect the optic and power lead, switch on radio and the unit will work again.
grease the moving parts with light lubricant.
Thanks for contacting fixya.com
My eurovox radio/cd/tape player displays error message E-99 when i switch to cd
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
Oct 03, 2009 | Car Audio & Video
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds.
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 21, 2009 | iLO CA3000V CD Player
CD ERROR DISPLAYS
CD Changers
E01:
E02:
E04:
upside down
WAIT:
Jun 14, 2009 | iLO CA3000V CD Player
Car Audio & Video Logo
233 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
