Does it fill with water to the correct level? The water pressure switch lets the machine fill to a certain level and the stops the water coming in, then the control board should start the agitation.
use the features fuzzy logic, u only need to power on and start on the machine when u hve fill in the tub with cloths and soap. water will fill in according to the load filled.
When loading the machine, load towels, sheets or jeans with an accordion fold instead of putting the laundry in a circle around the agitator. It helps to put the clothes in at the twelve o'clock position, then six o'clock, then nine o'clock and then three o'clock. Repeat this sequence until the washer is full.
The laundry can circulate much better and get cleaner too.
Sounds like the timer is screwed... Sending out the wrong signals and the dryer is doing the rinse cycle when it should just be the spin cycle. Do t know what your timer looks like in that washer but most now days look like the picture.
most top loaders fill to the setting you enter into the program l( medium low high etc ) as the clothes absorb the water it will keep filling until a level is reached at which point that is the amount of water for the clothes and the machine will start you just have to think about how many clothes you are washing and how big they are ie blanket will be a big load and nickers will be small load
if you are saying that the washer finishes the load of clothes and timer goes to off and water is filling the tub after this then you have a bad water valve on the back of the washer.disconnect the water lines and change out the valve
Normally I would think that the problem is with the drain system (faulty pump or clogged lines), but you told me that also "When the washing machine is not bein.g used the drum slowly starts to fill with water!!" therefor I think it can be a dafective inlet valve or a faulty control assembly. In either case, you will need a technician to fix this.
