Question about Harley Davidson 426290 AM/FM Radio
2003 classic raido goes off when warm won't go back on. weeks later radio works again. going on another trip i would like to have tuns the whole time
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • Harley Davidson Expert
  • 281 Answers
Internal amp is breaking down, needs to be replaced
Posted on Mar 25, 2010
Battery light comes on and off then kills my car
might be due to the battery being bad and may need replacement but if the battery is holding a charge then it might be due to a short out in some place
Mar 14, 2017 | 1990 Subaru Legacy
I have a bran new Admiral dyer that won't work
The dryer may have been wired incorrectly, e.g., 115v rather than 230v.
May 23, 2017 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
I recently won an E10 in an auction. I did not receive any paper work or anything with it, so I don't know a whole lot about this little camera. But what I do know is that when I turn it on, it go
There are other complaints all over the internet about this cameras' battery life. Are you using NiMH batteries or alkaline? If you used 8 you must be using alkaline. If they are heavy duty regular batteries you are using the wrong kind of battery. NiMh hold more power and last longer with a flatter power curve up till they are about done. Recahrging means not buying lots of batteries too. They should last for a long, long time; like a week or two at least. The manual and quick guide can be downloaded in PDF from http://www.ricoh-imaging.co.uk/en/Photo-Downloads.html
Jul 22, 2012 | Pentax Optio E10 Digital Camera
Wipers quit working. Dealer replaced wiring harness. Now my cruise control, radio and headlights won't work unless headlight dimmer switch is held in the whole time.
Don't know why you would ever be at a dealer for anything
Now you have to go back
Now you see why I say that
You get the car back,all kinds of things
that worked for years, now do not,so why go there
Jun 13, 2011 | 2003 Mercury Grand Marquis
My 2000 expedition will not start just clicks under dash but doesnt always first time it happened suddenly came home from store turned motor off got back in 10 mins later just clicked sat for a day or two...
This is a classic sign of a bad starter. When a starter is on its way out, it will usually start when cold. Once it heats up after a short trip or 2, it takes more and more power to get the starter to turn. If the truck will start with a jump when warm, you've confirmed that you have a bad starter.
Apr 27, 2011 | 2000 Ford Expedition
Replaced factory radio one week ago with
sounds like its wired up wrong, remove the radio unplug the connector and remove the radio, then check all your fuses must have blown one when radio was installed, after that charge battery and with radio removed see if battery goes dead, if not recheck wiring to radio, common problem with vw aftermarket radio,they are installed wrong,good luck,
Nov 16, 2009 | 2003 Volkswagen New Beetle Convertible
JCM2000 DSL100 No Sound
Not likely to be a fuse. The bane of electrical amps are the connectors.
Often the speaker and more commonly the input 1/4 inch connectors go bad. Sometimes caused by side loads when cables are yanked or tripped over.
Be careful of running amps IF the speakers are not connected OR have bad connectors or cables. You can arc over the tubes or pop transistors.
Get a cheap Volt-ohmeter from HarborFreight or Radio Shack and test your cables and connectors.
For a tube amp, your should find relatively low resistance at the speaker connector (certainly under 20 ohms). Do this with power off.
Sep 09, 2009 | Marshall Music
Cobra 29 LTD classic when turned on it shuts off
Well I hope you didn't clip D12. D11 makes sense to me. If you clip that you are disabling the AMC, automatic modulation circuit. This will allow the radio to modulate at full modulation all the time, which isn't always good. You can over driver your final and possibly blow it.
Most of the time you can just turn up VR4. thats the AMC adjustment. It will raise your modulation to the max but will not over modulate it.
You probably blew the final and or more components as well. Your going to have to take it to a radio tech. This is no simple fix.
Jan 26, 2009 | Cobra 29 LTD CB Radio
New Mastercylinder/brakes still lose pressure
ITS THE MASTER CYLINDER AGAIN.More than likely they are using a re manufactured master cylinders. Get a new one from MOPAR-(CHRYSLER) that will take care of your problem. Trust me I have had the same problem with a similar vehicle in the past in my shop. Good Luck, thank for using FIX YA
Jan 16, 2009 | 2003 Chrysler Town & Country
2003 Alero Dies after faulty turn signals on for a week
is the battery charging? the indicator control could need replacing .joe
Nov 17, 2008 | 2003 Oldsmobile Alero
Harley Davidson 426290 AM/FM Radio Logo
Top Harley Davidson Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Harley Davidson Audio Player and Recorder Expert? Answer questions, earn points and help others
