Question about Maytag MGS5870 Gas Kitchen Range
NoT A GOOD SEAL ON THE DOORS
RECEIVE SLIDE IN RANGE YESTERDAY, THE LIGHT IN THE OVEN WAS ON AS SOON AS THE RANGE WAS PLUGGED IN.
WE TESTED IR
    President:
  • 1,304 Answers
Check the light switch itself
check the door switch
Posted on Oct 03, 2009
Testimonial: "Thanks, i figured it out when i went to lock the oven and it would just show DOOR and would not lock. we waited 3wks for the stove to be delivered"
HGS7152UC bosch oven door won't seal
Oven doors are designed to have some movement in and out to accommodate sealing against the gasket. If you're not getting a good seal check the condition of the gasket. If it's hard and inflexible you'll need to replace it.
About 5-6 years of normal use can make these hard and inflexible.
I just looked and Bosch calls this the 'Door Seal' pn 1052639
Jul 30, 2012 | Bosch HGS442UC Gas Kitchen Range
We have a Lofra dual fuel cooker 5 years old which needs a new rubber door seal on the gas oven but cannot find anywhere to obtain this part. Can you help? Pip Bedford
Hi I also had difficulty in obtaining a Lofra oven door seal but after searching and searching the internet I obtained an email address and now the problem has been solved. I received my oven door seal from the Italian Lofra company direct this morning. I dealt with a lady named Donatella and I found her very helpful. She can be contacted on donatella.talpo@lofra.it just give her the make of your cooker and she will let you know if she has one mine cost around £14. Good luck Suzie :)
May 03, 2011 | Lofra MXGC96AMF/CV Dual Fuel (Electric and...
Oven door will not close completely.
Make sure the seal is not stiff. It should be flexible so it gives when you shut the door.
If it looks good, you need new hinges and receivers.
Nov 19, 2010 | Tappan Kitchen Range
How do I test a microwave for 'leakage'?... Does calling to a cell phone placed inside a closed microwave indicate 'leakage' if the cell phone rings/receives the call? Thank you
The "cell phone" test is a fraud. Cell phones operate on a frequency range much lower than microwaves (800 MHz for phones and 2.5 GHz for the ovens), and the metal screen in the microwave door won't affect them. The phone will ring loud and clear and it doesn't mean the oven is leaking microwaves.
You can buy a "microwave leakage test card" at some stores that supposedly change color when you hold in front of the door if the oven is leaking microwaves. This is also a fake. It actually responds to heat, on the thory that if heat is escaping around the door then microwaves are too. That's wrong.
The only sure way to test for microwave leakage is with a standardized leakage test meter. This is a fairly expensive electronic device. You really don't need to worry about microwave leakage unless the door of the oven is visibly out of alignment so that it isn't closing and sealing properly. If the door hasn't been getting slammed shut and the oven hasn't been dropped, everything should be fine. Take the oven to a service shop for a leakage test if you are concerned.
One final note: Microwave energy drops off rapidly with distance. Just don't stand right in front of the oven while it's running.
Hope this helps ease your mind. Thanks for using Fixya!
Feb 02, 2010 | Microwave Ovens
The oven door locks and lock light comes on. It
Flashing F1 clearly indicates a problem in the electronic control, its keypad (which may only be available with the control) or sometimes even the oven sensor.
The first thing you can try is disconnecting the appliance from power for several minutes to see if that clears the problem. If not, some investigating will likely be necessary. However, a defective oven temperature sensor can also sometimes trigger the same F-1 error to display. It is also not inconceivable that an improperly grounded or polarized power supply to the range could also cause intermittent failures of the electronic control. Checking the power supply should usually be done as a matter of course during testing.
Unfortunately, it will likely be difficult to pinpoint the exact cause unless the range can be tested *at the time of failure*. Otherwise just replacing the possible suspect components may need to be done to see if they correct the condition.
Sep 01, 2009 | Kitchen Ranges
Oven won't broil
You probably have a bad broil ignitor. When you turn the oven onb to broil the ignitor on the top of the oven should glow bright orange. If it doesn't glow or glows a dull orange, it is probably bad.
Apr 08, 2009 | GE 30 in. Gas Self Clean Slide-In Range...
Microwave starts after plug-in cannot be stopped by control panel
This seems like a problem with with the door latch circuitry HW. If the unit is still in warranty, call GE customer care. If not, your neighbor will need to buy a new oven. Service on microwave ovens is not cost effective because the replacements are so reasonable and have so many new features.
I have a lot of experience with these units. If the door latch circuitry is in question you may be exposed to dangerous microwave energy. Hope this helps...
Ray
Nov 20, 2008 | GE Microwave Ovens
Self cleaning oven
Could be a malfunction in the lock mechanism, But if this is a newer oven or first time cleaning, the oven door seal may be holding the door out just far enough to keep the lock mechanism from engaging.
Try pushing in a bit on the top of the door to compress the seal a bit and then try setting it to lock while holding pressure on the top of the door. If this works remember you may need to press in on it again to get it to unlock after it cools.
Also check that the lock lever actually springs out to grab the door and that the hole in the door is aligned properly to receive the lock lever. I would think that you could test this with the oven door open.
Sep 10, 2008 | Whirlpool GR478LXP Electric Kitchen Range
Oven light won't turn off
It sounds to me like the switch that operates the light is malfunctioning. You're taking the right steps by pressing the switch by hand. Since that didn't work, either that switch is not working or there is another switch that is intended to keep the light on while the door is closed. You can look at that one too. The last thing to consider is if the light is relay controlled, the relay might be stuck closed and applying power to the light all the time.
Mar 09, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Maytag MGS5870 Gas Kitchen Range Logo
109 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
