Question about Mitsubishi VS-60607 TV
I have a Mitsubishi VS-60607 that when turned on has a flourecent green colored screen. I can hear the audio, but the picture doens't show up, just green. The TV then turns itself off after approx 20 sec. Is this a bad color gun? The set is from 2000, can I even get replacement guns for it?
  • Mitsubishi Master
  • 8,457 Answers
Tv Repair World.com,Shopjimmy.com,Partstore.com or Ebay.com for colors guns.
Posted on Oct 03, 2009
VS-60607 turns on then off
2,1 is X-ray protection or excessive High voltage
It is a circuit repair or may be related to a Glycol leak
Mar 13, 2012 | Mitsubishi VS-60607 TV
Screen role red and green wavie lines.
Hello dctc1,
Looks like there is a problem with the convergence IC's. You will have to replace both of them. I would also look for busted capacitors around the IC's.
However, if you are not familiar with TV repairs, I would advise against opening up the set. Best get a service man to come and diagnose/repair the set.
Hope that helps!
Please dont forget to rate or "Accept" the solution if it helped you in any way, or leas you to a fix.
Thank you for using FixYa!
IrishDruid
May 18, 2008 | Mitsubishi VS-60607 TV
I thought i might need a lamp for my mitsubishi tv--model VS 60607 when my tv is fuzzy when turned on.should i simply replace the lamp or is there something else i should try? thank you!
This TV is a rear projection television and does not have a lamp. It has three CRT color guns (Red, Blue, and Green). You have a convergence issue (the red, blue and green color guns aren't aligned properly) and it doesn't sound like a very big one. You should be able to adjust this through the CONVERGENCE Menu in ADVANCED SETTINGS.
More details can be found in your manual, here. The model number isn't exactly the same but I'm sure the process is identical or really close. The other option would be a bad IC (integrated circuit) for the convergence control. This is unlikely unless your picture looks something like this: captainhawk1_15.jpg
May 29, 2011 | Mitsubishi VS-60607 TV
Mitsubishi vs-60607 60" screen is
when picture is getting smaller in size or goes away or moves towards one side then hit your TV lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board at some soldering joints crack develops....then due to loose contact picture becomes small in size or disappears ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some time............so solution is ......TV main board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer
Apr 22, 2011 | Mitsubishi VS-60607 TV
Tv turns on .but as soon as it feels a vibration it distorts the picture
Hi ,If you are experimenting hues,color distortion ,black and white picture,feel vibrations, it could be time to replace the color wheel.You can find it at discount-merchant.com
Apr 22, 2010 | Mitsubishi VS-60607 TV
My picture is wavy, I have a mitubishi big screen model # vs-60607
sounds almost like bad caps okay this is where i would start is thier an option on the set to alighn convergence try that also okay may be bad module also okay its worth fixxing okay call tv shop
May 17, 2009 | Mitsubishi VS-60607 TV
Mitsubishi convergence Problem
You only have 3 colors Red, Blue, and Green. No black or yellow. I would say look for self test diagnosic on here or other sites.
Jan 13, 2008 | Mitsubishi VS-60607 TV
Picture goes out after a few hours.
coul'be overheat solder the cause of a loose connection , and or convergence ic 's almost ready to fail . the cost to repair will be around 250.00 to fix replacing the ic's depending of the tech. or 350.00 at repair shop if you may have more question , let me know Im here to help you. thanks
Jun 12, 2007 | Mitsubishi VS-60607 TV
Black screen with green smiley face
If your tv has a picture tube,your problem is in it. If you have only one line now,the vertical circuit is not working. You could have jarred something loose around the picture tube.Maybe a yoke lead ???
Jan 13, 2007 | Mitsubishi VS-60607 TV
Mitsubishi VS-60607 TV Logo
251 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
