Question about Ovens
I have a ce351000aw crosley range that seems to always stay on low. The temperature has been off by about 30-40 degrees for quite some time but as of late it constantly cycles on a very low temperature.
  • 725 Answers
This is a simple repair. You need a new thermostat. If you will give us a call at 972-859-0929, we'll get the right part out to you asap so you can start using your oven the proper way. We look forward to hearing form you soon. We answer our phones from 7AM - 9PM CST, so call us right away! We hope this helps you!
Posted on Oct 05, 2009
My oven does not heat to the correct temperature. If I set it for 325 degrees it will heat to 390 or so degrees. It always seems to be about 70 degrees too high. Accross all ranges of temperatures from...
The thermostat is the cause of the problem, normally the the only cure is to replace the oven thermostat,completely, or alternatively, compensate by setting a lower temperature when cooking.
this will work o/k if it is always the same variation in temperature across the range .
Dec 25, 2010 | Electrolux 30" Built-In Single Electric...
Kenmore Electric Double Oven Mod 9114832592992 got F2 code in middle of selfclean what do I need to fix?
Hi, i found three all same series... If it's occasional I'd leave it 'till was always on? Anyway .....
F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC)
OR....
F2 Oven temperature sensor shorted Replace oven temperature sensor
OR
F2 Temperature runaway detected (Bake/Broil: 600 - 700 F; Clean: 930 - 1000 degrees F). Sounds alarm and resets to non-cook mode. Check relay board for stuck contacts. Check oven temperature sensor for normal room temperature resistance (1085-1097 ohms at 75 degrees F). Check sensor wiring connectors for a loose or high resistance connection. Check electronic range control (also called clock or ERC) functions Replace relay board if necessary. Replace oven temperature sensor if other components check normal. If failure repeats, replace electronic range control (also called clock or ERC)
Oct 26, 2010 | Kenmore Ovens
Self-cleaning oven F2 error message
Well I found three all same series... If it's occasional I'd leave it 'till was always on? Anyway .....
OR....
OR
Feb 16, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Oven temp stays 100 degrees above set temperature. Have adjusted digital controls but cannot bring it into range.
You obviously have a faulty thermostat,only solution would be to replace thermostat.
Jan 02, 2010 | Kenmore Ovens
When using the oven setting it justs get hotter and hotter.
tt sounds like the thermostat sensor
Dec 27, 2009 | Ovens
Takes what seems to a an extended time to PreHeat either oven.
Sadly ours performs this way also. I've always had GE wall ovens and NEVER did they take very long to get up to temperature.
Has anyone else communicated with you about this problem?
Jun 14, 2009 | Frigidaire PLEB30T9DC Electric Double Oven
Temperature is wrong
Many ranges show a beginning temperature that is higher than actual temperature, then the gap closes as it heats up.
Use a accurate oven thermometer to check your temps.
If it is faulty, it will not recalibrate to offset 200 degrees. You will have to replace the ERC.
Mar 20, 2009 | GE 24" Built-In Single Gas Wall Oven
Temperature in oven is way off
Jim,
A couple of questions... What makes you think the oven is off that far? If you have a set on the shelf dial type thermometer, throw it away. They are never accurate and generally read 50+ degree too low. I recommend the "biscuit test". Which is simply a cheap can of "hit on the edge of a counter top to open" biscuits and see how they bake with the instructions on the can. Make sure you allow the oven to preheat for 20-30 minutes (always but especially for this test).
To change the oven setting press BAKE, then run the temp up to 550 then immediately press and hold the bake pad for 10-20 seconds. The display should read 0 (zero) you can then use the up down arrow pads to adjust, hit bake pad again and then "clear" when done to lock it in but, you can only go up or down 35 degrees. If it is truly off by more than that you would need to change the main oven control board and oven sensor.
Dec 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Crosley (Maytag) CG3478VVD Gas oven not heating properly
It's possible but a failing (ignitor) can cause this too. It might be barely passing enough current to hold the valve fully open. Check the rating on the valve and then the current draw of the ignitor. Or sub in another ignitor. Also low gas pressure can cause it too. Have your utility co check for this
Dec 28, 2007 | Ovens
Ovens Logo
32 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
