Question about AEG Lavamat 16810 Front Load Washer/Dryer
My aeg washer dryer comes up with e20 flashing i have checked the pipes, changed the pump cleaned the bottom filter, pump is now working but e20 fault still comes up half way through the wash cycle... how do I re-set the washing cycle?
  • 1 more comment
  • cantal15 Nov 15, 2008
    I have the same pb did you found the solution to fix it?
  • yas_gibson Nov 26, 2008
    my washer - dryer lavamat turbo 16830 keeps flashing e20 so i clean the bottom filter and check the pump and its fine, then it stated washing and e20 started flashing half way through and i was making a bibing noise please help me!
  • fayed_west Feb 08, 2009
    hello, I have the E20 flashing. The drum filled with water though I put it on a drying cycle. I am also unable to drain or spin....hmmmm? I can't find my manual so any suggestions before I call the repair man...thanks ....oh and my machine says AEG electrolux Lavamat Turbo - dont have a number...
I had the same problem (E20) for a long time and tried everything in the manual before I called AEG to have someone stop by and fix it.
He took the whole top off as well as the back and pulled out all this fuzz that was stopped somewhere. He said it normally comes from using too much detergant and also from not letting the machine run empty every now and then....but it doesn't say to do this in the manual. And anyway, I can't imagine that using too much wash powder made 1/2 kg of fluff.
I still have a guarantee on the machine, but they say that because it is my fault that I got E20 I have to pay for the repairment myself.
I actually think that they build the machine purposly in this way to keep up the money flow. I have an attorney on the case now.
Posted on Jan 14, 2009
  • jenni green
    jenni green Sep 18, 2014
    i dont use loose washng powder in the drawer - hes had all the pipes out and checked pump etc but still cant get it to advance beyond the wash cycle - and cant stop it or change the programm - it just keeps washing forever!
I had a similsr problem that was caused by inadvertantly crimping the drain hose when the machine was pu8shed back under the counter
Posted on Feb 21, 2008
I have the same problem any help appreciated
Posted on Jan 09, 2008
Another AEG e20 Plea, tried everything please help!
E20 on your machine means some sort of drain problem. If it actually goes through the spin cycle fine; some water will still not drain out at the time of the tumble dry. Check the wall drain to make sure it isn't clogged..
Check the drain of your wall, not the washer, this shd be cleaned out thoroughly; and the exit pipe of your washer should not fit too tight into it, there shd be some space for air.
This is a further tip, if helped click helped.
Apr 10, 2013 | Washing Machines
Error code E20 on a AEG washer dryer
Ok if its only bring the E20 up on the drying side then this will be a blocked dryer condenser chamber.
To get at this you need to take the back half of the washer off and from there you will see a big plastic chamber going from the bottom up to the top.
Take this chamber off and give it a good clean out with a hose pipe.
Once this is clear refit it and the dryer should be back to normal from there.
Oct 14, 2012 | Washing Machines
Getting E20 error message so I need to clean out the pump and hose but I can't get inside the machine - how do I get access to the pump? Thanks
Try bottom right / drawer here Filter within, you will see a long tube that comes out ,you take out the end stopper and drain first then remove and /clean filter good luck...
Apr 01, 2011 | AEG Lavamat 16810 Front Load Washer/Dryer
Tumble dryer works for 10 mins then switches off and flashes E20....what does this mean?
E20 relates to a blockage in the pump check the filter and that the pump is free to turn there may also be aproblem on the drain pipe check this also
Apr 25, 2010 | Zanussi FJD1666W Front Load Washer
Error code e20
E20 means you have a drain problem. Check the drain filter on your machine to make sure it isn't blocked by fluff/coins/etc. Should work again unless you have a bust pump (which I had).
If machine is full of water, do an emergency drain through the little pipe on the bottom front. Good luck.
Jan 18, 2010 | AEG Lavamat 72640 Front Load Washer
E20 what does that mean?
E20 is a drain problem. Clean out the drain filter, normally found bottom of machine. Do emergency drain first or you will flood the room if there is water sitting in drum. Hopefully you just have a blocked filter or pipe, otherwise you may have to replace pump if it has failed.
Washer front loader
Check the drain hose, and inspect the filter for any foreign object.
I report :"E20 means your fluff filter / waste pipe is getting blocked and themachine cannot pump out the water. Try unblocking the fluff filterfirst at the bottom of the machine. This should work, if the faultappears again though and the fluff filter is clean your waste pipe isblocked and you need to flush this through. Can you tell what I've justspent my weekend doing, I have had to get the most unbelievable amountof limescale out of these 2 areas but machine is now working fine again."
From how to mend it
See also E20 Zanussi Washer Dryer WJD1667
Oct 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Problem
I report :"E20 means your fluff filter / waste pipe is getting blocked and the machine cannot pump out the water. Try unblocking the fluff filter first at the bottom of the machine. This should work, if the fault appears again though and the fluff filter is clean your waste pipe is blocked and you need to flush this through. Can you tell what I've just spent my weekend doing, I have had to get the most unbelievable amount of limescale out of these 2 areas but machine is now working fine again."
From how to mend it
Oct 15, 2008 | Zanussi FJS1225W Front Load Washer
AEG Lavamat 16810 Front Load Washer/Dryer Logo
2,795 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
