Question about EliteGroup nForce3-A Motherboard
Nforce 3a Hi I have power but no boot up can you help? Michelle
  • 1 more comment
  • mivan Dec 22, 2007
    Hi thanks i will look at the caps but as i thought it looks like it burnt out, bought it from e-bay stating working but they must not have a clue as to what works or does not.
    Thanks
    Michelle
  • ndn4ever Apr 26, 2008
    Soon as I flip toogle on psu , fan will spin,no display,will not power down with front panel button. Caps have no leaks or swelling..
  • moley52 Aug 17, 2008
    plugged my camera into a front USB port and the mouse froze. On inpection The port looked damaged, when I plugged the camera into the lower USB port the PC switchdd off immediatley. Some USB pins are bent & I guess they have shorted. I have unplugged the usbports at the motherboard, but the PC will not power up.
Hi
I had the same problem. Mine was because of the mainboard capacitors. I quote some part of my post and ones of Tom.
"Nearly one month ago my computer started to reboot again and again. When it came up , after 10 minutes of operation it showed a blue screen showing the progress of dumping RAM or something. Now it does not boot at all. It just turns on and the green light is on , but nothing appears on the monitor. Also there is no drive activity. Just fans work! I think the motherboard is burnt. Any other possibility?"
"Gr8MP, look at your board closely. Are any of the caps. leaking or tops popped up?
http://cquirke.mvps.org/badcaps.htm
http://cquirke.mvps.org/csxcaps.htm"
If yours was like mine , you should just buy the caps and replace them or get them replaced by an semi-expert or something. Good luck and keep me informed.
Posted on Dec 22, 2007
  • Gr8MP Dec 23, 2007
    Maybe you have hurried! Any way good luck.
How Do I Reset Circuit Breakers in 2006 GMC Envoy?
Hi Michelle, I'm glad to help!
Michelle, Sometimes there is a hidden fuse box inside the vehicle somewhere. It could be behind the glove box, in one of the kick panels next to your feet OR even on the side of the dash behind the cover. You'll need to check with the dealer and give them your VIN number and have them see if there are more then just the under-hood fuse box. Because most likely you have blown a fuse somewhere. You check on the fuses boxes and I'll do some more research and let you know. Hope this helps and have an awesome day Michelle.
Jun 04, 2013 | Cars & Trucks
ASUS A7N8X-E Deluxe NForce 2 Ultra 400 Motherboard (90M7A770GOUAYOZ) When I built my PC in '05 I installed 4 HDD's on the A7N8X-E Deluxe. Now my main drive is failing so I've cloned it to a new HDD, but...
hi Memory,
You can try 2 things:
1. If the HDD has jumpers make sure to set the one you want to boot from as the master.
2. Go into your BIOS and choose which device to boot from first.
Also just to be sure disable all other drives and boot with the single drive to ensure that it actually works. There are bootdisks that can help with booting issues one being called ultimate boot cd but i wouldn't touch settings unless you know what your doing.
Hope this helps,
Omeil
Jan 31, 2011 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
How to format
Welcome to Fixya Support
I am Michelle, and i will be assisting you regarding the issue
please click on the below link
http://www.google.co.in/url?sa=t&source=web&cd=1&ved=0CBYQFjAA&url=http%3A%2F%2Ffiledb.experts-exchange.com%2Fincoming%2F2009%2F12_w50%2F211069%2Fusers-guide-28066A.pdf&ei=ds_oTIXUMo2IvgO4p-TCCA&usg=AFQjCNG5mFTY23KWQp5P1YmYOPyqo85DzQ
this will open the Toshiba user manual.
open page#60 which will list the steps for a factory restore of the notebook.
Nov 21, 2010 | Toshiba Satellite Pro L300 Notebook
My acer travelmate 4100 will not power up when I switch on. The green power button is lit but the screen is blank and and there is none of the normal "booting up" noises it's just silence :-( I have tried...
hi michelle, first check to see if you can even get to your BIOS. if that is not posible then you might have either a power supply or motherboard issue. for either one of those you will need to send for repair.
Aug 11, 2010 | Acer TravelMate 4100 Notebook
Black screen after factory BIOS reset
Have u connected signal cable to the monitor? Is it ON?Try with different monitor
May 07, 2009 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
No beep tones on startup, power to all devices, no bootup
Just a shot in the dark...unplug power, remove battery..at least an hour . Press power button at least once in the hour.
Good Luck
Apr 04, 2017 | Gigabyte GA-N650SLI-DS4 nVIDIA nFORCE 650I...
Computer does not boot (new Machine)
Swap the power supply since you got two systems?
Feb 23, 2008 | Pine Technology XFX NFORCE LT 680I SLI...
ASUS Motherboard A7N266-VM
If you have another video card you can try (you can put an AGP card in there, it will disable the onboard video automatically), take that route first. If you can't, or it occurs with another card, it may be your power supply. It would help to know if your pc beeps when you turn it on, and how many - if any - beeps there are.
Feb 18, 2008 | ASUS NVIDIA nForce Chipset A7N266-VM...
EliteGroup nForce3-A Motherboard Logo
164 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Computer Links
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
