Question about Garden
How do you remove the clutch from a Cub Cadet cc 4125. Have removed the flywheel, but can't get the rest of the clutch off.
  • 7 Answers
SOURCE: I need to replace the pto clutch on my cub cadet
best way is to use an impact gun. second way would be to use a pipe wrench on the shaft if theres room. use some liquid wrench to loosen it up too
Posted on Jun 09, 2009
  • 279 Answers
SOURCE: clutch removal on 31 cc weed eater
Break the engine away from the shaft on the shaft side. I think 4 bolts/screws. Once you have that open you will seethe part that goes over the shaft. To take it off, hold the part with one hand and remove a screw in the center of the part using a #15 TORX screwdriver. Take off the part and under it is the clutch. Good luck...Lee
Posted on Sep 05, 2009
  • 736 Answers
SOURCE: I have a Cub Cadet cc4125 string trimmer not starting
need a little more information .. but look for the following .. take out the spark plug and look inside with a flashlight ... if the piston is moving with the rotation of the flywheel then you likely have a blown head gasket .. if there is no compression there wont be a load on the pull cord .. a cracked or damaged piston can also do this .. ... if the piston is not moving when you rotate the flywheel then you likely have a bad "shear key" sometimes called a "shear pin" .. thats usually a half moon shaped small metal part that keeps the flywheel locked rotationally to the crankshaft .. it is designed to shear off if there is an excessive sudden load on the engine .. the flywheel will then spin without turning the crankshaft .. the same thing will happen if you have broken the connecting rod .. (a rod failure is often preceded by lots of clatter from the engine) .. the head gasket or shear key are much more likely to be your problem .. if you cant see in the spark plug hole you might try using a straw to feel the piston motion .. its possible that without the spark plug in place the piston might move even with a bad shear pin .. because with no compression the piston will move freely .. if thats the case you can stop the piston motion with a wood dowell thru the spark plug hole .. if it moves in spite of your dowell resistance then consider the head gasket option ..
Posted on Sep 19, 2009
  • 332 Answers
SOURCE: How to remove deck on 1045 cub cadet to remove and
You should be able to remove the blades without removing the deck
They bolt on from underneath with either a single or double bolt set up
90% + are single bolt
Posted on Mar 30, 2010
SOURCE: My Cub cadet pto cluch bearing is froze up on my 2518 lawn tracto
A medium length extension (stuck through the grill), a swivel and an impact is all you need to remove the pulley with the frozen bearing. It's just a bolt, a washer, and a lock washer holding it on. You just need to remove the pulley to see if the bearing is stuck. Take the pulley to your local shop that can press bearings and you can be up and running for $20 dollars instead of $300. Here's a diagram I found on partstree:
http://www.partstree.com/parts/?lc=cub_cadet&mn=2518-48+Tractor&dn=0043700012
Posted on Apr 11, 2010
How to i change the drive train belt on my cub cadet z force 50
  1. First park your mower on level ground and apply the parking brake.
  2. Remove the deck drive belt from the PTO clutch.
  3. Remove the electric PTO clutch. This is done by disconnecting the electrical wires first. Then removing the center bolt using an impact wrench. A pull bar can used but you must prevent the engine from turning by blocking the flywheel.
  4. Remove the tension on the drive belt idler.
  5. Remove the drive belt from around the pulleys. Be careful as the engine may try fall off depending on if it isn't seized on yet.
  6. Installation is the reverse of the above instructions.
  7. After install the PTO clutch tighten the center bolt to 55 ft lbs using a torque wrench (not your impact wrench) with the flywheel blocked from moving.
Dec 28, 2014 | Cub Cadet Garden
Cub cadet starter spins but doesn't connect to flywheel
youy have a strip starter gear on the starter have to remove starter to chang gear gear cost 24.00 have it done 50 to 60 dollars
Aug 15, 2014 | Cub Cadet Garden
How to change out an electric clutch on a cub cadet zero turn RZT50?
Removal is simple if you have access to an impact wrench so you can the center retaining bolt.
When re-installing anti-seize compound needs to used on the crankshaft so the new clutch assembly doesn't seize on the shaft. To tighten the center bolt you must hold the flywheel in place by blocking it. This center bolt must be torqued to 45-55 ft fts. Also the new pto clutch needs burnishing in. Most new clutches come with instruction on this procedure.
Jul 23, 2014 | Cub Cadet Riding Lawn Garden Zero Turn...
How to remove clutch on a cub cadet lawn tractor
if eletrical clutch you need a air wrench remove the nut clucth slides off but you got to have air wrench
Jul 29, 2013 | Cub Cadet Garden
Need to change flywheel on a Kohler motor CH 12.5S in a cub cadet 1230. Do I need to pull the motor
shouldn't. Just remove the blower housing and the hold down nut for the flywheel then put your flywheel puller on it and remove it
Mar 28, 2013 | Garden
How do you remove the pto on Cub cadet LT 1046?
it should pull off after removing the center bolt
Aug 05, 2012 | Garden
How to remove pto clutch on cub cadet model 2186
unplug it remove the center bolt and remove the bolt that stops the clutch from rotating
Apr 23, 2012 | Oregon Scientific Electric PTO Clutch for...
Mower will not shut off when disengaged \r\nwhen starting the mower the pull chord is very hard to pull and i usually have to take off the mechanism and readjust it
REPAIR OF THIS SORT USUALLY REQUIRES REMOVAL OF THE FLYWHEEL AND WITHOUT THE PROPER TOOLS AND KNOWLEDGE YOU MAY DAMAGE IT PERMANTLY, IF YOU CAN HANDLE THE FLYWHEEL REMOVAL YOU PROBABLY WILL BE ABLE TO FIGURE OUT THE REST BUT BE MINDFULL THAT THE CABLE FOR THIS IS USUALY ABOUT $60.00
Aug 02, 2011 | Cub Cadet Garden
Garden Logo
552 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
