Blue error message comes when there is any issue with memory.
First Refix your RAM memory.
Then boot your computer with recovery disk.
For that you have to set first boot device as your cd or dvd rom .
When you power up the computer press F1 or F2 or "del" key then you see bios setup screen.
Then go to boot option and set first boot device as cd or dvd.
Then put bootable disk in computer then it boot with it.
Then follow the procedure on screen.
choose "R" option for enter in "Recovery Console"
Then type in prompt "chkdsk /r"
then
it fix error on harddisk then then restart computer then if still same
issue then you have to repair your windows with recovery disk.
Let me know if you need more assistance.
Thanks.
SOURCE: Intel desktop board display stuck problem while booting
it is the problem Ram bus please change memury module then solve your problem
SOURCE: recover BIOS d845gebv2 motherboard
Right after you power the computer on start tapping F2 rapidly on the keyboard until you are in the BIOS setup. When you are in the BIOS setup, check to see that the computer recognizes your boot device and that your boot order is correct. Also, if you have changed any jumpers on your mainboard; change the back.
SOURCE: IntelD865GBF starts up displays Blue INtel Desktop
remove Bios battery ..and try again ...probably it doesn't see something ...but its a good sign that the Intel blue appears
