Question about Heaters
Delonghi heater my delonghi heater wont turn on!it has been making cicking noises for a bit but i only got it this july
0 characters
1 Points
Have a 1 year old Delonghi oil heater and has starting to make loud crackling noises when hearing up for about 5 mins.
The sound you are hearing is the metal and the oil inside expanding. When you heat metals they expand. When it cools it shrinks. I would imagine that when you turn this off it is also making these noises but you are not there to hear them like you are when you turn it on.
Sep 23, 2014 | DeLonghi Heaters
Heater switching off for no reason
The level safety device may be defective.
Jan 28, 2014 | DeLonghi TCH6590ER Ceramic Heater
Family member knocked heater over.Now it makes noise like water dropping into a pan of oil. I can hear what sounds like water dripping in the heater, Help
Don't get too excited... it will stop after everything settles in there again...
It is just the oil dripping back down inside...they are not toally full with oil...
Jan 23, 2011 | DeLonghi EW0507 Oil Filled Radiator Heater
When i turn the heater on its making an awful noise?
The fan could be rubbing on it's shroud. I would check that first. Ascrew could have vibrated out as well.
Oct 15, 2010 | DeLonghi Primadonna Mid-Size Heater
Dragon wont turn on, have checked the fuse
We had the same problem. The on/off switch is likely to be broken inside. We tried to fix it but its likely the pcb is damaged. If you contact Delonghi direct they will help resolve. They sent us a new heater (10yr guarantee)!
Jan 13, 2009 | DeLonghi Dragon 3 0820 / 0820T Oil Filled...
Delonghi MG15T Magnum Oil-Filled Radiator timer -timer keeps running?
I found the manual at this website:
I hope this helps.
Oct 13, 2008 | DeLonghi MG15T SafeHeat Oil Filled...
Noise coming from DeLonghi TRD0715T Oil Filled Heater
seems to me you have a bad bearing in the fan. if you can access the fan, have a few drops of oil poured on the shaft of the fan and see if it solves your prob.
Jan 23, 2008 | DeLonghi TRD0715T Oil Filled Radiator...
Delonghi TRN1015T wiring diagram
Just wondered how you learned to turn off the timer.
Jan 10, 2008 | DeLonghi TRN1015T Solaris Oil-Filled...
DeLoghi Oil Filled heater
No need to replace. There's a loose wire/connection somewhere. Have someone with good hands open the control box and tighten. I would not suggest using it in the present condition.
Dec 29, 2006 | DeLonghi 6507L Oil Filled Radiator Heater
Heaters Logo
147 people viewed this question
Top Heaters Experts
Dan Webster
Dan Webster
Are you a Heater Expert? Answer questions, earn points and help others
