Question about Refrigerators
I have a kenmore refrige with a top freezer made in 1996. All of a sudden it is making a noise like a wobbly fan.should i be concerned it is going to die?
    President:
  • 1,304 Answers
Yes
you will notice your refer temp climb
while your freezer remains semi normal
Posted on Oct 03, 2009
Kenmore side by side 253.52349302 making stalling noise
motors start capacitor relay may be going bad..
Jan 20, 2014 | Kenmore Refrigerators
Subzero 550 freezer making loud noise if top wire shelf closed
When you shut your top wire shelf you do a few things. First of all you activate your fan. Your fan sits in back of a large evaporator coil which is prone to defrost issues. I would imagine your fan is hitting ice due to a defrost issue. You may want to check your defrost system out. Ie your defrost timer.
or alternatively your fan could be getting old and needs replacing, it could just be making noise.
Joe B, Certified refrig.
Apr 04, 2013 | Freezers
Whirlpool refrig center section hot
Heat between the doors is normal, It can be a bit concerning but don't worry about it.
The fans do wear out on fridges and can be replaced if the noise bothers you. As long as the fan is still turning it won't affect the operation.
Mar 07, 2012 | Whirlpool Refrigerators
I have a Kenmore top freezer refrig, My freezer works fine. My fridgerator is not cooling. I can hear the fan running. What could be the problem?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 26, 2011 | Kenmore Top Freezer Refrigerator
Kenmore 18tfa top freezer refrig model # 72852101 freezer works, no cool air going into the refrig part. Ice machine works fine too. fan is on.
Possible fan not blowing the air into the fresh food compartment or your freezer could be frosted up. Need more input.
Jan 29, 2011 | Kenmore Refrigerators
Refrig compartment does not cool on my new Kemore Frig.
Check and make sure the fan in the freezer is running. if not possible bad fan. If fan is running, check to see if you have any ice built up on back freezer wall. Normally frost type ice. If so, you may possibly have a bad defrost bi-metal mounted in the freezer section. Next could be a defrost timer control. Model number usally will help more in getting it right.
Feb 28, 2010 | Kenmore Refrigerators
Noises in freezer area of refrigerator
Some refrigerators have a small plastic fan under the bottom shelf of the freezer that circulates air. It's not too unusual for a heavily loaded shelf to rub the fan blades making the noise you describe. If you empty the freezer, you'll fin a few screws holding the bottom shelf in. remove the shelf and inspect the fan and surrounding parts for signs of rubbing. Also tug on the fan blade lightly to see if it is still attached to the motor's shaft securely. New fan blades can be purchased at a good appliance repair shop. Good Luck
Nov 30, 2009 | Hotpoint HTR16BBSR Top Freezer...
Kenmore top freezer fridge does not cool but freezer works
Turned refrigerator off for 8 hours, let the frost melt and the fan in the freezer worked again. The compressor now only has a soft clunk when it goes off.
Jan 30, 2009 | Kenmore 64823 Top Freezer Refrigerator
Kenmore refrig not making ice and top shelf area in refrig not cold
if you are having tempurature issues make sure the fan in the freezer is operating. it should be on when the compresor is running. this may explain both warm fridge and no ice.
Sep 10, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore top freezer unit-refrig not cooling past 50degrees
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 03, 2007 | Kenmore 64802 Top Freezer Refrigerator
Refrigerators Logo
61 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
