Question about Insignia 42" LCD Flat-Panel HDTV
The cable people told me to have the tv auto adjust itself as the sports channels I added seem pixely. I cannot find this on the menu...also won't let me choose auto on picture mode or the parental controls and computer settings on the settings menu won't le
    President:
  • 1,284 Answers
If you have only one channel that is a bit more pixelated than the others I hate to tell your cable company but its not the TV at faut. The fact is that channel has more compression and also the fact that some sports will show more pixelation than others. Depends on if the shot is close up or a wide angle shot.
Posted on Oct 03, 2009
Sharp LC-37DB5U stuck on one channel. Won't respond to anything. Put in a new motherboard and same problem persists. Sound and picture are fine
I could be wrong, but it sounds like the TV hasn't gone through channel setup. You have to do this in order for the TV to "learn" the channels, assuming you are using cable. If you are using cable run channel search in the setup menu and see if that changes anything. Can you change channels by manually entering in the channel # and hitting enter?
Jan 06, 2013 | Sharp LC-37DB5U 37 in. HDTV LCD Television
I have removed all cable boxes from my home. I cannot get the tv remote to change channels. I was told by the cable tech that I needed to do a channel search. How do I do that?
Which specific model do you have? The menus may depend on your model. Are you using the original TV remote or a different remote? If you do not have the TV remote, try the buttons on the TV. Use the channel up/down buttons to navigate through the menu items and the volume up button to enter a sub-menu.
Try Menu and locate the Channel sub-menu. Then make sure that the antenna Air/Cable item is set correctly. Then the Channel Search option is on the next line. This is the method for the LCD2050. For the TTM2901L, you need the same Channel sub-menu but the channel search is called "Auto Program".
A number of other manuals for Polaroid TVs are available here: http://www.polaroid-tv.com/polaroid-lcd-tv/manual/ .
I hope this helps. If you add a comment with your model number, I'll be glad to provide additional help. (Note: without the model, I can't be sure which tuners (NTSC - analog OTA or cable, ATSC - digital OTA, or QAM - digital cable) are in your TV. This may change whether you can receive any stations without the cable boxes.)
Jan 25, 2012 | Polaroid Televison & Video
LG 50" the pitcher is off the screen each side by
Ok, first make sure you or someone in family didn't hit the "HD Zoom" on your cable remote or whatever kind of remote you have. On ours - Cable- if you hit it once it is in "Normal" picture which on ours has black around edges on a non Hd channel. Then if you hit it again it Zooms once makes pix very large and if you hit button a third time brings it into a wide screen Zoom that fills the Tv screen. If we are viewing HD channels I put it on Normal which will fill the screen and give you the best HD pix. If we are viewing a NON HD channel, then normal will have black on sides, so I hit the Zoom a couple times to fill in the screen. My brother in law had this problem and couldn't figure out why his Sports channel Scores were always half cut off the screen! it was zoomed in too much for that channel. His sports channel was in HD so needed to be on normal instead of zoomed in.
if it is not the Cable remote then this is a second possible cause:
The other thing that happened to me was - we hardly ever use our original TV remote that came with the TV. but one day our picture looked weird and the cable remote didn't adjust it. One of us had hit the "P SIZE" button on the TV remote. this changes your pix from - 4:3 ratio to 16:9 ratio and vice versa. I put clicked that button and on the TV it shows whether it is at 4:3 or 16:9. For newer wide screen TVs you want that set at 16:9 ratio.
All cable company remotes probably are a bit different so check with your company ... to find out where the zoom control is on their remote.
Feb 27, 2011 | LG Televison & Video
The channels won't work.
you can use another TV to test the cable.
Apr 30, 2010 | Samsung LN-R409D 40 in. LCD Television
Dont know how to do a channel scan on my samsung 2333hd t.v
Using the Color buttons on the Remote with the Channel List.
• Red (Antenna): Switches to Air or Cable.
• Green (Zoom): Enlarges or shrinks a channel number.
• Yellow (Select): Selects multiple channel lists.
• TOOLS (Option): Displays the Add(or Delete), Add to Favorite(or Delete from Favorite),
Timer Viewing, Channel Name Edit, and Auto Program menus..
Auto Program
The TV automatically cycles through all of the available channels and stores them in memory.
In rare cases, "Auto program" may miss a few channels due to weak signals and the channels may
not be added to the channel memory.
Air
Cable
Auto
MENU → arrow up, arrow down→enter → arrow up, arrow down→enter →arrow up, arrow down →enter →arrow up, arrow down, arrow left , arrow right →enter → MENU,EXIT.
Hope this helps. I have the owners manual on file.
Sep 01, 2009 | Samsung SyncMaster 2333HD 23 in. LCD TV
SONY KV32V16...can't get all my cable stations.
I called our cable company about getting a converter box and it ended up I didn't need one after all. The cable rep told me to go to the menu and try the auto-programming. He was familiar with the TV I have and said that a converter box is not necessary. So, I tried the auto-programming and still didn't get all the channels...then I noticed on the menu for the channel set up there was the word "Cable" and after it it said "Off" so, I switched that to "On" and did the auto-programming, and Presto! I got all my channels.
Dec 25, 2008 | Sony KV-32V16 TV
Can I get more channels?
go to the menu and navigate to auto-prog(ram)
Feb 24, 2008 | Sanyo DS31520 31" TV
Auto SAP
The problem is not a cable one, but a TV function. Pull out your user manual for your TV. My dad just had this happen, and he has a Sony WEGA TV. The auto sap is an AUTO Secondary Audio Program, you need to find the menu to back out of it.
Good luck.
Jan 06, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Receiving tv programs
In the menu theres a channel set up mode. You want to switch from antenna to cable mode, then do an auto search. Then all your cable channels will come in. Your going to need the original remote to go into the correct menu. good Luck
Aug 25, 2006 | Audiovox FPE1078 7.8 in. TV/DVD Combo
Insignia 42" LCD Flat-Panel HDTV Logo
146 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
