Question about HP Photosmart C5180 All-In-One InkJet Printer
How do I insert an ink cartridge? - HP Photosmart C5180 All-In-One InkJet Printer
First get the chunky peanut butter and apply to the cartridge sides, the insert.
Posted on Oct 03, 2009
How do you insert ink cartridge?
hi may.
you have not said on what printer.
but go to this link might help you out.
Remove the old ink cartridge and install the new ink cartridge.
  1. Make sure the printer is turned on. ...
  2. Open the top cover of the printer. ...
  3. Wait until the carriage moves to the right side of the printer and is idle and quiet.
  4. Press down on the old ink cartridge, and then slide it out of the carriage.
More items...
Replacing Ink Cartridges - HP Support
How do you insert ink cartridge Google Search
Nov 06, 2017 | Office Equipment & Supplies
How do you remove ink cart.
To replace an ink cartridge on a Kodak ESP C310 follow these steps:
1) Make sure your printer is on.
2) Lift the printer access door, and wait for the carriage to move to a position where you can access it. The ink cartridges are located in the printhead.
3) Pinch the tab on the ink cartridge.
4) Lift the ink cartridge out of the printhead.
5) Remove the new ink cartridge from its bag.
IMPORTANT:To prevent the printhead from drying out, insert the ink cartridge into the printhead immediately.
6) Remove the protective cap from the cartridge.
7) Insert the ink cartridge into the printhead.
8) Press down on the ink cartridge tab until you hear a click.
9) Close the printer access door.
That completes changing the ink cartridges.
Thank
Mark
Aug 25, 2014 | Kodak EasyShare Office Equipment &...
Need to replace ink cartridge and I forget how to replace ink cartridge
1. Remove the black ink cartridge from its bag.
2. Carefully remove and discard the orange cap.
Handle ink cartridges carefully to avoid ink transfer.
3. Insert the black ink cartridge into the printhead.
4. Press down on the ink cartridge until you hear it click
into position.
5. Open and uncap the color ink cartridge. Insert it into
the printhead.
6. Press down firmly on the ink cartridge until you hear it
click into position.
7. Close the printer access door.
Here's the link if you want some illustrations. Link
Chapter 3, Page 5
Thank you for posting..
Jun 30, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I am having problem on how to change the ink cartrdges. I can't get it to go to the center to be able to change the ink. Pls. help
hi,
following images and steps may guide you.
first know the parts.
Tear open the black ink cartridge bag at the notch and remove the ink cartridge.
IMPORTANT: Insert the ink cartridge immediately to prevent any drying of the ink.
Remove and discard the orange cap.
IMPORTANT: Handle ink cartridge carefully to avoid ink transfer.
Insert the black ink cartridge into the printhead. User's
Press down on the ink cartridge until you hear it snap into position
Tear open the color ink cartridge bag at the notch and remove the ink cartridge.
Insert the color ink cartridge into the printhead
Press down firmly on the cartridge until you hear it snap into position
regards,
cseian
Feb 16, 2011 | Kodak EASYSHARE 5300 All-In-One InkJet...
I whant to refill pixma canon ip2700 with black ink but dond now how
Color Cartridge 1. Place the cartridge over somepaper towels in case there are any spills.Remove the label sticker from the topof the color cartridge. 2. Drill into the three small holeson the top of the cartridge to widen them so they will allow syringe needles. 3. Fill a syringe with 6 mL ofmagenta ink. Insert the needle into the refill hole that is located below thetwo protruding rectangles on the top of the cartridge. Slowly inject the ink. 4. Fill a syringe with 6 mL of cyanink. Insert the needle into the refill hole located below the large rectangleon the top of the cartridge. Slowly inject the ink into the cartridge. 5. Fill a syringe with 6 mL of yellowink. Insert the needle into the refill hole located below the small rectangleon the top of the cartridge. Slowly inject the ink into the ink chamber. 6. Replace the cartridge into theMX310 printer. Black Cartridge 1. Set the cartridge on some paper towels. 2. Drill a hole into the dimplelocated directly above the semicircle on the top of the cartridge.Fill asyringe with 20 mL of black ink. Insert the needle into the hole and slowlyinject the ink. 3. Replace the cartridge into theCanon MX310.
Nov 28, 2010 | Canon PIXMA MX310 All-In-One Printer
How do I insert my ink cartridge into my Canon MP240
1st you must switch on the power. the lift up the scanner unit. The you will see the cartridge holder moving to the left hand side. And then you may insert the ink cartridges.
May 21, 2010 | Canon PIXMA MP240 All-In-One InkJet...
HOw to install ink cartridge on HP Photosmart7760
Install the ink cartridges.
  1. Turn on the printer.
  2. Lift the top cover.
  3. Open both ink cartridge cradle latches by pulling each latch forward and then up.
  4. Pull the pink pull-tab to remove the clear tape from each ink cartridge. Do not touch or remove the copper contacts.
  5. Insert the HP #57 tri-color ink cartridge in the left stall. Insert the HP #58 photo ink cartridge in the right stall.
  6. Close both ink cartridge cradle latches by pushing down on each latch until it snaps into place.
  7. Close the top cover and press the OK button to print a calibration page. This verifies that the print cartridges are installed correctly.
Sep 13, 2009 | HP PhotoSmart 7760 InkJet Printer
Won't print after replacing cartridges
The following text copied from HP website to tackle this problem. minimtop.gif Follow the instructions below to install the print cartridges. NOTE: If you are installing ink cartridges in the unit for the first time, be sure to use only the print cartridges that came with the unit. The ink in these cartridges is specially formulated to mix with the ink in the print head assembly at first-time setup. s.gif Installing the print cartridges minimtop.gif
  1. Verify that the unit is on.
  2. Open the ink cartridge door. Figure 1: Opening the ink cartridge door c00718797.gif
  3. Squeeze the gray tab below an ink cartridge slot to release the gray latch and then lift the latch. Figure 2: Lifting the latch c00721793.gif 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges NOTE: The ink cartridge areas are color-coded for easy reference. From left to right, the ink cartridges are black, yellow, light cyan, cyan, light magenta, and magenta.
  4. Remove the new ink cartridge from its packaging.
  5. Hold the ink cartridge by the handle and then slide the ink cartridge into the empty slot. NOTE: Make sure that the ink cartridge is inserted into the slot that has the same shaped icon and color as the ink cartridge. The copper-colored contacts should be facing the printer as the ink cartridge is inserted. Figure 3: Inserting an ink cartridge c00721795.gif
  6. Press down on the gray latch until it clicks into place. Figure 4: Closing the gray latch c00721796.gif
  7. Repeat steps 3 through 6 for each ink cartridge that needs to be replaced. NOTE: All six cartridges must be installed. The printer will not work if an ink cartridge is missing.
  8. Close the ink cartridge door. Figure 5: Closing the ink cartridge door c00718798.gif
s.gif s.gifHave a Good Day
Jul 17, 2009 | HP Photosmart C4580 All-in-One InkJet...
New Cartridge error message
Follow the steps below to remove and replace the empty ink cartridge.
  1. Turn the printer on.
  2. Open the ink cartridge door. Figure 1: Opening the ink cartridge door c00819080.gif
  3. Squeeze the gray tab below an ink cartridge slot to release the gray latch and then lift the latch. Figure 2: Lifting the latch c00819081.gif 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges
    NOTE: Theink cartridge areas are color-coded for easy reference. From left toright, the ink cartridges are black, yellow, light cyan, cyan, lightmagenta, and magenta.
  4. Pull the ink cartridge toward you out of it's slot to remove it. Figure 3: Removing an ink cartridge c00819082.gif
  5. Remove the new ink cartridge from the packaging.
  6. Hold the ink cartridge by the handle and then slide the ink cartridge into the empty slot.
    NOTE: Makesure that the ink cartridge is inserted into the slot that has the sameshaped icon and color as the ink cartridge. The copper-colored contactsshould be facing the printer as the ink cartridge is inserted. Figure 4: Inserting an ink cartridge c00819083.gif
  7. Press down on the gray latch until it clicks into place. Figure 5: Closing the gray latch c00819084.gif
  8. Repeat steps 3 through 7 for each ink cartridge that needs to be replaced.
  9. Close the ink cartridge door.
after Doing this all Follow the next step :-
Please Try This, I am sure it is going to workout.
Resetting the All-in-One
Press the On (fa37665.gif) button to turn off the unit.
  • Disconnect the power cord from the back of the unit.
  • Connect the power cord to the back of the unit.
  • Press the On (a477fdf.gif) button to turn on the unit.
Oct 21, 2008 | HP Photosmart C5180 All-In-One InkJet...
Installing new cartridge
Go here. Type "how to install ink" in the search box. Click "Search", then select "How do I install the ink cartridge(s)". You will get instructions with pictures on how to prepare and install the cartridges.
Mar 25, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
32 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
