Question about GE Spacemaker JVM1640SJ Microwave Oven
Our GE spacemaker microwave model #JVM1440 is flickering on/off when in use. sometimes it cooks and others you push start and the fan is running but the micrwave isn't cooking or counting down.
    Sergeant:
  • 347 Answers
Something wrong with electrical connection or the magnetron is defective. try switching to high. if it persists replace magnetron.
Posted on Oct 03, 2009
GE Over range microwave model JVM1443LK01 This started a couple days ago. After removeing something from the microwave and we shut the door, the fan started up. The fan will run as long as the door is...
I would check the door switches for a faulty switch. If it were condensation on the control panel. I would think it would have dried out by now unless it has damaged the control board.
Mar 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker suddenly quits during cooking cycle and sometimes displays a PF ... other times simply no display
If it only runs a few seconds then fails, see this FixYa solution. even if your model number is different.
Otherwise, I would suspect the cooling fan may be failing or there is a bad connection.
Dec 31, 2010 | Microwave Ovens
GE Profile Microwave Model JEM31SA, intermittent problem with keypad going dead after cooking. Have to go out and flip breaker to reset. It prompts for clock set info and functions normally again after...
You're going to have to replace the keypad module and possible the control module (do the keypad first). You can try contacting these folks: http://www.appliancepartspros.com/search.aspx?model=jem31sa%20001%20ge%20spacemaker%20microwave
And see if they have a keypad for your unit. Depending on the age of your microwave, you may be best off replacing the whole microwave.
Aug 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Jvm1440wh04 GE Spacemaker. no microwave cooking
Could be an open internal fuse or magnetron failure
Mar 07, 2018 | GE JVM1440 Microwave Oven
My GE spacemaker microwave doesn't heat up foods. There is a slight bit of heat generated but not much. All timers, lights, etc. work normal. It is a GE model jvm1440. It is about 3 years old. The problem...
IT COULD BE A NUMBER OF THINGS RANGING FROM DIODES TO CAPACITORS TO YOUR MAGNATRON OR THERMOSTAST OR TRANSFORMERS. IT'S DIFFICULT TO DIAGNOSE WITHOUT SEEING THIS MICROWAVE. YOU MAY BE BETTER OFF GETTING YOURSELF A DIFFERENT ONE.
Apr 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
No power to GE Spacemaker Microwave
I have model GE Microwave serial # JVM2070SK02. I start to cook something and it shuts off 5~10 seconds. Keyboard is still lit up, but no clock, fan, light and you cannot operate anything on the key pad. Unplug the unit and it resets. Sometimes it cooks, sometimes it doesn't? It is getting more frequent with the shutting down problem?
Feb 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker xl microwave oven JVM1440 Two weeks ago after I press 6-express cook stopped and all the lights and clock went blank. In a 10-15 minutes it came back on and the clock would have to be...
Assuming that your internal cooling fan is working, I would suspect that your magnetron is failing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the
left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
I would check the cooling fan, then suspect the magnetron.
Nov 07, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
New microwave; loud fan when heating items
Since you say it's new, it should be under warranty. I would call GE (see your owner's manual) to get a local authorized service center. Then while you're on the phone with the service center, you can start it up and hold the phone close to it to demonstrate to the technician how loud it is. They should be able to tell you if it will be covered under warranty so you get it fixed free.
Mar 27, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
133 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
