Question about Video Game Consoles & Games
Bought a Wii console in Spain and brought bak to Canada. Have a 50'' TV from LG but it can't seem to work; power oulet, ok; video and audio input, ok; different inputs tested but no image whatsoever. With the same procedure it worked fine in my 32''Proview...has anyone been through this too?
  • 69 Answers
Get a canadian wii
Posted on Oct 30, 2009
Wii turns on but nothing comes on screen
Check your video inputs on your TV to make sure they are working then try a known working Wii audio/video cable. If still no video try changing your TV resolution if possible to match the Wii video input resolution. If still no video then you may have a dead Wii motherboard.
Jan 15, 2013 | Nintendo Wii Console
I just bought a wii and I'm hooking it up to an older model tv. the inputs are on the front and there is only one audio input and one video input. I plug in the red cable in audio and I hear the music...
Hello
The yellow cable needs to go to video.The red and white are left and right speakers or stereo.Usually there is a yellow for video,the cable doesnt have to be yellow, another red or white will work.It just needs to be in the video jack or output.
You need one more cable for video.Also be sure your tv is set to the correct input for the wii to work.Possibly it may need to be on channel 3 or 4. Or if the tv is newer try component or any input available in the tvs setup menu.
Aug 23, 2011 | Nintendo Wii Console
I hav a lg flat screen tv. just brought a wii and the set up screen does not appear. what imput setting am i supposed to use.
You should try them all. Usually, it's a RCA connection for a brand new Wii. The Input channel should be called AV1 or AV2, Depending on the number of inputs you have. The Input channel is usually written near the connection itself.
Mar 15, 2011 | Video Game Consoles & Games
Wii help
Hello :
1:Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console.
2:
Insert the RCA plugs on the Wii AV Cable into the input connectors on the TV. Plug the colored connectors into the following inputs:
Yellow = Video Input
White = Audio Input Left (or Mono)
Red = Audio Input Right
3:Once the cables are inserted and the Wii is powered on, you must find the Input Select for your TV to view the game (it is likely not going to be seen on Channel 3 or 4). Typically this is found by pressing the TV/Video button on the Television's front panel or remote control. If you have more than one input channel, keep pressing TV/Video until you see the display from the Wii.
If you do not have a TV/Video button, then the input could be labeled something different. Some other common input selects to look for on the TV or remote are: Input, Input Select, EXT, AUX, or a channel such as 00 or 99.
I hope this will help .
Mar 23, 2010 | Nintendo Wii Console
When I try to connect a Wii console to my LG television, I put the connection in AV2. But then I get the message that there's no LG signal.
Using the yellow, white and red audio/video cables connect to the side panel of your LG TV and switch the Wii console on. Then press input button on remote and select AV 3 then OK and you should see Wii Menu.
Jan 04, 2010 | LG 37LH30 37 in. LCD HDTV
Moving from Ireland to Canada with Wii and DVD Player
Is it a new TV? I am not familiar with the Ireland/Canada signals. But it could be a PAL/NTSC conversion issue.
Jan 01, 2010 | Nintendo Wii Console
Dear Sir / Madam, I bought my Wii in the UK, however we have recently emigrated to Canada and we brought the Wii with us. I have bought the correct power lead and the Wii starts up as usual. The program...
There may be multiple problems with your nintendo wii if there is no picture showing your AV cable may be broke i would buy a new one if thats not it return it buy a AV cable somewhere where there is a loose return policy if this doesnt work i believe UK and Canadian electric outlets are different. And yes if none of these solutions help Canadian games can be played on a UK console. I hope this helps your problem
Dec 23, 2009 | Nintendo Wii Console
Bought a Wii and using the standard cables it played great on a new 50' Panasonic Plasma as well as on our 2 year old 32' VIZIO LCD. Just upgraded to a 46' Sony LCD (W series) and the Wii looks terrible...
The Wii can display on a HDTV, but keep in mind the output is only 480p. It is not true high definition, and it will only display this using a component video cable. There shouldn't be a difference with LCD and plasma.
You will also need to go to the display settings to force the Wii to display in 480p.
Try a different input (safe to assume your Sony has multiple?) and see if it is that specific input. Also, try a different device like a DVD player or VCR and see if you get the same result.
Good luck.
Dec 07, 2009 | Nintendo Wii Console
Can hook up my wii to this tv
The AV Multi Out plug that is included with the Wii will allow you to connect the console to most televisions or video cassette recorders (VCR). First, look at the back of your television AND your VCR and see if you have colored holes label "Input". Though most TVs have them, almost all VCRs do as well.
  • Audio/Video (AV) inputs are located on the front or back of the TV or VCR.
  • They are smooth silver posts with the inside showing a color, usually red, white and yellow.
  • Look for inputs marked Audio and Video IN.
  • The image on the left features stereo audio inputs. Some televisions have only one audio input. Click here for help setting up a mono audio connection.
  • Do NOT connect your system to anything marked OUT.
Where do you have these inputs?
Additional Options:
Connecting to a Television
  1. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console. setuptvav.gif
  2. Insert the RCA plugs on the Wii AV Cable into the input connectors on the TV. Plug the colored connectors into the following inputs:
    Interested in playing your games in Dolby Pro Logic II (simulated surround sound)? Click here setup information.
  3. Once the cables are inserted and the Wii is powered on, you must find the Input Select for your TV to view the game (it is likely not going to be seen on Channel 3 or 4). Typically this is found by pressing the TV/Video button on the Television's front panel or remote control. If you have more than one input channel, keep pressing TV/Video until you see the display from the Wii.
    Still can't find it? We have compiled a list of known input selects for many popular brands. Click here to see our list.
    Go to Next Step (Set Up of the Wii Remote) >
Connecting to a VCR, DVD-R, Cable Box, etc.
    In order to connect a video game system through a device such as a VCR, DVR, cable or satelite box, it must have Video and Audio "inputs." While most VCRs and VCR/DVD combos have these inputs, other devices typically have "Outputs" which will not work for playing your Wii console. Please verify the device you are attempting to use has these holes.
    While many cable/satelite boxes and DVRs may have "inputs," accessing them can be difficult. Please consult the instruction manual for the device you are connecting to, for more information.
  1. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console. setupvcrav.gif
  2. Insert the RCA plugs on the Wii AV Cable into the input connectors on the VCR. Make sure you are plugging the connectors into the holes labeled"Input" or "In". Holes labeled"Output" or "Out" will not work. Plug the colored connectors into the following inputs:
  3. Once the cables are inserted and the Wii is powered on, put your TV on the channel you use to watch movies (usually channel 3 or 4). Put in a video tape and play the movie. When you see the movie playing, press stop (do not power off the VCR!) and proceed to the next step.
  4. You will now need to find the Input Select for your VCR. This is usually a button on the original remote control that is labeled Input Select, AUX, Input, EXT, Line In, or a high or low channel. For more information on locating your input select, click here.
Nov 26, 2008 | Video Game Consoles & Games
Europran wii
Wii consoles are region-specific and different regions also use different television standards.
You have potentially three problems:
  1. Wii consoles are region-specific. Games for US/Canada won't work in a European Wii
  2. European Wii consoles output PAL video signals. US/Canada/Japan TVs except NTSC video signals.
  3. European Wii consoles likely require 220-volt power. US/Canada/Japan is 100-120-volt power.
So now your solutions for each:
  1. You need to get games from France (or at least Europe)
    You can also look into a device called the Freeloader, but I'm not sure if it works with Wii games yet (the original allowed Gamecube consoles to play games from different regions)
  2. You'll need a multi-standard TV, or a television standards converter. Tourist-y camera shops often sell converter boxes. You need to convert from a PAL video signal to an NTSC video signal in order to connect it to your TV.
  3. Check the power adapter of the Wii. If it lists "110-240 volts" or "100-240 volts" (at least a voltage number in the 100-something range) on it, then the power supply will work and you just need an international plug adapter. You can get these from most travel stores and electronics stores.
    If the power adapter does not list a voltage in the 100-something range on it, then you will need a step-up transformer - that will convert power from 120-volt to 220-volt or 240-volt. The transformer may or may not have the right type of power receptacle, so you may also need a plug adapter. Check your local electronics store for this. Tell them you have a device from Europe and want to run it on your local electrical power. They should know what you need. If you have a choice, get one that is designed for computer or laptop use, as the cheaper ones provide "dirty" power which is fine for hair dryers and such, but bad for electronics.
Hope that helps...
Apr 02, 2008 | Nintendo Wii Console
Video Game Consoles & Games Logo
60 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
