Question about RCA F27252GY 27" TV
I have an old RCA XS TV and cannot figure out how
I have an old RCA XS TV (F27251WN) and cannot figure out how to switch from cable to video input. HELP!!!
    President:
  • 1,284 Answers
Alot of the older RCA chassis required you to press 00, 91, or 92 to get to the external video input.
Posted on Oct 03, 2009
I've been living out of a hotel for about a month now cuz of work and I like to chill and play xbox. U can't always get a room with a flat screen and I didn't know how to get to the cbannel, so thanks, for me it 00.
Posted on Jan 15, 2012
How do I hook up my Toshiba DVD player to my old Daewoo Tv /vcr combo
what inputs does the old Daewood / VCR combo use is it RCA and Video cable on an AV input? How many Av inputs are there in TV ? Does the DVD player have AV out audio out (Yellow) RCA (Red and White). If you do not have enough AV inputs on the Tv use an AV switch box . and Switch two AV RCA inputs /DVD and VCR and into one output to the TV. You may be able to feed the AV out RCA out into the VCR AV in and switch the input on the VCR.
May 25, 2015 | Toshiba Televison & Video
Bought a ROKU XS needed a RCA CRF 907 TO CONNECT TO MY OLD SONY XBR 55' TV..DIDN'T HAVE ANYMOR
Hi, after a lot of searching I found all your bits but not too sure on the TV itself as it's not showing connections on the rear.
However as far as I can see, based on the device and your question, it looks like the standard old style coax goes from the CRF 907 TV OUT socket to your TV's ANT. IN socket.
I hope this helps.
May 05, 2017 | RCA Crf907 Compact Rf Modulator
Cant figure out how to hook up the receiver to my phillips hi def tv and get the sound?
its old model, will not pass hd video, good only for audio. Connections depend on your equipment. If you use a cable box to watch tv, connect cable box audio out rca connectors (red and white), by an audio rca cable, to audio TV input on the back of the receiver. Now when you swith your receiver to TV input you get sound from cable box trough your speakers.
If you use DVD player: connect audio out of the player to dvd audio input of the receiver. Switch the receiver to DVD input, you have sound from DVD.
Jan 08, 2011 | Denon AVR-1403 Receiver
I have a RCA XS Stero TV. I don't have remote. I connected DVD player right connections. But I am not getting any picture in the Screen. Actully it is showing Blue screen all the time. No TV picture also....
Sounds like you're stuck on..... Video 1 or Video 2 (whichever). If you can access your TV's menu at the front panel, you should be able to switch over fairly easy. Hit MENU. Using your VOLUME UP & DOWN buttons, Go to CABLE/SATELITE/ANTENNA, hit VOLUME UP or DOWN 'til it switches back to TV picture then hit ENTER. If you do not have an access panel in front but possibly have any other remote (cable or satelite or home theater, etc...) that can be paired with this TV and has an INPUT button, you can change the setting that way.
Hope this info was helpful. Good Luck!
Jan 29, 2010 | RCA Televison & Video
Must hookup DVD-VR375to tv,cablevision box & MSNtv2.
Here's How:
  1. The first step to connecting a DVD Recorder to your TV is to determine what type of connection you want to make between the TV source (Cable, Satellite, Antenna), the DVD Recorder and the TV. This is usually determined by the outputs and inputs available on the DVD Recorder and the TV.
  2. If you have an older TV that only accepts RF (Coaxial) input, then you would connect the RF output (a coaxial cable) from your TV source (in my case a Cable Box) to the RF input on the DVD Recorder. Then connect the RF output from the DVD Recorder to the RF input on the TV. This is the most basic (and lowest quality) option for connecting a DVD Recorder to any TV.
  3. If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
  4. To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
  5. To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
  6. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
  7. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
  8. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
  9. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
  10. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
  11. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Jan 20, 2009 | Air Tools & Compressors
Rca F27251WN TV
you mqay need a video converter because it is in another country
Jun 22, 2008 | RCA F27615 27" TV
Setting up to tv
ok which rca tv do you have.....its better figured out..you might need a adapter if you dont have video/audio input slots or whatever but if you do have those..all you need is A/V cables "yellow white red" but if your tv is old then you might need to look for an adapter it changes A/V cables in to the regular tv cable...cable cable...i dk what they are called..but yeah
Jan 02, 2008 | Durabrand DVD-1002 DVD Player
Setting the tv up
..yeah i copie it from the earlier one cause its pretty much the same dif
Nes Nintendo Channel Trouble
are you using a/v (audio/video cables with rca ends), or direct to cable input on t v.? if direct to t v, did you check ch switch on back of system deck? otherwise is t v programmed for the correct INPUT. T V, AV1. AV2. OR AV3? ANOTHER PROBLEM WITH OLD NES IS YOU MUST CLEAN THE GAME EVERYTIME YOU INSERT IT. TO CLEAN MIX ALCOHOL/WATER 1-1 AND USE QTIP. RUN IT UP AND DOWN BOTH SIDES OF CONTACTS. IT WILL DRY RIGHTAWAY.
Sep 19, 2007 | Nintendo NES Console
RCA F27252GY 27" TV Logo
543 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
