Question about Lexicon Lambda Usb Desktop Recording Interface Sound Card
I change computers, I am trying to run my Lambda / Lexicon on Vista ( previous computer had XP).I plug in my Lambda and nothinghappens ( I expected the Cubase automatic dowload). What should I do (my previous computer is broken...)
    President:
  • 2,666 Answers
You'd be better directing your uestion here
http://www.lexicon.com/support/index.asp
Posted on Oct 03, 2009
Lexicom Lambda is not working! New user
right click my computer goto properties-harware-device manager then right click the lambda click update driver browse it with ur cd driver...hope this help
Jan 21, 2008 | Lexicon Lambda Usb Desktop Recording...
I am totally lost!! All I have is the lambda lexicon and cubase LE4 on my desktop.Apparently it is not set up correctly. I want to record guitar and voice I have sound on lambda through mike and guitar but...
All it needs is a USB connection. You'll need to go into Cubase device setup and make sure your lambda drivers are selected. Then create the audio channels in cubase with the inputs set as the inputs you're using for guitar and mic. There is a monitor button right next to the record enable button that needs to be enabled if you want to hear playback from your computer.
Feb 20, 2010 | Lexicon Lambda Usb Desktop Recording...
Driver
The only thing I can think of is that maybe you have installed xp drivers and software instead of vista software the vista software can be downloaded from the lexicon Lambda website.
Aug 08, 2009 | Lexicon Lambda Usb Desktop Recording...
No Power to the lambda
Make sure the usb socket is working ,the lamda takes current from your computer.Don't use a usb hub.Make sure you are using xp service pack 2 or higher.Try another usb socket.
Jul 14, 2009 | Lexicon Lambda Usb Desktop Recording...
Lexicon Omega will not play any sound on Windows XP
one of several install steps (the steps seem to vary depending on which manual you can find) mention checking your sound device setup in control panel. ON one machine I installed the sound devices were not affeted. On a 2nd PC they were changed from drivers installed with PC to the Lambda driver
Win XP settings->control panel->Sounds and Audio Devices then select Audio tab. Make sure the three areas are set up to use your PC's default drivers and not lambda's.
You may need to verify this again when reconnecting the Lambda USB cable. Sort of new but ran into this "issue" as well.
Found info in Lambda Studio Software Installation Guide I downloaded, step B following driver install.
Nov 21, 2008 | Lexicon Lambda Usb Desktop Recording...
Sometimes power comes on and sometimes it does not.
Are you running Vista? Lexicon is working on some firmware and software updates to fix the problem. The only workaround is to unplug and replug your USB cable when it stops working. As long as you are actually using the Lambda, it should work.
Oct 30, 2008 | Lexicon Lambda Usb Desktop Recording...
Lambda lexicon sound problems: is vista the cause?
I have had the same problems with the lambda driver ...they just posted a new installer on the lexicon website which fixed me up...try it.
Jul 16, 2008 | Lexicon Lambda Usb Desktop Recording...
My Lexicon Lambda is not working
Go to your devices tab click on the ASIO driver Lambda and when you get that message click reset and try again it should work.
Lexicon Lambda Usb Desktop Recording Interface Sound Card Logo
281 people viewed this question
Top Lexicon Computers & Internet Experts
Marissa Umali
aftab Nawaz
aftab Nawaz
Gareth Cockram
Gareth Cockram
Are you a Lexicon Computer and Internet Expert? Answer questions, earn points and help others
