Question about Frigidaire Washing Machines
Washer is drippinf on inside while not running
    President:
  • 1,185 Answers
Fill valve is not sealing correctly and needs cleaning or replacing
Posted on Oct 03, 2009
Nd error code, what does this mean
ND stands for No Drain.
It means that either your drain is plugged, the piping inside your washer to the drain pump is plugged, your pump is damaged, your control panel is damaged or a combination of the above.
If you can hear your drain pump operating, you should check for blocked piping. If you have water in the washer, unhook your washer hose from the back of the washer and lower down to the floor to see if water drains from your washer. If little water runs out there is a good chance that the hoses inside your washer are plugged with something. If water runs out freely, then there is a problem with your pump that will not allow it to pump water up to your drain hookup.
Oct 04, 2014 | Samsung WF220AN Washer
Machine lights come on but the washer will not run
the drum is probably damaged or stuck inside the washer. or the belt the goes round the drum inside has probably snapped off.
Mar 10, 2012 | Frigidaire ATF6000ES Front Load Washer
I haveno idea how there continues to be water run inside the washer after the cycle runs through. I have even shut the water off and there seems to be water still running inside,
Turn off your hot and cold water valves. Your water valve inside the washer has gone bad. What happens is the valves open and close there is suppose to be a filter screen on both hot and cold inlets where you connect the water hoses to. If not the debris from the water line gets in there and clogs it up leaving the valve open which is causing your problem. Also seen it where people on well water have this problem a lot because the water might be hard with sediment . You can have a qualified technician come fix it won't be too expensive hope this helps and thank you for using FixYa!
Jan 27, 2011 | Maytag Neptune MAH5500B Front Load Washer
How do you clean the inside of your Front Loading washer?
This can be accomplished by running the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
Oct 09, 2009 | Kenmore HE2 Plus Front Load Washer
MOLD REMOVAL FROM WASHER RUBBER BOOT
Try this:
Run an empty load and as soon as water has filled and the washer begins to run, open the washer door (probably have to pause the washer via the control panel) and add 3 - 4 cap fulls of regular bleach. If you don't have regular bleach, you can try vinegar. After cycle completes, open washer and wipe the entire gasket with an old towel.
When washer is not in use, prop the door open so the inside can fully dry.
Please report back here with the results and if you are still having problems, we can take the next steps if needed.
Aug 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
Hot water running into washer continuously.
Yes there is it is the water valve the part that your hot and cold water hook up to.You will need to replace that part Hope i helped:)
May 11, 2009 | Washing Machines
Washer won't drain
Yes Get a space heater and run it by the frozen pipe. Turn off all electricity to avoid shock and it should break free by the morning. Run it at a drip from now on during really cold night just like the sink but set washer on DRAIN this will help. Good LUCK
Dec 07, 2008 | Kenmore 44042 Front Load Washer
2000 navigator radio coming on with truck off lights going on
there is a short in the radio it self replace it
Nov 27, 2008 | 2000 Lincoln Navigator
Washing Machines Logo
23 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
