Question about MSI K8T Neo-V Motherboard
Need an image, back of k8t neo-v mainboard or can someone tell me if there is a resistor near the ram slots on the back of the board. if so what resistance is it
  • 44 Answers
SOURCE: cpu speed
You do not mention the CPU name, but if the CPU is a Semprom 3000+, then 1.8Ghz is the correct clock speed for the chip.
The "3000+" is what is called a "performance rating" - It is NOT the chips clock speed in GHz.
Look here: http://en.wikipedia.org/wiki/Sempron
If you want faster, then you would need to overclock.
Posted on Dec 30, 2007
map9966
  • 2351 Answers
SOURCE: msi motherboard for model k8t neo ms 6702
Its the model numbers that vary the most when looking for the manual. Click on the link below to open MSI download site;
http://www.msi.com/index.php?func=searchresult&keywords=K8T+NEO&table=download
While on MSI's site I searched for MS-6702 and left out the term, "K8T NEO". MSI provided the another link; http://www.msi.com/index.php?func=searchresult&keywords=MS-6702&table=download
The model numbers K8T Neo-FSR and FIS2R, use the same manual.
See link; http://www.msi.com/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=565
K8T Neo2-F and FIR use the same manual.
From the pic included, Connect everything to JFP1. Connect the speaker to JFP2.
b972b2a.jpg Wire colors do vary from case to case. Normally solid colors like red, green, blue and dark blue are used as positive. White and black are negative. Each jumper pair will share a common color. That common color is negative except when hooking up the speaker wire. Black is used for negative.
Cheers!
Mike
Posted on Oct 25, 2009
  • 218 Answers
SOURCE: MSI K8T Neo 2 not recognize Hitach 1 TB Sata
This is a quote from VIA:
"CHIP FIRM VIA issued a note to its customers telling them of problems with chipset support for hard drives using the Serial ATA II standard.
It said that VT8237 and VT8237R chipsets don't provide forward compatibility for S-ATA II, which is important as hard drive makers are beginning to manufacture this type of drive.
But Via is readying the release of VT8237R Plus, which will solve the problem. This means that motherboard makers that use the former chipset should clear their inventory before September.
Hard drive manufacturers position with S-ATA II is as follows, said Via in its note. Western Digital and Samsung are already shipping these devices, while Seagate and Maxtor will start shipping them during this quarter.
If you connect S-ATA II drives to an old Via chipset which includes the VT8237, VT8237R, VT6420 and VT6421L, the devices won't be detected.
Some mobo makers, such as Epox, have already responded to the problem and have warned their customers to seek the support of hard drive vendors. In a letter to its customers, it said that they should also check the specs of other manufacturers' Via based motherboards."
Posted on Jan 11, 2010
Testimonial: "Thanks for quick explanation! Now I can return the drive."
  • 69 Answers
SOURCE: mainboard drivers for MSI k9N Neo v2 for Windows
type in the mobo mdel number in google it'll take you straight to it
Posted on Feb 24, 2010
map9966
  • 2351 Answers
SOURCE: How would you know what type K8T Neo of
The manual is mostly the same.
MSI K8T Neo is also, MS-6702 (v1.X) ATX Main board. You'll find K8T Neo printed just in-between the first and second PCI slot.
In-between the second and third PCI slots you should see, MS-6702 ver 1.0 (Printed in white). All 5 models use the same chipsets. VIA K8T800 PRO Northbridge and VT8237R/Plus Southbridge. K8T Neo-FSR/ FIS2R Socket 939 use the same manual.
K8T Neo-V V2.0 uses a socket 754 CPU.
K8T Neo2-F V2.0 Also uses socket 754 CPU.
K8T Neo2-F-FIR Uses a socket 939 CPU
So open the link provided for drivers, bios ECT;
http://www.msi.com/index.php?func=searchresult&keywords=K8T+Neo&table=download
The most noticeable item is the SATA ports. From 2 ports and up to 4 ports. In different locations on the MB.
Did you find this helpful?
Mike
Posted on Jun 20, 2010
Necesito manual de instalacion de k8t neo-v
Follow this link;
http://www.msi.com/product/mb/K8T-Neo-FSR--FIS2R.html#/?div=Manual
Oct 01, 2012 | MSI K8T Neo-V Motherboard
How would you know what type K8T Neo of motherboard you have mine just says K8T Neo
Mike
Jun 19, 2010 | MSI K8T Neo-FSR Motherboard
Upgrade
According to motherboard manual (p. 2-9), it can support upto 2GB of DDR400 RAM int total. You can get the manual from http://www.msi.com/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=565.
Dec 21, 2009 | MSI K8T Neo-FSR Motherboard
I accidentally hit F11 Flash memory when restarting my PC that has an MSI K8T Neo motherboard and now there is no action or display - how can I restart my PC?
For that pull cmos cell from motherbord for 10 minutes so all settings are defaults.CMOS cell is round cell on motherbord.
Refix RAM memory.
Then check .
Let me know if you need more assistanse.
Thanks.
Sep 26, 2009 | MSI K8T Neo-FSR Motherboard
Drive the motherboard
This is your Mainboard driver
MSI K8T Neo V (MS-7032)
Direct Download :
VIA 10/100 LAN Drivers
XP :
Vista :
VIA PIDE/SATA RAID Drivers & Utility
XP :
Vista :
Realtek ALC Series AC97 Audio Driver
XP :
VIA Chipset 4in1 Drivers
XP :
Vista :
VIA VT8237(R) SATA RAID Driver (For floppy driver)
XP32bit :
AMD Cool and Quiet Driver
• AMD Athlon™ 64/Sempron™/Turion™ 64/Opteron™ systems with ACPI 2.0 processor performance control objects
• WinXP WHQL pass
XP :
May 08, 2009 | Intel Motherboard
K8T Neo ,m/board
Thanks to those who responded, . I eventually found the correct place on the MSI Global web site and downloaded the correct manual for the K8T Neo motherboard. Simple when you know how, erm ... and where. Thanks again,
Apr 28, 2008 | Intel Motherboard
MSI K8T Neo-V Motherboard Logo
53 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
