Question about Logitech 250 Headset
Not Compatible with Xbox 360 controller
If I try to use the headset with a 360 controller at te same time, all of the sound becomes "buzzy", even after I switch to speakers or restart the computer. I have to use regedit to change full duplex and half duplex values back to normal. Problem is, I cannot remember the path to the registry values I need to edit, and I was wondering if there were any easier solutions.
  • nixster Jan 10, 2008
    Same problem... Nobody knows a fix? He means he hooks his usb headset ans usb 360 controller into pc at same time and controller effects headset with wierd buzzy robotic sounds.
He's hooking both up to his computer VIA usb at the same time.
Posted on Feb 05, 2008
How could you have hooked it up to a 360 controller? this headset is USB.
Posted on Jan 07, 2008
Datel game talk xbox 360 wireless headset shuts off.
I have the same exact problem , BUT I did a little trick and it worked somehow, the problem that I had is that : when you turned the headset off by pressing the power button. It won't really go off, you can still hear the sounds from your Xbox, even that the Xbox show you that its disconnected , there will be no logo for the headset when you press the Xbox button on the controller.
Here is what I did to really turn it off.
First you should adjust the "Master Volume " wheel to the end. I mean move it like you are decreasing the volume to the least. so there will be No SOUND. after that hold the power button, and it will really turn off this time , for real.
Hope it worked for you :)
Oct 18, 2012 | Datel Xbox 360 Game Talk Wireless Headset
My son has a xbox360 and were trying to get xbox live to connect and it wont we had it working just fine on his brothers hes not home so we hooked it up to the other xbox 360 and it wont connect
1 Disconnect all accessories and wired controllers from the Xbox 360.
2 Hold the "Guide" button down for three seconds on any wireless controllers, then respond to the prompt on your television screen to disconnect the controllers from your system.3 turn on the wireless headset by pressing the "Power" button in the center of the earpiece. 4 Press the "Connect" button on the front of your Xbox 360 system. 5 Press the "Connect" button on the wireless headset. The ring of lights around the power button of the Xbox 360 system should spin and blink once. One of the lights should remain lit up, indicating the port number that the headset is using. If you do not see any lights on the system, you may have a faulty wireless headset.6 Press the "Guide" button on your wireless controller to reconnect the controller to the Xbox 360 system. If you are using a wired controller, you can plug it back into the system.7 Press the "Connect" button on the top of your wireless controller to sync the controller with your system. You should see the connection light around the "Guide" button on the controller light up, indicating which port you are connected to. You should also see a corresponding port light in the ring around the power button of your Xbox 360 system 8 Press the "Connect" button on the wireless headset until the port light on the headset matches the light on the controller and Xbox 360 system. For example, if you are the first player, the light for port number one should be lit up on the Xbox system, the controller and the headset. When all lights correspond, your headset should be properly connected.
Sep 29, 2011 | Microsoft Xbox 360 Console
My turtle beach headset doesnt work in my turbo fire 2 controller.
Unfortunately Turtle Beach made and tested their headsets with only the official Microsoft brand Xbox 360 controllers and therefore their headsets actually aren't compatible with all types of third party controllers. The Turbo Fire 2 is one of the controllers that the Turtle Beach headsets are not compatible with.
Hopefully this helped!
-although I'm sure this isn't the news you wanted to hear.
May 16, 2011 | Video Game Consoles & Games
I can talk to other people but they can hear me somtimes when i twist the plug i can hear them for a secend then i cant
Sorry dude, but it's really sounding like you got a bad headset on your hands. I'd test it on another controller, and if it still happens, then its definitely the headset. If so, just call Microsoft with your serial number and tell them what happened and they will replace it for FREE! The number for their customer support is (800) 469-9269. I've used it many times, and they've replaced 2 of my broken controllers! Good luck!
Mar 08, 2011 | Microsoft Headset for Xbox 360
Xbox 360 Controller: Headset jack on my Xbox 360 wired controller isn't...
try taping it down.
If this doesn't work, you're probably stuck buying a new headset.
May 16, 2010 | Microsoft Xbox 360 Controller
I can't hear my friends but they can hear me on my xbox headset
The default Microsoft Xbox 360 headsets are very faulty.
You will probably be stuck buying a new one, or may I even such a higher-class headset such as the Turtle Beach.
www.bestbuy.com is an example retailer of such product.
May 12, 2010 | Microsoft Headset for Xbox 360
New Controller wont work with Headset
try to reset button on the both side (xbox and controller))
at same time it will work
for xbox reset buuton on the side censor
for joystick above the battery
Feb 13, 2010 | Microsoft Xbox 360 Wireless Controller
So i have a green xbox 360 controller and a white one. My wireless headset will sync with my green one but when I try to use it with my white one, it is recognized as player two and not syncing with the...
hi there,
just a quicky...but ur wireless headset dosnt sync to the controller it syncs to the xbox :-)
it dosnt matter which controller you use its synced with the xbox & not the controller !
if ur using 2 different controllers depending on which you switch on first will take player 1 as will the wireless headset. if after you have switched it on (the xbox) you decide to use the other controller it will obviousley take player 2 slot (even if you switch the other controller off first) as will the headset !
hope this helps :-)
Feb 13, 2010 | Microsoft Wireless Headset for Xbox 360
Xbox 360 Controller and USB Headset Conflict
Go to control panel, sound and audio, hardware, USB devices, and disable it. The computer thinks the XBox controller is an audio device and is giving it priority.
Aug 26, 2017 | Logitech 250 Headset
Logitech 250 Headset Logo
116 people viewed this question
Top Logitech Radio Communications Experts
Bharat Das
Bharat Das
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
