Question about Gateway MX7122 Notebook
Borken on/off switch. It is down and will not
Borken on/off switch. It is down and will not come up. it is as if a spring is broken in the switch. It will not turn on.
Please sell it for me your laptop gateway mx7122 my email is rahel_habte@yahoo.com.
Posted on Mar 11, 2010
My '94 geo tracker manual shifter keeps popping out of its housing but will shift when pushed back in place. How can i fix this?
that's easy the stop bolts left and right are missing, bad, borken
or mangled. (not photos posted. so damage, is "anything"
suzuki sells these special, harndend shoulder bolts.
part ID 36 times 2.
see it here.
http://www.fixkick.com/buy-parts.html#5sp-shift
the upper shell twist clocks down on to those 2 special bolts.
its spring loaded if spring not broken.,
the spring his hidden and captive for ever in the stick.
replace part 27 for clean shifts, (like new car)
Mar 25, 2015 | 1994 Geo Tracker
My D40 rolled off my couch and broke my flash. After watching a video, I opened up the flash and got the flash working, but now the flash won't pop up... After messing with multiple pieces (while reading...
Check to make sure the flash up switch on the side of the flash (the switch you see where the wires go through when you remove the flash top) is not under the activation rod on the pivot, the pivot is not pushed in, or the activation rod is not broken off. The switch should close when the flash goes up and be open when it is down. A lot of times you see the top contact stuck under the activation rod. Also check the continuity of the two thin switch wires as sometimes they are borken inside by impact
Sep 01, 2013 | Nikon D40 Digital Camera with G-II 18-55mm...
Hinges broken, power supply borken, bottom case replace
And you question is? Sounds like you need a new laptop.
Feb 27, 2013 | Computers & Internet
Switch on 1987 toyota pickup cool to heat broken
Tear it apart and see what is borken is all the advice i can offer.
Nov 01, 2012 | Toyota Cars & Trucks
Window stuck
Power Window: If it's a power window check to see if there is power coming from the window switch with a test light or multimeter. If power is coming from the switch, look in the door where it pivots and check to see if any wires are cracked or broken. If there is no borken wires, then it's possible that the power window motor is not working. If you hear the power window motor working or operating it's possible the window regulator is broken or binded up
Manual Window: If it's a manual window, take the door panel off and check the regulator (part where the window is attached) and looked for any signs that the cable in the part has come free or binded up. Try to roll window up and down to find any signs of the broken cable. If that is the case, then you need a window regulator.
Jan 07, 2012 | 2007 Suzuki Swift 1.3
Fuse blew as garage door was closing.Door slammed shut ,now only goes up 2inches then closes when switch touched !!!
Sounds like it may be a broken spring. Look above the door at the coils on the steel rod and see if there is a separation of the torsion springs. Or if extension spring it will be hanging down on one side above the tracks. If it is a broken torsion spring I would advise calling someone with experience. If not what is the make and year of opener?
Aug 16, 2011 | liftmaster Chamberlain Garage Door Opener...
Head lights stop working from the light switch my turn sig. button still work.
check your connection, bulbs, wires and fuses. its pretty easy just look to see if the philement in your bulbs are broken if so just get bulbs and put them in. and look at your fuse if the metal is borken get a new fuse to put in. you can also follow your wire and if there is any dry rotting of slice but a new wire and run it from your battery to your bulbs. hope this helps you
Jun 30, 2010 | John Deere Garden
Slide projector will not advance the circular slide tray
Took projector apart and replaced borken spring
Dec 23, 2009 | Cameras
Hood cable is borken can get hood open
if its broken at the handle inside the car use a pair of pliers to pull the silver cable if it is broken outside the car there is a black plastic shield on the underside of the car, remove it and the lack will be visible use a screw driver to release latch
Apr 13, 2009 | Buick Park Avenue Cars & Trucks
Latch on batterey door is borken,
here is Vivitar's USA number: (800) 592-9541. They should have what you need
Jan 09, 2008 | Vivitar ViviCam 4100 Digital Camera
Gateway MX7122 Notebook Logo
78 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
