Question about Dell InspironTM 1501 Notebook
Bottom right corner of the LCD screen is very hot
I have changed the inverter twice. The screen bottom right corner gets very hot in a very short time. The inverter is not so hot but the screen corner actually burns my fingers. The screen is out of the laptop, so no bad contacts.
The screen is working fine, but it gets dark in the hot corner. It is a Samsung LTN141WD-L01 from a Dell Inspiron 640m.
Can I change something, inside the screen, like the backlight? or shall I try to find a new screen? Thank you for your help
    Guru:
  • 830 Answers
I would first search the internet and Dells website to see if there is a recall on this item. If there is, they will replace for free.
Changing the inverter in screens always seems to complicate the LCD. I prefer to just purchase a new screen and everything works great. I replaced an inverter on a couple and had to change them again and again do to them slipping.
Replacing the screen is a bit more expensive but will save you time and money in the long run.
Posted on Oct 03, 2009
Horizontal lines and black spot in corner of led tv
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Aug 09, 2016 | Samsung Televison & Video
How do i replace the backlight on my sony vgn-fj1s
It's much easier to just replace the screen than trying to replace the back light. Save yourself the trouble and buy a new screen on ebay.
May 02, 2012 | Computers & Internet
First of all, sorry for the mix up on model the model #. I was viewing a problem regarding LG LCD TVs and found your link. My problem is with an LG 42LGX LCD HDTV. It has worked fine without any issues...
welcome to fixya and thank you choosing my service..
OK,that is the most and common problem of all LCD TV...
Usually dim and totally have no back-light is cause of bad inverter board.One of the inverter board is shorted that cause dim light and crackling sounds..
This are the sample images of inverter board.
to make sure that the problem is on the inverter board kindly try to disconnect/unplug it from your TV and power ON then observe if the crackling sounds remain or not..If the crackling sounds gone replaced the inverter board..Also I need to how many inverter board you have? if 2 or more disconnect it one by one to determine if where is the specific faulty inverter board..
Example:
I disconnect #1 inverter still have crackling sounds..next disconnect #2 inverter and reconnect the #1 inverter until you found the faulty one..Note when you doing this make it sure you power off the TV before you unplug or disconnect inverter board because its high voltage..
I need the picture your TV screen..just send it to chesterpendilton@yahoo.com
Regards.
Chester
Jan 20, 2012 | LG 42LC2D 42 in. LCD HDTV
Lap top dark screen, with system working fine. plugged on external vga, it works.
90 percent of the time the problem is the Inverter.
An LCD screen cannot produce enough light by itself. It needs an additional light source.
A Backlight is the additional light source.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp. (Bulb)
Similar to the Fluorescent lamps used in home and businesses, but on a MUCH smaller scale.
(General size is 3 to 5 inches in length, and half the thickness of a No.2 pencil)
An Inverter is used to provide power for the LCD screen, and the Backlight.
An Inverter reduces the power coming from the laptop, for the Backlight.
An Inverter increases the power coming from the laptop, for the LCD screen.
An Inverter is a small circuit board located inside the Display Assembly, behind the Bezel, and usually towards the bottom of the LCD screen.
This is a typical example of an Inverter. It is NOT THE Inverter that you will need.
You have to match the Inverter to the LCD screen. has to be THE Inverter.
http://www.lcdparts.net/InverterDetail3D.aspx?ProductID=2432
Post in a Comment as to the Model Number, and LCVD screen size of your Acer laptop.
(LCD screen's are measured diagonally. From corner to corner)
Nov 24, 2010 | Acer Computers & Internet
I have a gateway m675 and it has something wrong with the lcd screen. In the right hand corner the is a band about 2' wide and runs top to bottom. The colors are inverted looking that area and the tint of...
I would place bet on the LCD going/gone bad. If it works with an external monitor that is about all that is left. Google LCD replacement for screens.
Sep 03, 2010 | Gateway M675 Notebook
Dell 1520 , on start up screen goes black.... top right hand corner of pc is hot. backlight ?invertor?has the screen got a built in ivertor?? then maybe new screen??? help please....
Hi:
The top right corner of your laptop is where the CPU and heatsink/ fan is located. If you can hook up an external monitor to your laptop, you can toggle to it with the function key and the lcd/CRT key. If you get a good display, then you have a bad inverter or possibly the LCD, but you can't do too much more troubleshooting,
Dec 01, 2009 | Dell Keyboard for Inspiron 1420, 1520,...
My 26" Insignia LCD TV will not power on.. the little light on the bottom right corner will change from red to blue but the screen itself will not make any change.
The problem can be in the backlight inverter board or the power supply that supplys the power to the inverter board is bad. The indicator is on because the 5v standby power supply is still working at least.
Nov 01, 2009 | Insignia LCDTV26 26 in. Television
My monitor has running lines
If these lines are colored running up and down the screen then you most likely have either a loose cable if this is a desktop. If this is a laptop or a flat screen monitor this can be caused by a faulty or loose inverter.
On a laptop you can tell if it is loose by squeezing the bottom two corners right below the LCD on the bezel. If the screen changes then the inverter is most likely loose. Same goes for an LCD monitor. If the screen stays the same then the inverter usually needs to be replaced.
Sep 15, 2009 | Computers & Internet
Black corner on laptop screen and burnt smell
The problem you have is caused by a defective LCD inverter.
They really really fragile and the job of replacing them can be quite tedious.
There is not other reason for your screen corner to became dark.
Send it back and tell them that the replaced part is defective or it was not properly installed.
I hope this help you out.
Aug 10, 2009 | Dell Inspiron 8000 (6158u) Modem
Dell InspironTM 1501 Notebook Logo
316 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
