If you have a front loading machine:
You can try to remove the front of the machine, this will expose the drum and belt, remove the drum and belt and this will expose the drum rollers, motor, and idler arm assembly. Then you can remove the motor.
I hope this helps
it just stopped. breaker is fine but no matter what it will not restart? I took out tthe cloths and...
(More)
it just stopped. breaker is fine but no matter what it will not restart? I took out tthe cloths and put them back in, I resett the dial. I pushed the dial to restart but nothing happened. I check the electric box and the breaker is fine. sure seems like it isn't getting any electricity.
Greetings, I have a two year old Roper REX6634RQ0 electric dryer that has been working like a charm...
(More)
Greetings, I have a two year old Roper REX6634RQ0 electric dryer that has been working like a charm until today. When you push the start button the dryer buzzes but does not start and I can feel it get really hot towards the front of the dryer. I have checked what I believe to be the thermal cut out and thermal fuse. I pretty much checked everything that looked like a fuse and had continuity with everything so I don't think its a blown fuse. I have verified the door switch was engaged and there are no obstructions. Any ideas? The thing gets hot, but wouldn't start. A relay maybe? Please be specific on where I can find it or what it might look like please, I am a novice with appliance repair Thanks in advance!
I replaced the motor and it worked fine through a full cycle. Now when I push the start button it...
(More)
I replaced the motor and it worked fine through a full cycle. Now when I push the start button it makes a buzzing sound and does not start. I can hear the timer ticking and the drum turns fine when I manually turn it by hand.
it runs for about 30 seconds and shuts off. I disconnected the vwent and cleaned it but nothing also...
(More)
it runs for about 30 seconds and shuts off. I disconnected the vwent and cleaned it but nothing also tried the remove vent altogether but nothing
