My dell inspiron 5160 laptop doesnt power up and is completely dead, even if i tried with other power adaptor.
Is it the problem with motherboard or battery or any other problem.
Can you please help me in getting my laptop work.
It should power up with the external power supply if it is working properly; you can remove the batteries and it should still work with the external source. If not, then the power section on the laptop is dead and needs servicing.
I have a computer manufactured from ibuypower in california.It is a Fatality Version, Viper Model. I...
(More)
I have a computer manufactured from ibuypower in california.It is a Fatality Version, Viper Model. I was attempting to install a new network card but some wires were in the way of installing the new network card. I tried to stretch them a little but the wires came unplugged. Now I don't know what wires go where.
I have an ASUS P5n-d nForce 7501 SLI chipset w Gb LAN, S-ATA Raid, USB 2.0, IEEE-1394, Dual PCI-EPU Technology motherboard. I need help in re-installing these wires to their connectors. I know I can't guess and if I get the wires in the wrong place, I could burn up the computer. Can you assist please? I have the pin numbers/letter description and the possible wire numbers/lettering and ready to submit this data.
Please help. I tried to call my manufacturer but they will be closed till Monday.
Sincerely,
Allen Williams
Hi, i have ecs motherboard A780GM-A Ultra (V1.0) and when i insert powercolor hd 4730 graphic, some...
(More)
Hi, i have ecs motherboard A780GM-A Ultra (V1.0) and when i insert powercolor hd 4730 graphic, some issues happen, sometime vpu recover, sometime bsod and on another mb (gigabyte) with all same components (HD, PSU,memory),gpu work fine. Is there anything i forgot to set, maybe its a problem that mb has integrated graphic on it?
Where would I get a manual or full spec for a SCI36-r13 Dell motherboard can't find anything on...
(More)
Where would I get a manual or full spec for a SCI36-r13 Dell motherboard can't find anything on their site.
My Dell Inspiron works perfectly fine on the dock. When I use it away from the dock, though, the...
(More)
My Dell Inspiron works perfectly fine on the dock. When I use it away from the dock, though, the power "comes and goes" and the screen flashes dim then bright repeatedly. Eventually I see that my battery is not charging. I have replaced the external power cord and that doesn't seem to help.
