Question about D-Link DIR-615 Wireless Router
How can I boost my signal on the DIR-615 router. I am having a hard time finding my network with my laptop in the same room.
  • clb199
    clb199 May 11, 2010
    simple problem to fix email me at clb199@yahoo.com
    Novelist:
  • D-Link Expert
  • 199 Answers
Login in using your browser and go to the wireless settings. Make certain transmitter power is set to the highest level.
Posted on Jan 06, 2017
SOURCE: how to install d link Dir 615 router
Port opening
Posted on Apr 22, 2009
rtrahan
  • 741 Answers
SOURCE: Cannot connect to DLink DIR-655
The part below is all you need to look at, the rest is Ethernet which is your wired connection, ethernet card.
Here is what are causing your problems from what you gave me and basically your computer is not communicating with the router:
1)I don't see any IP address for your laptop so you can't get on the internet if you don't have an IP address, also, I don't see any gateway address. The gateway address is your router address, and that address is given to the router automatically from your Internet Service Provider.
So if your computer cannot see the gateway address then the gateway address (router) cannot give you an IP address to get on the Internet.
Your Wireless card looks ok, that is the physical address and if you were able to do the loopback then its working.
So on your laptop I would begin from the beginning. Go into network connections and delete the DLink connection if it is there. Then Start>control panel>Network connections>click wireless network connection>click change settings of the connection on the left window>click wireless network tab>make sure checkmark"use windows to configure my wireless network settings>click add a new network>TYPE IN THE SSID FOR THE NETWORK>ENTER WEP/WPA KEY>CLICK OK, then close and you should be connected.
You said other computers are able to access the internet thru the DLINK so it all points to your laptop not being configured correctly.
HOWEVER :)...I see alot of "Media disconnected in your list. Make sure all of the lights are working on the front of the router, if not check the cabling or call the ISP sometimes the problem is on their end. Hope this helps, keep me updated.
C:>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : HPdv7
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Atheros AR5009 802.11a/g/n WiFi Adapter
Physical Address. . . . . . . . . : 00-24-2B-12-FD-63
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Posted on May 03, 2009
  • 1479 Answers
SOURCE: Lost Network Key
an easy way around this is to do a factory reset then set up wifi security using wpa-psk and use the serial number for the pre-shared key.
Posted on Sep 22, 2009
  • 6 Answers
SOURCE: D-Link DIR-615 router
default username and password on the router should be
username: admin
password: *left blank*
Geekman
  • 32281 Answers
SOURCE: How can i put a password to my N router (DIR 615)?
Connect a LAN cable to the router and computer. Open your WEB Internet Explorer and your in the router's URL IP configuration address.
This will be 192.168.0.1 and the default Login = admin and the default password = (blank) just press Enter.
You can now change the default password.
Posted on Oct 21, 2009
How do I connect a Dlink wireless router to a Netgear WiFi Internet adaptor?
Hi there is two way to connect best is to connect via cable ,DIR 615 login to router setting by typing 192.168.0.1 enter user name and password uaser name will be admin and password could be admin or blank or you need to enter text " read the manual to access the router via internet explorer" make sure WAN connection is DHCP connect LAN cable from your main router to the WAN port of your Dlink it should be ready in 1 miutes also if it support WDS you do not cable it can find the main router signal and connect to it and boost it , should you need any help please post me your question to http://computernetworksupportindubai.com/
Jul 22, 2011 | D-Link DIR-615 Wireless Router
My DIR-615 Dlink router always has the Orange globe. How am i supposed to fix this, the modem works perfectly fine as i tersted it without the router and internet works. But my wife needs the laptop and...
In the web interface of dir-615 switch it to router mode, adjust wan connection (username, password... depend on your Internet provider, in fact, it is easier to ask their tech support to provide all necessary information) then configure wireless network.
May 19, 2011 | D-Link DIR-615 Wireless Router
After installing DIR-615 to my desktop, I could go online but my laptop could not get the signal. After key in the code it still keeps verifying the source. How to get my laptop catch the signal?
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
There is a great article at Working with Windows Wireless Networks
If you need more help post back! Thumbs and testimonial are welcome!
Feb 16, 2011 | D-Link DIR-615 Wireless Router
DIR-615 Wireless Router: i have a d-link wireless router dir 615 that i've ...
if youve changed the password on the router since the other computers logged onto the network, then you need to delete the network history from those computers.
Otherwise those laptops will be trying to connect to the network with the old details.
May 16, 2010 | D-Link DIR-615 Wireless Router
Unable to connect every two days
SSID is the name you give to the network.
A good key is the code you give to the WPA to secure the network.
Yes, get an update for your router to Revision E here.
Try turning your router 90 degrees to the room that has the computer in it. If you are using Wireles 'N', one antenna needs to be further from the computer than the other for best results. Like this:
| | <---- antennas ----------
router ---------------------------------------| Room |
Apr 19, 2010 | D-Link DIR-625 (790069292637) Wireless...
Cant get on the settings page on my DLINK dir-615 router
Turn the router off.
Straighten one end of a Norwegian paper-clip,
and insert it into the small hole in the back of the router,
to "reset" the router to the "factory" settings.
Turn the router on, connect to its built-in web-interface,
and the "default" ID/password should now work.
Change the password.
Rerun the "Wireless Network Setup Wizard",
to recreate your wireless network.
Nov 23, 2009 | Computers & Internet
Connection, via D-Link Dir 615, lost after restarting computer
Did you tell Vista to "automatically connect to XXXXX network whenever in range" ?
Oct 20, 2009 | D-Link DIR-615 Wireless Router
Connected to wireless router, not connected to the internet
Try setting up a new network connection in the Network and Sharing Center. You'll need your info from your router like:
router username:
router password:
network name (ssid):
network security type:
network security key:
connection type:
Some will also ask for a serial id(I've only ever come across one)
I've never used your particular brand of router but it ought to work the same way as far as the setup.
Aug 25, 2009 | D-Link DIR-615 Wireless Router
D-Link DIR-615 Wireless Router Logo
665 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
