Question about Hitachi 43UWX10B 43" Rear Projection Television
RCA F31317 31" TV Turning self off and on then completely off
I just purchased this TV second hand and the people said that it turns off and on every so often like every other hour (hey for $20 I can deal with that), but when I got it home the problem happened every half minute to only a few seconds! The TV would just turn itself off and then back on but after a few times it just gives up and turns self off completely. I already tried the hard reboot and I really don't want to have to take this monster down and up 3 flights of narrow stairs again. Does this problem sound familiar? Any help would be very much appreciated tv turns off/on repeatedly at random it can be cured temporarily by banging the tv
    Problem Solver:
  • 7 Answers
The horzantle power supply is bad probably missing the B+ voltage this is a repair for a tech high voltage
Posted on Jan 10, 2008
Iarp 505 freezer won't go below 20 degrees
turn it off at the wall for 10 minutes
then turn it back on and move the thermostat setting to see if you can feel the compressor start to run
if is is running ( vibrations in the freezer walls ) place a bucket of water in the freezer and set it on close to max cold
freezers need heat in the cabinet to make the liquid gas boil off to a gas and that heat is provided by the water
if the unit is working , the water will turn to ice in a coup[le of hours
could be a problem thermostat
Jan 17, 2018 | Refrigerators
I turn on the tv and i get a blue screen for 5 seconds and the tv shuts off. Any ideas?
Hey bbendure, I have a similar/same same problem! My model is a GV42L.
It has a blue screen that says no signal t, then it turns itself off in about 20 seconds.
Is this the same problem you see?
Oct 09, 2010 | Vizio GV42L 42 in. LCD Television
I have a '03 model Samsung HLN5065W TV that after approx 1 hour, part of the images start turning white. If I shut it off, for only 1-2 minutes, the picture is good for another 15-20 minutes.Occasionally,...
Look on your Power supply board ,it will be on left hand side,Bad Capacitors 330uf 10v 220uf 10v 1000uf 16v if you see any that are swollen,or Puffed up on Top they are Bad replace them and order you another Lamp, I got Mine on Ebay for $85.00 Look under Electronics
Encompass Parts Distribution will have part number on their website just type in your model number and it will list Parts and Prices 1-800-638-3328
Apr 24, 2010 | Samsung HLN5065W 50" Rear Projection...
REDENT PURCHASE OF TV'S Have green in some spots.
This is typically referred to as a color purity problem and can be caused by two main things. The first cause can be stray magnetic fields which can 'magnetize' the TV screen either by something magnetic begint oo close to the screen or having turned the direction of the TV while it is turned on. If this is a purity issue caused by magnetic fields, it can usually be cirrected by powering off the TV for about 1/2 hour and turning it back on. All tube TVs have build in 'degaussing' circuits to cure just this issue.
If this doesn't fix it the other cause is a shifted shadow mask inside the picture tube itself and cannot be corrected.
May 25, 2009 | Televison & Video
Navigon 5100 won't turn on when battery is charged.
try holding the power button down for 15 to 20 seconds - that worked for mine!
Hope that helps
Nov 29, 2008 | Panasonic Navigon 5100
I am unable to find a 12volt computer power cord for a Pro View Monitor I purchased second hand. I even bought a one size fits all deal that did not work. Can you help me.
dear cate
you buying this without a power adapter
but you can buy this separate the type is
Proview SA-769 11 TO 14 Volt AC Adapter
it's price about $ 54 and mybe you can find the second hand about $ 20
oke
cropp
Mar 15, 2008 | Computers & Internet
20" digital flat stero tv moel CR202EM8
It sounds magnetised. Is there a magnet near that side... like a speaker?
It probably needs degaussed. Many TV shops have a device that does this, at a cost to you. Also, the set degauses itself for about a second when it's first turned on after being off for a while. So it may go away by itself eventually.
Hope that helps...
Geno
Feb 27, 2008 | Emerson EWL2005 20 in. LCD Television
Keeps going black and coming back on - green light blinks
Our tv is about 2 1/2 yrs old and did the same thing we had to replace the bulb and bulb driver board this fixed the problem
Jan 27, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Tv does not power on
Do a Hard Reset. Unplug the power cord and cable for 4 hours. If the power protection circuit has taken over the set due to some shorted conditions internally, then the hard reset should allow you to turn it back on but if the condition remains, it will just go into auto off again. This means there is a hardware problem that is locking up the protection circuit. Since there are so many possible areas in the set that can cause this, you will need a service tech to do the hands-on diagnosis for it.
Jul 02, 2007 | RCA 20F512T 20" TV
Hitachi 43UWX10B 43" Rear Projection Television Logo
96 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
