Question about Sony KP-53S75 53" Rear Projection Television
Cant find a bulb for kp 53n77 - Sony KP-53S75 53" Rear Projection Television
    Genius:
  • 1,112 Answers
This unit does not use bulbs, unless you are speaking of one of the CRT's, It incorporates 3 picture tubes commonly known as Cathode Ray Tubes.
Posted on Oct 03, 2009
Tv died and won't turn on or off. standby light is on not blinking. can i fix it?
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Oct 10, 2014 | Sony KP-53N77 TV
I have a sony kp-53n77 rear projection tv i cleaned the lenses but i still have alittle to much red how can i clean up the color
Older projection set:
Not knowing exactly what it looks like I suggest two things: first in the menu look for convergence to see if it is off adjustment wise--it can be adjusted in customer mode to see if that helps.
Also either turn color all the way off (Black and white) to see what color the screen is with no color--if somewhat red you will need to turn the red screen control down--I can tell you where and how.
If screen is too red, red will be the prominent background color with color off or on.
Another easy way to LOOK is go to an unused video input---should only see "Input 1" for example in green and rest of screen should be black and not red to any degree.
Let me know with a comment here what you find.
May 02, 2012 | Sony KP-53N77 TV
We need to clean our Sony KP-53N77. We have some spider webs inside the protective screen and our color is a little fuzzy. We have never had the mirrors cleaned. How do we access the areas to clean and...
Remove the back hardboard cover by removing all the screws and lifting the cover up and toward you.
Mirror will be above but usually doesnt get dusty. Try not to touch it if you can. Same with back of screen. If you have a spider web just use a soft dry cloth to wipe it away.
You will likely find the upward facing lamp lenses covered in dust. Clean these with a soft cloth moistened with glasses cleaning solution. Glass cleaner works too.
Mar 20, 2011 | Sony KP-53N77 TV
What is the bulbs size for the Sony KP-46WT520
That is a specialty bulb. You need to purchace from Sony, online or from a electronics shop. Dont think it even has a size designation on it.
Oct 27, 2009 | Sony KP-46WT520 46" Rear Projection...
The remote control stopped working.
Check the remote lens on the TV for some dust and if present remove it. You can even use some alcohol to remove the dust. You can even try pressing the small reset button on the bottom of the remote after removing the batteries. Use new batteries.
You can get some help on how to repair a remote control from:
http://www.fixya.com/manuals/w153225-repair_remote_control
If nothing helps then you need to get a new remote... you get one from: http://www.newtvremotes.com/Mfrs/Sony/SonyTV/RM-Y906.htm
Jul 20, 2009 | Sony KP-53N77 TV
Sony kp-46wt-500 tv help
if your set has auto focus try activating it if not you require a convergence alignment.
Apr 13, 2008 | Sony KP-53N77 TV
Kp-53n77 color 53
Try resetting to factory settings via tha manual at this link.
It will download onto your computer in PDF form.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KP53N77&LOC=3
Mar 11, 2008 | Televison & Video
Sony KP-53N77 has no sound, no picture. Just a red blinking light.
How many times does it blink? It should blink a series of blinks pause second then blink again if it is in protective shutdown. Try to count the blinks then let me know if ts putting out a code or not.
Jan 24, 2008 | Televison & Video
Sony KP-53S75 53" Rear Projection Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
