Question about Dell Dimension 2400 PC Desktop
It wont boot up. the green light on the motherboard comes on. Only the power light in front blinks no bios or anything. Is there an internal fuse I can reset?
    Guru:
  • 830 Answers
The power supply is out. You can get a replacement off of eBay for a reasonable price.
Posted on Oct 03, 2009
Testimonial: "Thanks I thought if the green light on the motherboard came on the power supply was working. "
I have similar problem and I've replaced he power supply and it still wouldn't turn on. I suspect it's the motherboard that I need to replace now.
Posted on Oct 04, 2009
    Problem Solver:
  • 10 Answers
There aren't any fuses inside. I'd check to make sure the video cable didn't get knocked off of the back of the monitor or tower. I know it sounds stupid, but always check the little things first, then move on to the harder/more expensive reasons.
Dell uses beep codes and diagnostic lights on the back of the PC's in the event of ram or video failure. You can decypher what they are here:
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/advtshoo.htm
If no beeps and the diag lights on the back aren't lit, it's your power supply.
This is a good replacement for $15.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182001
Good Luck!!
  • 835 Answers
First make sure that the ram is fully fastened onto the bored.
you can tell this buy seeing if the little clips on both ends of the memory are fully snapped into place.
If this doesnt work, then its very possible that your hardrive is fried and you will need to replace it.
Toshiba a210: Powers up on both battery and power source. When powered on the caps lock blinks green most of the time but not always. Display does not come on at all, no blinking, flickering, or...
Just out of curiosity, you haven't got a usb device plugged in as you are booting the laptop have you?
If not, try this:
Remove battery, unplug power, hold power button for 60 seconds, turn on computer with power plug only, then shutdown, add battery and restart
If that fails to work, check that the charger indicator light is not flickering, this indicates that the power is not completing the circuit (damaged power capacitors/ fault on motherboard.
Are you using a genuine Toshiba charger, these laptops are prone to breaking down if an aftermarket one is used, a non-genuine one can damage the motherboard as well.
How many blinks does the caps lock make? Flashing caps lock is usually a sign that the Ram may be failing. You can try replacing the Ram modules to see if it boots, also, a dying hard drive will prevent booting, remove and see if that allows the laptop to power up
After that, I'd suspect the motherboard is damaged and will need replacing
Jun 15, 2011 | Computers & Internet
Motherboard problem.
Test the motherboard with nothing attached to it except the monitor, mouse, keyboard and the power button. If you can't still get into the bios then try again with another memory and processor. If it's the same then it's dead, junk it, it's unfixable.
May 19, 2010 | Asrock 775VM800 Motherboard
My xps 420 pc desktop wont boot. Shut it down last
Try and reset your CMOS and see if it helps.
If you're not sure how, then unplug the power cable from your PC, then take off the side panel, on the motherboard is a set of 2 or 3 pins to Clear the CMOS (reset the BIOS) all boards are different, so there is no set location for the CMOS pins, if you're unsure, just remove the battery from the motherboard for about 30 seconds, then replace it ("+" facing up)
But you need to make sure your PS is not plugged into any external power source while you're doing this or you risk deleting your BIOS
Hope this helps in some way.
Jan 01, 2010 | Dell XPS 420 PC Desktop
Cant boot my system
Check all your power cable if they are losened and the memory if is fully inserted
Aug 04, 2009 | ASUS P4SDX Motherboard
Can't boot up Dell 5100 Dimension, amber light flashes
When you mean the amber light, is that the blinking hard drive access light or the power light? Different cases have different colors on it. Mine has blue and green lights.
If you see the boot screen (bios) and then after it goes to boot, does it blink and hang?
This could be a simple operating system issue, hard drive or hardware/motherboard issue. If you could provide more information, that would help.
Jun 28, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Acer Aspire 5520 boot problem power on linght blinks
If you can't get past the bios boot then likely its a problem with the bios settings or a hardware issue on the motherboard. Make sure the processor fan is running when it turns on.
Feb 23, 2009 | Acer Aspire 3100-1405 Notebook
Dell e510 won't make it to post
Unplug computer, disconnect all usb/monitor/internet, open it, hold power button until green led on the inside on the motherboard turns off, pop out the BIOS battery (looks like a big watch battery and use a small flathead screwdriver to depress the spring lock on one side), plug in computer, hold power button for about 20 seconds (must reset BIOS), let up on power button, wait 10 seconds and push power button. The computer should turn on. Wait for it until activity seems stable (1 min. or so). Push powerbutton to shut off.
If this has worked you have proven that it's not the power supply (it turned on). If you purchased a non dell power supply, you might try this with the original one installed.
Go buy a new battery (CR2032 3 volt). Unplug computer, open it, hold power button until green led on the inside on the motherboard turns off, pop in new battery, plug in (you should notice the power button blinking amber again), hold power button until it stops blinking (about 20 sec....again must reset BIOS), wait 10 sec., push power button. the computer should turn on. Wait for it until activity seems stabe (1 min. or so). Push powerbutton to shut off.
Now, close case, plug in all usb/monitor/internet/etc. Power up computer. You'll get an internal floppy drive error. Push F2 (maybe F1) to get into the BIOS settings and go to "drives" and turn off the internal floppy. Save and exit. The computer should boot properly now.
This seems to be a big problem with the e510, my theory is that this one small battery is the root of most of these failures (as these computers usually fail after 1-2 years), not the power supply or the motherboard (heck, when you replace the motherboard it comes with a new one of these batteries...a several hundred dollar piece of hardware, with a $5 battery that will actually fix it).
Nov 09, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
Power light blinking yellow after sitting a while
Unplug computer, disconnect all usb/monitor/internet, open it, hold power button until green led on the inside on the motherboard turns off, pop out the BIOS battery (looks like a big watch battery and use a small flathead screwdriver to depress the spring lock on one side), plug in computer, hold power button for about 20 seconds (must reset BIOS or something), let up on power button, wait 10 seconds and push power button. The computer should turn on. Wait for it until activity seems stable (1 min. or so). Push powerbutton to shut off.
Go buy a new battery (CR2032 3 volt). Unplug computer, open it, hold power button until green led on the inside on the motherboard turns off, pop in new battery, plug in (you should notice the power button blinking amber again), hold power button until it stops blinking (about 20 sec....again must reset BIOS or something), wait 10 sec., push power button. the computer should turn on. Wait for it until activity seems stabe (1 min. or so). Push powerbutton to shut off.
Oct 11, 2008 | Dell XPS 200 PC Desktop
Not booting Up when power on
try setting your BIOS to default as it seems like someone or something has changed settings
Jul 25, 2008 | ASUS P5S800-VM Motherboard
Hp 1270n power problems
Sounds as if your power pack might have a problem.blown fuse ect.I whould remove the cmos battery and or change jumper pin setting to start fresh in the bios settings.after removng the cmos battery,Make sure to put it back in before you re boot your computer. Good Luck garydalel
Dec 29, 2007 | Gateway (4000811) Motherboard
Dell Dimension 2400 PC Desktop Logo
199 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
