Question about Toshiba TheaterWide 62HM84 62" Rear Projection HDTV-Ready Television
Have an old toshiba theater view big screen tv the red light by the power switch keeps bilnking and when you push it, it won't turn on
SOURCE: TV is not powering up and red light keeps flashing
I have the same problem on the same TV - nothing shown on screen, blinking red LED (sometimes slow, sometimes fast), clicking noise of a transformer. I got the TV free thinking I could fix it. It looks like the previous owner has replaced some resistors. Can anyone double check the pic and tell me if the mod is correct or not? PCB is marked PB9582 B Thanks
Posted on Mar 29, 2007
ctf1800
  • 4402 Answers
SOURCE: Toshiba 43A61 - No Picture, no sound
If your set all of a sudden won't come on, e.g., the screen is blank, but the LED on the under the screen next to the on/off switch keeps flashing, then there may be an internal fault on the set that needs to be reset.
To force the reset, try this:
  • Unplug the set and wait a few seconds
  • Replug and see if the video returns
Whenever the set senses an internal fault through its monitoring circuitry, it essentially shuts down the set. The flashing LED provides the indication that a fault has been detected. Removing power to the set resets the monitoring circuitry. When plugged back in, the circuitry again does a check of the system. If it finds that there truly is a problem, then the set is shut down and the LED will again flash. In this case, you need to call a service tech. Most of the time, however, the unplug/replug routine is enough to get the set up and running.
Posted on Dec 11, 2007
ginko
  • 19396 Answers
SOURCE: toshiba 50HX81 projection 'tv- blinking red light
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
ginko
  • 19396 Answers
SOURCE: toshiba 46H84 tv turned off light blinking
  • 13 Answers
SOURCE: TV turns off and power light blinks unpluged andd still does it.
Likely to be the STK convergence chips causing a protection circuit to switch the TV off. Have you got any onscreen convergence problems (i.e, colour fringes)?
Posted on May 28, 2009
How do I replace the on/off switch on the 50" TV?
Sounds like the knob to On/Off switch is broken. It is a very difficult to get part from open electronic spare part market; even though it is very cheap to buy. Contact the authorized service centre for Toshiba. They only can help you in this case.
Sep 16, 2014 | Toshiba 50 Inch Big Screen Flat Tv Theater...
When i turn on the my toshiba theater view tv all that happens is the of/on idicater light just flashes
We recommend you remove the "Digital In" cable connection from the rear of the TV and turn it back on. If the problem persists, we recommend having the TV evaluated by an authorized service center using the below link.
www.panasonic.com/repair
If the TV turns on then we recommend having the Toshiba Home Theater evaluated. Welcome to Panasonic Online Repair
Mar 26, 2014 | Panasonic PT-47WX53 47" Rear Projection...
Toshiba TV won't turn on
Toshiba? Suspect that if it uses a Lamp for brightness (a model number would help) it may have failed----customer replaceable and if remove look to see it is not shattered inside--2 year, 2000 hour life is normal.
Oct 29, 2012 | Sony Televison & Video
The tv seems really dark.57in theatrewide hd toshiba
Go into the tv menu and select the Preferences menu and set your picutre preference from Theater to Normal. The TV is currently in Theater mode, wich is for viewing with no lights on in the room. Switching it to normal lightens the pictue a lot.
May 27, 2009 | Toshiba 57H81 57" Rear Projection...
Turned the big screen toshiba theatre view on, worked good for about 2 min. Then just shut down, not the red power light comes on, but no picture or sound.
water from air conditioner dripped on back of 56in.toshiba big screen.now its has no sound or picture.its been sitting for 2yrs and has had just a good as picture a smy flat panel.every 1 says im stupid for keeping it but iwould like to know if it is doable by me.i believe i could do it if i knew what part i needed.thx
Aug 28, 2008 | Televison & Video
Toshiba big screen tv
I have a 50" big screen tv by toshiba. I need a replacement protective screen or a place I can get it.
Aug 26, 2008 | Televison & Video
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Toshiba TheaterWide 62HM84 62" Rear Projection HDTV-Ready Television Logo
585 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
