Question about Power Acoustik PTID-4003TV Car Video Player
Ipod cable where do i get the ipod cable for the power acustik ptid-5300
  • trueass Dec 23, 2007
    at the store
  • 3 Answers
You can get it at best buy. ill do some lookin' cause i have a pioneer head unit and i just built that cable. i might be able to do the same for you.
Posted on May 15, 2008
How do i power it on without it being hooked up in car
if you have a 12 volts ac/dc adapter you can hook the 3 wires Black for negative, Red and yellow for positive and the stereo will turn on.
Jul 22, 2011 | Power Acoustik PTID-5300 Car DVD Player
My unit is a used unit got the unit to power up and it wont tkae cd's. is there a special way to load a cd or any way you can help
sure you need 2 wires to connect to make it work properly one is bluewire for the romote 2 it's the either pink or bronw connect it to ground for your DVD's and it shouold work perfect.
Dec 27, 2010 | Power Acoustik PTID-5300 Car DVD Player
How do i get the blue parking brake screen off so i can whatch a dvd
Take the parking brake wire from the deck and hook it to a toggle switch on the end of that switch run a switch to a ground. When powering up toggle the switch on and off and your in business
Jul 31, 2010 | Power Acoustik PTID-5300 Car DVD Player
How do i set my ipod to my power acoustik ptid 5300 when i plug it in it just says close
If you bought the correct cable it should work automatically. There are no settings. However, my 5300 was flakey right out of the box and I had to send it in for repair. It works perfectly now.
Jun 06, 2009 | Power Acoustik PTID-4003TV Car Video...
Help i need a wire harness for power Acoustic dvd player
you would have to order it from poweracoustik.com. go to poweracoustik.com then go to contact and there will be a number call it an order.
Jan 24, 2009 | Power Acoustik PTID-5300 Car DVD Player
How can i connect an mp3 player on my Power Acoustik PTID-4007
Expandability Options:
  • 3 sets of preamp outputs (front, rear and subwoofer)
  • Telephone Mute trigger wire for Bluetooth adaptation
  • iPod Ready: IC-1 iPod Connection Cable Required and Sold Separately
  • Front-panel auxiliary input: Mini USB input and SD Card slot
  • Rear auxiliary input: 1 back-up camera input and 1 A/V input
  • 1 Video output
The aux rear a/v input should do the trick.
If it is a component (RCA) type input, you will need a Male 3.5mm to dual Male RCA adapter.
If it is a 3.5mm input, a Male 3.5mm on each end.
I believe you will need the Dual RCA (red/wht) to 3.5mm cable.
The Audio inputs are purple RCAs on the back of your head unit.
Jan 14, 2009 | Car Audio & Video
Region free code for power acoustik ptid-5300
Try the following which i managed to get from POWER ACOUSTIK technical support:
Multi-region for PTID4006T, 406T, 4005, 405, 8006T, 8004, 4003, 5000, 5800, 5300, 530.
1. Turn the unit on and insert a DVD disc. The unit will display LOADING.
2. While the DVD player is LOADING press the following keys:
SET-UP, then press 0, 0, 0, 0 key (0 four times), then ARROW DOWN key (to change the zone to region all 0), then BAND/ENTER key and SET-UP
3. To finish the procedure, push the EJECT key. The disc will eject... Wait and the DVD disc will re-load and play.
Jul 13, 2008 | Jensen VM9510 Car DVD Player
Ptid-5300
Its illegal to watch a dvd/tv when the vehicle is moving so the manufacturer disables the function.. Usually by connecting a cable to your handbrake indicator or to your vehicle speed sensor VSS.
Youll have to find out which one it is. You can then find out how to disable it. JVC's normally ground the H/brake cable
Apr 04, 2008 | Power Acoustik PTID-900 Car DVD Player
Screensaver
This might be related to your question, read through the answers.
http://www.fixya.com/support/t126992-bypass_parking_brake_switch_in_order
Dec 09, 2007 | Power Acoustik PTID-4003TV Car Video...
Cannot see video
What i did was get a switch from walmart. they cost less than 2 bucks...Get one that has 3 slots..1 for power, 1 for acc, 1 for ground. Plug the brake cord the acc, and splice the power and ground cords to the other two. When your switch is off you can watch video while you drive, when its on it will cut the video off and display that message.....
If you want to do it the right way, then plug it into the emergency brake line or the parking brake line...hope i helped
Power Acoustik PTID-4003TV Car Video Player Logo
118 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
