Question about Lenovo 3000 Y410 Notebook
Vista 7 upgrade & One Touch compatability
I did the Windows 7 upgrade adviser beta test on my y530. It looks like just about everything is upgradable except One Key Recovery v.6.0.2102, easy capture & veriface III.
I use recovery often, as vista updates kill my computer. how can I get around this & either put the computer back with one key if 7 doesn't work &/or upgrade to one key for 7 if it does?
    President:
  • 2,678 Answers
Basically you can't as it is incompatable, however having said that you should not need to use recovery anywhere near as often (if ever) with Win7 as it has supposed to have ironed out all the problems that Vista has caused in the past.
All that said it is always a good idea to have a backup available to do a system recovery, unfortunateley one touch is not an option with win 7 ATM
Posted on Oct 03, 2009
During upgrade of windows 32 bit vista to win 7 32 bit compatibility test advised to update device drivers storage controllers SCSI/RAID host hd type seagate baracuda 7200-10 how do i find suitable...
The drivers for vista and windows 7 are probably the same. As long as you performed an upgrade and all your original programs and data are still there. there is no point in updating drivers unless you are expieriencing problems.
Jul 22, 2011 | Computers & Internet
Tip
Upgrade Windows XP to Windows 7 - it can be done!
Windows XP has been around for over 12 years. With that much time in use, there are bound to be situations where exporting data, finding install disks, installing the new OS, reinstalling the program and then restoring the data is not a viable option or is doomed to fail. What can you do if you are faced with this situation? Simply, upgrade the system to Windows 7!
Despite Microsoft's claim that there is no upgrade path from Windows XP to Windows 7, there is a way to make this happen. As a consultant, I am faced with this issue several times a month and fully expect this to rise as more companies transition to Windows 7. The reasons to upgrade the existing system range from legacy databases that cannot easily be exported and imported, software that is permanently associated with the specific PC hardware and software that require a hardware dongle that does not work with newer PC's. Regardless of the reason, there is a way to upgrade Windows XP to Windows 7.
Let me say at this point that the process to upgrade Windows XP to Windows 7 is involved and there are some things you will need to prepare for to make this process successful. If you have Windows XP 64 bit, you can upgrade to Windows 7 64 bit. If you have Windows XP 32 bit (as most installs are), you will have to use Windows 7 32 bit.
Tools you will need:
1. Download Windows Upgrade Advisor
2. External hard drive
3. Windows Vista Business Edition Service Pack 1 (no license needed)
4. Windows 7 Professional with license
The Prep:
As with any major change, you need to create a backup of the existing system. Use your favorite method of backing up the OS, data and system settings (I prefer to use Ghost to get an entire image of the hard drive in a short period of time).
Create the backup of Windows XP:
Before continuing, disconnect all hardware from the PC and uninstall all printers, scanners and any other hardware devices that will need a new Windows 7 driver. This step will save you time troubleshooting a failed device once Windows 7 is installed.
Also, verify the Administrator account log in and password or setup a new local Administrator level user login and password.
Run Windows Upgrade Advisor. This will indicate if there are any software or hardware that is currently in use that absolutely will NOT work with Windows 7. Evaluate all non-compatible software and hardware issue with the user and see if this is a "show stopper".
You can still proceed with the upgrade and see if you can make the software or hardware to work by changing the compatibility settings in Windows 7.
The Process:
With Windows XP running, put the Windows Vista Business disk in and start the upgrade process. When prompted, choose UPGRADE. (This process can take some time so be patient.) Let this finish and the system will reboot. Verify Windows Vista is properly installed by logging in using the local Administrator account.
Reboot Windows Vista at least 2 times, logging in each time, to ensure the new OS is working correctly.
With Windows Vista running, insert the Windows 7 disk and start the upgrade process. Choose the UPGRADE option again and let this complete (again, this will take some time so be patient). Once Windows 7 is installed, the system will reboot. Use the local Administrator account to login and test the OS to ensure it installed properly.
Test everything:
Test everything - log into each program and verify access and functionality. Do not skimp on this step - get the user to log in and watch them run their programs.
Once initial testing is complete, re-install the printers, scanners and other hardware that will need updated drivers to work correctly.
I have followed these steps numerous times and it has worked perfectly each time. Removing the printers and hardware before upgrading will save you time and was a lesson I learned after my first upgrade.
on Nov 09, 2013 | Microsoft Windows 7 Professional for PC
Tip
Upgrade Windows XP to Windows 7 - it is possible!
The Prep:
The Process:
Test everything:
on Nov 09, 2013 | Microsoft Windows XP Professional
Why does if i upgrade my laptop to windows 7, it can't be activated? and why does my drivers where not compatible with windows 7?
Because the laptop is made before Windows 7 is made. If you try to look at the drivers website (Click Me). There is only Windows XP and Windows Vista drives that is available not Windows 7. refer to the figure
Jul 22, 2011 | Dell Latitude D630 PC Notebook
Hi, im using vgn cr23g. i upgraded- the ram from 1GB to 4GB. Then i upgraded to Vista (Service pack 1) as advised by Windows 7 Upgrade Advisor. Now i want to upgrade My OS from 32-bit Vista to 64-bit...
I have checked the specs of your PC notebook, I can see that you can upgrade the OS of your notebook to windows 7, because your PC passed the requirements for the windows 7 OS.
I hope you have a great day.
Jul 03, 2011 | Computers & Internet
I instal a windows vista but i can't find my audio
Is your audio device compatible with Windows 7? Did you check the hardware compatibility list before you installed the upgrade? Did you run the compatibility test (called Is Your Computer ready for 7?)
Find the list here: http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx Click on hardware and then find your device. If your device is compatible, the list will tell you - you will also find additional information at the post.
If your device is not compatible, you will have to upgrade it to a devise that is compatible.
Thanks for your question @ FixYa.com
May 30, 2011 | Sony Computers & Internet
I am having installing my dynex wireles g usb adapter because it says the install driver is not compatible with windows 7 64 bit. Is there a way to install the driver?
I'd suggest installing the device drivers in the Compatibility Wizard. Remove that hardware device in Device Manager, right-click on the driver executable/installer file and select the Compatibility tab; click the checkbox before Run this program in Compatibility mode for option and select Windows Vista in the list-down box; then try installing the device driver. In addition, you can use the Windows XP driver for testing.
If the problem still persists, please understand that Windows 7 is a new operating system (only the beta version) and whole driverstore has been reprogrammed; some old driver is not compatible with new OS. I suggest that you should wait for another period of time till the retail version is released and push the vendor company to upgrade their device driver. Thanks for your time and understanding!
Good Luck!
Feb 28, 2011 | Dynex Wireless-G USB 2.0 Network Adapter
Drivers
I will recommend that you download and run the free Windows 7 Upgrade Advisor. It helps find issues with your computer’s hardware, devices that might affect installing Windows 7. Go to the Windows 7 Compatibility Center find direct links to drivers, updates, and downloads.
Apr 04, 2010 | Toshiba Satellite A300-ST6511 Notebook
Windows 7 on an ASUS R1F
I installed Windows 7 (fresh installation) and my R1F tablet works great!
Feb 13, 2009 | ASUS R1F Tablet PC
Lenovo 3000 Y410 Notebook Logo
144 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
